#199 |
![]() Drives: 07 yaris hatchback Join Date: May 2011
I had always been curious about this. I bought a 2nd hand (AT) 2 DR hatchback, and didn't really know much about the Yaris.
By nature, I'd always coast as much as possible instead of the vroom-skrrrt everyone else did and noticed the engine sounded much different when I did. I presumed it was engine braking or something. Good to know I'm saving gas. |
#200 |
![]() ![]() Drives: red Liftback Join Date: Aug 2007
DFCO and engine braking...
When I bought my '08 3-door...I noticed a considerable engine braking when I took my foot off the accelerator! When going to work I have to descend down a long steep hill. My Jeep Liberty always required considerable braking to keep it down to the speed limit. With the Yaris, being much lighter and DFCO, the vehicle will coast down at about the speed limit without any braking required.
I could literally feel the engine compression helping to keep the speed down. Felt like a miniature Jack-Brake was on. I once had a Mazda compact pickup...coming down through the mountains one time...I thought that I would have to replace the brakes by the time I had gotten down (even in low gear). The Yaris just stays at about 30-40 mph. |
#201 |
![]() Drives: 2008 Civic LX sedan 5AT Join Date: Dec 2011
I don't have a Yaris (yet) , sorry. But DFCO can be a useful tool if/when you use it for slowing down or controlling speed on steep hills. For gliding, not so good. In my automatic Civic , it works in any gear , and at any RPM above 1000. For those who are not sure if they are in DFCO mode, you can usually feel the deceleration, or if you can't, your SG2 will show 9999 MPG (or 0.0 l/100km). You guys have ScanGauges , right ?
But I'm pretty sure that any "hypermiler" from CleanMPG doesn't try to glide in DFCO. |
#202 |
"the end user can induce DFCO conditions more often than 'natural driving' would
by adjusting how they use the kinetic energy of the vehicle, and the gas pedal and gear choices" My keyboard is acting up ; I can't seem to make it highlight the text I want to present as a quote. This guy (127.0.0.1) seems to know a thing or two. Or at least I do not disagree with his post , lol. Does anyone know why he was banned ? For my driving (not many steep hills) I find that invoking DFCO is most useful for driving with load (DWL) in traffic. When you maintain the proper interval , DFCO can mean you don't need to touch the brake when the person in front of you hits his. Any sudden lift of your right foot should put you in DFCO. My findings/comments are based on my experience with my Civic automatic , which apparently works a little differently than the Yaris with regards to DFCO. |
#203 |
is there a video of how exactly one can accomplish this? :)
JUST DRIVE
#204 |
Returning to Toyota
Drives: 2013 L 3dr MT Join Date: Mar 2013
very simply, when you take your foot off the gas it happens, except as you slow down and the engine RPM's drop below around 1100 rmp the ECU starts supplying fuel again, to avoid stalling the engine.
Automatics do it too, but not as quickly, depending on the gear engaged. Downshifting to slow the car when braking of course is the same thing, foot is off the gas. If the DFCO did not happen you would not get much engine braking. It's really very simple, and you don't need to know anything about it for it to work. Knowing that it is cutting off the fuel will help you to decide to either coast with the clutch in or or out, depending on how much engine braking you need. |
#205 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
#206 | |
#207 |
![]() ![]() Drives: 07 Yaris Liftback Join Date: Nov 2010
Haha this old thread was stickied so I assume it doesn't matter as much when people revive it.
Anyways, I've noticed the DFCO on the Yaris is not very noticeable on a manual transmission. With DFCO, my Yaris doesn't lug as bad as my civic did and I'm able to coast more effectively. Still getting 37-40mpg while hitting up to 85mph on the freeway and maintaining at least 70mph. Still rather impressive compared to my old civic which did around 30-33mpg. |
#208 |
![]() Drives: 2007 white hatchback Join Date: Apr 2013
When I brake going down a hill near my home the car feels like it downshift, it slows the car down so much that I have to accelerate to get the car to shift back to OD. I hate it, make me so mad some times that I floor board it to get going again. Is there a way to avoid this idiotic function?
#209 | |
#210 |
Returning to Toyota
Since you don't have a manual tranny, try sticking it in neutral so that it will roll free, if you want to coast. However, if you are braking you want the engine holdback.
If you needed to brake just a little bit, then want to coast again a small tap of the gas should tell the transmission to up shift again. Flooring it will make it want to downshift even more. Automatics are really Nannytrannies.. they try to decide for you what you need. Manuals are for those who want to be in control! |
#211 |
Is this avaliable for the 2nz-fe?
I love the back of my car, the front... not so much |
#212 |
![]() Drives: Yaris d4d Join Date: Oct 2014
Does the 2002 d4d have this?
Sent from my iPhone 5 using Tapatalk. |
#213 |
![]() Drives: No longer own a Yaris Join Date: Jul 2014
It doesn't wear out your clutch to coast down hill in gear.
#214 |
![]() Drives: 2013 TOYOTA YARIS SPORT. Join Date: Mar 2016
I think it works.
I read about this DFCO thing and give it a try. 2013 Yaris Sport with manual transmission.
Got to say that I filled my tank with premium quality fuel, I over-filled it to the point of some fuel spill. I drive in the conservative zone of 40 mph to 60 mph. Set the controls to monitor MPGs... When I lift the foot off the throttle that MPG monitor is set to 9999... I hit the throttle pedal and the MPG numbers started to flicker and constantly change. Low numbers if I press it to hard, good high numbers if I keep it in a sweet-spot of 45 mph / 55 mph. Used the A/C just a few times minimum. I am impressed that I was able to get over 80 driven miles on the over-filled fuel before the fuel gauge needle sets at the FULL mark and began to monitor fuel consumption. So far I got 262 driven miles with half tank (drove a bit harsh on the weekend) and I think I can get 400 driven mikes when it goes to E (empty) Average MPG monitor got better ratings too, from a 24.7 mpg to 38.5 mpg. |
#215 |
![]() Drives: 2018 LE 5DR A4 Join Date: Aug 2018
Is it possible that on newer models DFCO functions in 4th for the Autos?
Our 2018 will report a fuel flow of, literally, 0.0 when going downhill in top gear (not 3rd) with no foot on either pedal. The slightest press of the gas brings flow to a couple L/100 of course. Conversely with a gentle press of the break we initially still see 0.0, but as as the speed (or more likely the RPM) dips, a minimal flow is manifest at a certain point. Seems consistent with how DFCO works, no? |
#216 |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
Yes, it definitely functions in 4th gear for the auto transmission.
As long as engine revs are above the minimum for the function, DFCO will operate in any gear. A couple of my regular drives each week involve hilly stretches of 70 and 80 km/h road which I usually drive on cruise control. It's easy to see the consumption drop to 0 L/100 km on the downhill sections. The transmission also changes down to third on some of these to provide more engine braking, so you don't have tomride the brakes as much.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
| low gas mileage? | yrsdrgn | General Yaris / Vitz Discussion | 30 | 01-17-2019 04:26 AM |
| Synthetic oil MPG boost since change | Yaris Dick | General Yaris / Vitz Discussion | 29 | 09-15-2007 09:15 PM |
| Increased MPG or HP anyone???? | slvryaris | Performance Modifications | 55 | 05-27-2007 11:49 AM |
| MPG trackers | acrbill | General Yaris / Vitz Discussion | 11 | 01-01-2007 08:34 PM |
