Old 02-01-2012, 04:50 PM   #19
Jack Yak
Drives: Yaris 1.3 07
Dude i am confused. And I still disagree on there being a 1.3 sedan in 07 unless its a CAD import.
it's middle east version dude ... in middle east the 1.5L engine only with 2010 , 2011 , 2012 ! before 2010 all yaris in middle east with 1.3L engine
you dont have to disconnect the battery to clean it.. but it would help..
disconnecting the battery will reset the ecu. the ecu learns driving habbits and compensates. being that you already disconnected it to begin with, you dont have to. unless u get a code.
Am I the only one about this thread
A Code ! ! ! wat do you mean by get a code ? ?
Jack Yak is offline   Reply With Quote
Old 02-01-2012, 05:08 PM   #20
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
^ Your location says new york, hence the confusion.
Old 02-01-2012, 05:15 PM   #21
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
exactly lol this dude is crazy
Old 02-01-2012, 05:26 PM   #22
Look at that engine bay... that's Saudi dust if you ask me. Just a guess.
maybe he's FROM new york?
Old 02-01-2012, 05:46 PM   #23
1.5
Form>Function
1.5's Avatar
Its New York, Saudi Arabia
Old 02-01-2012, 06:13 PM   #24
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Um, I'm pretty sure you're supposed to remove the factory intake pipe... The filter should be connected directly to the throttle body, not clamped to a rubber pipe.
Old 02-02-2012, 01:33 AM   #25
syntax
syntax's Avatar
@ jack yak, are you here in saudi arabia?
Old 02-02-2012, 09:52 AM   #26
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
A code is when your check engine light comes on. It will have a code set in the ecu. You can use a scanner to read what the code is. Either the scanner can erase the code, OR you can just disconnect the battery for a min and it will erase the code also. SOMETIMES people get a code when doing an aftermarket Intake. Like if you forgot to plug the connector back into the MAF sensor and turn the car on, like i did..
-Derrick-
Old 02-02-2012, 11:46 AM   #27
yaris 2sz
www.yarisclub.gr
yaris 2sz's Avatar
Drives: yaris 1.3 2sz - 1.33 1nr
right. wash it.
yaris 2sz is offline   Reply With Quote
Old 02-02-2012, 07:34 PM   #28
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
The piss por transitions create so much turbulence that the additional airflow from the cone filer is not being used.
Get a real intake
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 02-02-2012, 10:13 PM   #29
Jack Yak
i'm not from usa neither saudi arabia i'm from Egypt
New York was wrong written while registration and i forget to edit it !
why ? dose the rubber pipe affect air flow ?
yes i got it ,, but if i reconnected the buttery i don't need to get any codes right ?
Originally Posted by yaris 2sz View Post
right. wash it.
Get a real intake
! ! are you really meaning that there are too much turbulence with the air flow ? ? ?
i saw alot of intake systems havning U and L shaped and worked good ? ?
btw ... i cleaned the AFM and reconnected the buttery then i got a good improvemnt
that's my acceleration 0-100 before installing the filter
http://www.youtube.com/watch?v=vI_2G...layer_embedded
and that's after installing the filter and cleaning the AMF
http://www.youtube.com/watch?v=2GwFn...layer_embedded
1.2 sec difference ! Good improvement
last question ..
do i need to change filter place to get more cold air ? ?
Old 02-02-2012, 10:24 PM   #30
malibuguy
Obsessed with 1.5L
But they are smooth on the inside. While yours is cobbled together with no internal streamlining.
-96 Tercel 4dr
Old 02-03-2012, 09:55 AM   #31
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
hahah.
yeah, clean it up a good bit. if you really wanna enjoy the intake, just drive with your windows down and radio turned down. thats how i enjoy mine. sounds like an asthmatic kid fighting for his life. but if thats what the engine looks like due to location, i prob wouldn't roll my window down and let that crap get inside my car.
Club SHIFT
Old 02-05-2012, 04:38 AM   #32
menz
Drives: yairs blue 2007 automatic 1.3
hey jack hearing u r from egypt. I just installed HID kit but i do not like the glare do u know if there is anyone around can help me install projector lens to my headlights and do you have any experience with that.
menz is offline   Reply With Quote
Old 02-20-2012, 07:37 AM   #33
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
My location is saudi arabia, but I don't have such a thing.
Pic was taken during my eyelids blackening procedure last weekend.
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 02-20-2012, 09:51 AM   #34
@ malibubuy
Check post 1, that's his car. Post 27 is someone else's.
Note the ribs right before the TB in post 1. I believe this is stock.
and by the way -- the OP's original question was answered in post 2.
Old 05-13-2012, 09:42 AM   #35
BoyMalambing
BoyMalambing's Avatar
Drives: Toyota Echo 2005
will this be work in Toyota Echo 2005 1.3 engine....
This is my 1st first car in Saudi Arabia
BoyMalambing is offline   Reply With Quote
Old 06-26-2012, 02:09 PM   #36
JonathanHB2011
Drives: Yaris 2011 1.3L
Hi! What is the part number of the K&N air filter you installed?
JonathanHB2011 is offline   Reply With Quote
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
FS: AFE Air Intake System (Cold Air Intake) jjbG35yaris Items for Sale by private party 7 04-01-2011 02:58 PM
