Old 02-01-2012, 07:42 AM   #1
Jack Yak
Drives: Yaris 1.3 07
Finally i installed Cold Air Intake system on my 1.3 yaris ! K&N
Hi everyone ..
Finally i installed Air intake system "K&N Sport Fillter" in my 1.3 sedan yaris
it has a coooool sound after 3000 RPM
but i don't feel any improvement in acceleration ! ! !
someone told me that the air mass sensor need readjustment but i don't know how could i do it ? ?
is that true ?
there's some pics during installing ..
Jack Yak is offline   Reply With Quote
Old 02-01-2012, 09:31 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
The MAF may benefit from being cleaned, there is no adjustment for it. To clean the MAF use an electronics cleaner in a spray can
Old 02-01-2012, 09:35 AM   #3
Jack Yak
you thought that the dust affected the sport air filter ? ?
Old 02-01-2012, 09:46 AM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Mass Air Flow sensor.
Old 02-01-2012, 09:47 AM   #5
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
MAF = mass air flow (sensor)
it is the sensor that is in the new tube. it is held in by two screws and has a wiring harness on it. in your picture, it is between the two hose clamps. on the nice shiny hose, it is the dirty dusty thing that you put back on it.
Old 02-01-2012, 10:07 AM   #6
Jack Yak
yes i got it ... but you thought that the dust could affect the sport air filter ? i could feel any improvement in acceleration if i well cleaned it ?
Old 02-01-2012, 10:07 AM   #7
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Dirtiest engine bay ever. And 1.3?
Old 02-01-2012, 10:09 AM   #8
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
did you disconnect the negative from the battery to let the ECU reset?
goliath1812 is offline   Reply With Quote
Old 02-01-2012, 10:33 AM   #9
Jack Yak
:( i'm gonna clean it ,, but i did not do it before because someone told me that it's too bad if you cleaned your engine and you don't have to do it
and yes sir it's 1.3
yes i did
i disconnected it and reconnect after about 10 min ! NO change NO improvement !
Old 02-01-2012, 11:10 AM   #10
kou
Drives: 08 lb
Whoever told you not to clean your engine is a dumbass.
Old 02-01-2012, 12:36 PM   #11
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Basicly what he was trying to tell you.
If you unscrew those 2 phillips and disconnect the sensor, you can pull it out. Then you can clean the little shiny part in the sensor that is shown in the picture attached. It usually gets dirty and is a good idea to clean it every now and then.. esp with a filter like you have there. Those filter doent filter out as well as the paper ones do, but thats for air flow reasons..
I would disconnect your battery again, and clean the MAF sensor. then put it back. Your ecu should reset your learned driving habbits.. You MAY feel a throttle response difference but unlikely. But it doesnt hurt to clean it.
-Derrick-
Old 02-01-2012, 12:49 PM   #12
1.5
Form>Function
1.5's Avatar
I thought in 07 the yaris sedan was only available in 1.5L
http://en.wikipedia.org/wiki/Toyota_Vitz
right...
Old 02-01-2012, 02:08 PM   #13
Jack Yak
right you are
you mean that i have to clean the shiny part in the sensor followed by disconnecting the battery ,, so that i MAY feel some improvement ,,, but you are not sure that i'll feel improvement in acceleration ? ? right ?
right...
No i have 07 yaris sedan with 1.3L engine
Old 02-01-2012, 02:17 PM   #14
goliath1812
A new intake will probably only give an extra 1-2 hp over stock, which you probably wont even notice. It's never a bad idea though to clean your MAF. Especially with how dirty your engine bay is.
Old 02-01-2012, 02:39 PM   #15
Jack Yak
you mean no increase in 0-100 acceleration "for example .. " occurs with installing new intake at all ? ?
guys : should i change the filter place ? or that's good place ?
i would like to move it slightly left and slightly down
Old 02-01-2012, 03:25 PM   #16
ilikerice
ilikerice's Avatar
you dont have to disconnect the battery to clean it.. but it would help..
disconnecting the battery will reset the ecu. the ecu learns driving habbits and compensates. being that you already disconnected it to begin with, you dont have to. unless u get a code.
Am I the only one about this thread
-Derrick-
Old 02-01-2012, 05:34 PM   #17
1.5
Form>Function
1.5's Avatar
Dude i am confused. And I still disagree on there being a 1.3 sedan in 07 unless its a CAD import.
Old 02-01-2012, 05:35 PM   #18
1.5
Form>Function
1.5's Avatar
Is this why you are so graciously giving yours to me? lol
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 10:20 PM
FS: AFE Air Intake System (Cold Air Intake) jjbG35yaris Items for Sale by private party 7 04-01-2011 03:58 PM
