#1819 |
Roadrunner Jr.
This is where I step back. I don't even have aftermarket rims on mine yet. I'm still waiting to lower it...happening this week sometime...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#1820 | |
The only problem going low and getting wheels is the offset, most of the time you could end up with rubbing problems, but there are a couple of ways to be safe. D.
. CLA 250, 4MATIC |
#1821 |
Roadrunner Jr.
I just put on the Eibach Pro kit this evening. It's going to be interesting to feel the car settle in. Already I can feel and see the car NOT lurch forward under braking and with the gear changes. What suprised me was how simply Toyota made the rear spring setup. Basically just a "cup" on the lower axle that presses the rear spring onto the unibody. literally two minutes per side on the rear.
I'll look at that sway bar. It was one of the first things I took off after the wheels...the factory bar that is.
#1822 |
Either size sway bar. If its mostly just day to day, then the 19 is good. Its waht I have on my sedan. But I do wish I had gotten the 23mm alot of times. I like to "hook up" around corner and I think the 23mm would have given me the little extra I want at times. Without sacrificing ride too. I still need to get springs under mine also....
#1823 | |
LOLD.
. CLA 250, 4MATIC |
#1824 | |
I have 19mm and love it, It's the combination of lowering springs + sway bar that gives you that sport feel. D.
. CLA 250, 4MATIC |
#1825 | |
![]() Drives: Yaris Sedan Join Date: Aug 2010
Been following your posts and noticed that you have not used any 3M Thinsulate™ Acoustic that's also available from Don. Any particular reason? Thanks |
#1826 |
Roadrunner Jr.
Thinsulate Acoustic? Interesting. 3M is a reputable name...
Who is Don Smabroke?
#1827 | |
LINK D.
. CLA 250, 4MATIC |
#1828 | |||
I used the a radiant barrier most of the floor where the exhaust is under to protect the amps from heat and under the dashboard to protect the HU. See POST # 263 and 295 for more information below... D. __________________________________________________ ___________________________________________ POST #263 Quote:
![]() and Talking about layers I just added one MORE! Radiant Barrier I'm putting this along the center channel and other areas after applying CLD Tiles and before CCF adn MLV, I've driving with no center console, bare metal and I can tell it gets HOT! the other day I had a Hershey chocolate about 4 inches above, and it melted! I guess this heat going inside the cabin it's good in winter, but not good in summer, any way one more barrier to make the noisy work harder! ![]() __________________________________________________ ____________________________________________ POST #295 Quote:
OEM deadening material ![]() Taking a break! ![]() Clean! ![]() 2 CLD Tiles. ![]() Some of that Radiant heat insulator... ![]() 1/4" CCF and ready for MLV ![]() With no MLV to work last night I started playing around with the amps, the 3rd amp will be here soon, maybe I'll put it under the passengers seat? or in line with these 2. I didn't realize they where so big and heavy ![]() "I just added this picture as a reference for the MLV layer on top:" ![]() I would use it now, I don't see why not? D.
. CLA 250, 4MATIC |
#1829 |
. CLA 250, 4MATIC |
#1830 |
Thanks for the clarification on Thinsulate.
Will continue to follow the development of your car
#1831 |
![]() ![]() Drives: 2007 yaris sedan Join Date: Aug 2011
He sells hot dogs at Fenway Park |
#1832 |
Roadrunner Jr.
Here is an iPhone take on uncle Larry's Woolcot's Buick presentation from Chris LaCombe:
http://i720.photobucket.com/albums/w...p/081e5e7e.mp4
#1833 | |
ok, here I go: 1 seat or 2 seats? (looks like a 2 seat) Install finish looks awesome but how it sounds? The music in the background... I recognize it! B. Regal are one of my favorite cars in my personal list. I really would like to sit in a car like that, I need some thing to compare at, (sound quality speaking) and set up my goals. D.
. CLA 250, 4MATIC |
#1834 |
Sqcomp... I have a question on the P99
on the specs it says: "31-band equalizer with independent right and left channel adjustments" SOURCE how do I adjust Right and Left EQ for each side? D.
. CLA 250, 4MATIC |
#1835 |
Roadrunner Jr.
D...
We'll get to the P-99. Bear with me. Who is this (I know the answer), and yes, he has a name tag on...but WHO is he and why does it matter:
#1836 |
CEO of Alpine ?
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 01:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 08:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 02:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 03:47 PM |
