![]() Drives: yaris verso 1.3 vvt Join Date: Feb 2012
1.3 vvt, hi idle speed on startup
Hi,
I have a 2004 Yaris Verso auto. NCP-20L 1.3 2NZ-FE. when it is started cold without a foot on the gas pedal, the idle speed jumps as high as 3000rpm before it comes down to about 1600, where it hangs about for at least 30 seconds until it settles down around 12-1400rpm untill it warms up. outside temp: -10 deg C / 14 deg F Is this normal? no other "modern" cars i drive these days do this. It cant be so good for engine wear jumping up to 3000rpm as soon as the engine fires. We've had the car since 2008 and it's allways behaved like this, even in warm weather it jumps to at least 1600 when it fires. advice would be appreciated. |
| Raising Idle speed? | Incillio1 | General Yaris / Vitz Discussion | 20 | 05-10-2020 02:08 PM |
| Cold Idle Speed Question... | cpnnz | DIY / Maintenance / Service | 9 | 11-04-2009 05:31 PM |
| what is the idle speed on stock 09 HB | ezhacker1 | General Yaris / Vitz Discussion | 5 | 05-17-2009 08:49 AM |
| Low idle speed | gonzo452001 | DIY / Maintenance / Service | 9 | 02-21-2007 08:41 PM |
