Old 04-17-2012, 11:13 PM   #1
Danyaris
Drives: 2007 Yaris sedan
Unhappy No response from my Yar..
Hi everyone. My car is totally dead. There are no lights showing on the dash at all. The symbol in the factory battery shows OK, but I can't even turn the key. Any suggestions???
Danyaris is offline
Old 04-17-2012, 11:25 PM   #2
2o6
Drives: 2007 Liftback
Check your connections.
2o6 is offline
Old 04-17-2012, 11:48 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Have you tried rotating the steering wheel? I've had the steering lock engage a few times to where it wouldn't allow the key to turn until you released the pressure on the tumbler. If not, then you may need to replace the tumbler. If that happens, then you need a new key, and possibly an ECU re-flash to get the ignition disable thing to work--assuming you have that feature.
CrankyOldMan is offline
Old 04-17-2012, 11:51 PM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Do you have an immobilizer? To check, see if your ignition cylinder has a black plastic ring around it.
Betrivent is offline
Old 04-18-2012, 07:10 AM   #5
curtmaxwall
Drives: Toyota Yaris Spirit
I think you should give one or two symptoms so that we can give the correct solution. By the way, have you checked the starter motor? Also check the loose connections in starting system of the car.
curtmaxwall is offline
Old 04-19-2012, 03:31 PM   #6
Danyaris
Hi everyone!Thanks for your imput. I tried boosting the car... it started smoothly. the daytime running lights came on after a couple of minutes. I let it run for 10 or so minutes. Once I turned off the engine, the dome light is very weak as well as the only symbol on the dash ( door ajar ). Now, after two hours, the ignition switch can be turn but no response...only the engine,battery, door ajar and oil lights showing on dash. When turning the key to start position I can bearly hear a very weak sound.
Danyaris is offline
Old 04-19-2012, 04:29 PM   #7
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Need new battery.
Altitude is offline
Old 04-19-2012, 04:44 PM   #8
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
bam! problem solved, close thread
-Derrick-
ilikerice is offline
Old 04-19-2012, 04:45 PM   #9
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
^+1
just because your battery (dumdum) eye says ok
your battery still could have a bad cell
OTA'sTOY is offline
Old 04-19-2012, 08:47 PM   #10
Danyaris
Thumbs up
Many thanks "YarisTeam" !!!
Danyaris is offline
Old 04-20-2012, 03:24 PM   #11
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
This is what happened to my car the other day, and it turned out to be the battery. Just replace and drive on my friend!
devinlamothe is offline
Old 04-22-2012, 09:49 AM   #12
CPALK719
CPALK719's Avatar
Drives: 2012 toyota yaris
sounds like your battery took a crap on you, similar thing happen with my evo, about a year ago. changed the battery out and it went back to normal
2012 yaris L model
2014 wrangler unlimited sport
CPALK719 is offline
6x9 speakers in front doors dawin2122 In Car Entertainment + Electronics (audio / video / alarm) 56 11-05-2011 03:55 PM
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Not Clean Yaris (a response) MWill517 General Yaris / Vitz Discussion 17 03-27-2007 05:01 PM
10" Type R in TCAB - Freq response - vid spkrman In Car Entertainment + Electronics (audio / video / alarm) 3 03-20-2007 03:53 PM
Response from Toyota Driver New YARIS Purchase Forum 22 09-04-2006 07:44 PM
