Old 02-08-2012, 03:25 PM   #973
Jason@SportsCar
Originally Posted by CrankyOldMan View Post
So this--combined with reverting the final drive--should make you much more competitive than last season? How's the gearbox coming along?
The car still wont be a front runner in the dry, but it should be faster than the last two years.
Still waiting on the close ratio gear box.
Old 02-08-2012, 03:41 PM   #974
Jeff@MicroImage
"Know it all"
Jeff@MicroImage's Avatar
Drives: Lancia Delta Integrale
Are you still running VVT-i in this car? Does your tuner/management have control over the that?
www.microimageonline.com
Jeff@MicroImage is offline   Reply With Quote
Old 02-08-2012, 03:48 PM   #975
Jason@SportsCar
Yes, still running it and the AEM controls it.
Old 02-08-2012, 04:01 PM   #976
Jeff@MicroImage
"Know it all"
Great results! I'm real excited to see that these actually work. I'd be curious to see if any top end gains or benefit from disabling VVT-i and running set or manually adjustable cam gears. Might loose more torque though...
Can't wait to see what the turbo spec Jun cams do for boosted cars
Old 02-08-2012, 04:04 PM   #977
Jason@SportsCar
The low end gets really weak with no VVT-i control.
Old 02-08-2012, 10:00 PM   #978
racerb
The results are in, the Jun cams are an improvement over the custom grind we had done for the 2010 season, but they are not magic.
With the combination of head work and cams we picked up 12hp when compared to the stock engine we ran in 2011. However, just like with the custom grind cams we lost Tq below 5000rpm when compared to the stock engine - fortunately in this case we only lost 3ft-lbs, where the 2010 cams lost around 18ft-lbs.
While I was not jumping for joy at the final numbers, I was happy to see the top end power match our 2010 numbers, while regaining most of our lost Tq. Additionally, the power band with the Jun cams is much broader than the custom grind was, we have nearly 1000 more usable RPMs than we did before. From 5500rpm on we have more HP and Tq than either of the previous setups offered, and the power delivery is smooth.
If you are thinking about the Jun 9.5 cams keep in mind these are not a direct bolt-in. Your head will need relief cuts to clear the lobes, and without engine management you will not see the full gains.
Overall I give them a thumbs up, but expect to spend about $2k between the cams and head work.
As a long time racer of low horsepower front drive cars, any gains with restrictive rules are a real plus. Learning how to get the most out of the loose nut behind the wheel, can actually make the biggest difference. Just look back in history at what those early racers did with the first Mini Coopers, cars that might have had 40 hp and tiny, skinny as hell tires. When you get to the point where your getting the most out of you the driver, then horsepower numbers aren't as big a factor in all out speed!!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 02-17-2012, 02:49 AM   #979
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
pics
From runoffs
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 02-17-2012, 10:56 PM   #980
Jason@SportsCar
Off to Willow Springs tomorrow, testing radial slicks on the 99.
Old 03-13-2012, 08:35 PM   #981
Jason@SportsCar
We are making progress on the Kaaz close-ratio gear set. Kaaz USA was able to track down the synchros we need, and are making modifications to two of the gears for a proper fit. They have already successfully built one trans for the Scion rally team, and are working on our gears right now. We should have all the parts in hand before the end of the week.
I would imagine that means I will spend my weekend in the place I am getting way to familiar with, on the floor pulling a trans out.
Old 03-13-2012, 10:45 PM   #982
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Wow, I'm surprised to hear that there's so much involved in fitting those gears. The C-56 gears went in without much fuss, but I'm stalled on funding for replacement parts and the LSD.
Old 03-14-2012, 02:31 PM   #983
Jason@SportsCar
It is odd, these were supposedly built for the C56. Are you pulling parts out of a C56 A or B? Could be the difference.
Turns out the gear itself is not to wide, but the collar at its base, that combined with the Yaris synchro made it bind up. And it is only the 3rd and 4th on the input side that is the challenge. They take a little bit off the collar and install the Celica/MR-S synchro its supposed to fit.
Fingers crossed.
Old 03-14-2012, 10:46 PM   #984
racerb
Back in my Honda racing days this guy was the man for alternate gear sets, he can probebly help you out if need be. He is a multi-time SCCA Champ and really knows a thing or two about gearboxes.
http://www.housemanautosport.com/
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 03-14-2012, 11:44 PM   #985
Jason@SportsCar
racerb
He was the first person I talked to when we started looking for gears two years ago. He was willing to make a custom final drive, but we found the xB gear fit at a fraction of the cost. He had no interest in doing the dog engagement trans that I wanted.
Old 03-15-2012, 08:18 AM   #986
CrankyOldMan
Fingers crossed.
I'm afraid you've got me stumped on that one. I didn't realize there were two C56 variants, or at least that there were significant internal differences between the front and rear mounted versions.
Old 03-16-2012, 10:59 PM   #987
racerb
Toyota must have a big range of different gearbox versions, my S-53 is fairly common, but I ended up with a JDM box and can't find syncros or shims to fit it! Would love to find an alternate final drive, the 4.18 is just not working for our longer tracks here in the East.
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 03-16-2012, 11:25 PM   #988
Jason@SportsCar
C56A open diff
C56B LSD
You may actually have the same problem we did and not know it yet if you have not put it back together. You wont know until you jam it all in the case and measure the drag when you spin it.
Old 03-17-2012, 12:15 AM   #989
CrankyOldMan
It's definitely a C56A then, as it's an open diff. The assembly goes together at the moment, but I haven't checked the torque yet. I have to replace the output shaft inner bearing (the one in the bell housing) because the C56 has an inner race on the roller bearing, whereas the C50/C59 doesn't, and the groove where the snap ring holds the inner race on the shaft sits right in the middle of the rollers. I'm assuming that you weren't able to get the torque set properly with any of the shims, which prompted you to investigate?
Old 03-26-2012, 09:19 PM   #990
Jason@SportsCar
The trans out of the 99 is in the shop for its new guts. With any luck I will have a close-ratio box by Friday.
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 08:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 11:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 06:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 01:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 11:51 AM
