Old 12-21-2011, 06:18 PM   #145
Originally Posted by devinlamothe View Post
OK tried that still nothing.
I am wondering if the hood safety switch needs to be connected to ground for the unit to operate. They don't really explain in the manual except saying it NEEDS to be connected (I've read you don't have to connect it but I guess it's worth a try).
The hood pins ground when the hood is open, so you leave them floating (i.e. not connected) to bypass.
Old 12-21-2011, 07:45 PM   #146
NHYarisFan
Drives: 09 Yaris Sedan Flint Mica
Just got new unit
Hi everyone this is my first post in a long time >:D i'm getting ready to install the ultrastart u4296m next week while i'm on vacation! my only question is about the clutch. will i have to bypass the switch to remote start, if so how do i. thanks yarisworld and Scott for all the great information.
*Update*
Hi everyone well i was a fool. Looks like i missed the clutch relay pic in post #118 first time around lol got a relay and everything works awesome. Thanks again YW!! i love this site
NHYarisFan is offline   Reply With Quote
Old 12-21-2011, 08:59 PM   #147
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Alright well that eliminates that.
I'm going to verify my ground point ... that's the only other thing I can think of.
devinlamothe is offline   Reply With Quote
Old 12-21-2011, 09:17 PM   #148
Unplug the power connector from the remote starter and measure the voltage between the ground pin and the constant power pins. That will verify exactly what the unit is getting.
Old 12-22-2011, 04:27 PM   #149
devinlamothe
OK ground is fine. I was able to get the shutdown code and it says "Transmitter shutdown (or push button)" (the LED on the unit flashes 4 times).
Car isn't even attempting to crank at all and remote errors out. I really wish these car starters had an LCD display, lol
Old 12-22-2011, 04:41 PM   #150
So that means that it thinks that you are either hitting the button on the remote a second time to kill it, or the valet mode is activated. Go through the procedure to turn valet mode off.
Old 01-24-2012, 12:19 AM   #151
yarisyeti
Drives: 2011 Yaris 3d LB
Is it better to solder or tap into the wires?
Does either void the warranty?
Thanks!
yarisyeti is offline   Reply With Quote
Old 01-24-2012, 12:24 AM   #152
Thanks!
Nothing voids the warranty unless what you do leads to failure of it or something else.
Soldering typically is better, but wire taps work fine and can be a bit safer to work with under the dash. I have used wire taps on the last 4 of my cars that I installed remote starters on and have driven 100K+ without an single issue.
Old 01-24-2012, 01:13 AM   #153
yarisyeti
Next question. I am adding electric windows to my bone stock yaris. I am using a Prestige APS787C and it says it can roll windows up and down.
On this site: http://voxrightnow.custhelp.com/app/...e-start-system It says I can use channel 4 and 5 to do this, my question is, can I just hook the wires for channel 4 and 5 to the power and ground of the window, or do I need to hook up relays?
If I have to hook up relays, how will I wire them?
Here is my install manual as well! http://www.clubgpstore.com/art/aps787_IM.pdf
Thanks a million!!
do i use this relay:http://www.automotiverewire.com/Nava...ayswindows.htm
Old 01-24-2012, 08:07 AM   #154
Thanks a million!!
For the remote window closure you need an auto window closer device, like the DEI 530T. The aux output of the remote starter would become an input to the 530T to tell it to crank up the windows (or with another output, down as well for airing it out in the hot weather).
Old 01-24-2012, 02:48 PM   #155
yarisyeti
could I use a 529T?
Old 01-24-2012, 02:49 PM   #156
yarisyeti
Can I use a 529T?
Old 01-24-2012, 03:15 PM   #157
Can I use a 529T?
Yes. The 529T just gives you one direction, whereas the 530T gives you both.
Old 01-25-2012, 02:07 PM   #158
yarisyeti
wouldn't hooking up a relay like thishttp://www.automotiverewire.com/Navagation/spdtrelayswindows.htm work just the same?
Old 01-25-2012, 02:17 PM   #159
Yes, although the relays will stay energized as long as the output channel is on, whereas the 529T or 530T has some intelligence to turn its relays off. The problem with leaving them energized is that if you trigger the output channel after turning the car off, and then leave the car parked for a day or so, you may come back to a dead battery.
Old 01-24-2013, 11:36 AM   #160
mirapatec
mirapatec's Avatar
Drives: 2012 Yaris L, 2020 Yaris LE HB
@ CTScott - Thanks for sharing all this information with other Yaris owners.
2012 Toyota Yaris L and 2020 Toyota Yaris LE HB
mirapatec is offline   Reply With Quote
Old 02-08-2013, 02:37 AM   #161
pat005
Drives: 08 Yaris 3-Door
Sorry to be "that guy" but I seem to be struggling with something I feel isn't very complicated but don't want to mess it up. Here's mine but I can't find from the DIY I can't seem to find anything that looks remotely similar with the two black and two pick wires. Oh yeah, 2008 HB Yaris. Thanks
https://plus.google.com/photos/11558...66988681874529
Link to the two photos
pat005 is offline   Reply With Quote
Old 02-08-2013, 07:53 AM   #162
You are about a foot to the left of where that connector in my picture is. It is the ignition switch connector, which is located at the base of the ignition switch, on the right side of the steering column.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 02:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 02:26 AM
