![]() Drives: Toyota Yaris II Join Date: Jan 2012
Installation of original power windows and locks in Yaris
Hello!
I have 2008 Toyota Yaris Terra A/C - sadly without power locks and windows: http://www.toyodiy.com I am considering of buying used power window and lock parts and installing those in my car (only front power windows, and at least front power locks). I must replace door parts with door wires which leads to GD1,GD2 (drivers side) and FD1, FD2 (pass. side) connectors. From these connectors wires go to ECU (I don't have that wires mounted). SOL version of Yaris according to: http://www.toyodiy.com/parts/p_E_200...MGKW_8404.html which has fabric mounted wireless locks (information from distributor's leaflet) and power windows has a same ECU like mine. Is it possible do install original parts, connect these to ECU and have power windows and locks? |
i am wanting to do this install as well. i havent found any salvage yard with a wrecked 3dr yet tho. As far as i can tell as long as you have the door harnesses and all the hardware it should be a plug n play application
#3 | |
#4 | |
That's good news. Thanks.
It is hard to get to the Body ECU connector D33? |
Actually, looking at the European EPC, they are different for Yaris with and without power locks. I had looked prior at the US Sedan ones, (since I have a sedan Body ECU sitting on my test bench) which were the same with and without power locks.
For the European liftbacks (built in France), there are four different ones. The different part numbers are based on if they have wireless locks and if they are cold spec or not, so ones with and without power locks and windows, but without wireless locks may still be the same. 82730-0D310 82730-0D320 - With wireless door locks 82730-0D380 - Cold spec 82730-0D390 - Cold spec with wireless door locks
| Power windows and locks on a 2009 3dr. | chilly79 | DIY / Maintenance / Service | 8 | 12-15-2010 12:55 PM |
