Old 03-22-2012, 06:56 PM   #469
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Originally Posted by pimp my yaris View Post
Made A big move yesterday and cranked up the turbo to 12psi. Hade to make a competely new map for my FIC. Old map was only good to 10psi. Its was running VERY STRONG for about an hour of very hard driving. Then I noticed the AFR's were getting a little lean. I will do some retuning if possible. I may need more fuel system upgrades at this power level. Possibly new rail with a return line or even lager injectors? The good news is I am no longer using that jimmy rigged pull spring on my wastegate as my boost controller.
Before you continue do a compression test so we can see what it is before 12. Your rods are goona be the first thing to go. Careful you don't burn up the exhaust valves that can make it show lean sometimes. And Dyno that thing so you can brag about it
Old 03-23-2012, 12:53 AM   #470
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Latest vid of stock 1nzfe at 12psi. Actually spikes to 13psi before dropping to 12psi. This was a forth gear roll on. Sorry, Im not good with filming.
http://www.youtube.com/watch?v=CfaEW...ature=youtu.be
pimp my yaris is offline   Reply With Quote
Old 04-16-2012, 11:14 PM   #471
pimp my yaris
C'est la vie
Did another dyno run at Sound Performance in Bensenville Il. They squezzed me in on a Buick dyno shootout on saturday. I pulled 197whp on a mustang dyno. They typically read 5% lower then Dynapac dynos.
Old 04-16-2012, 11:46 PM   #472
OH yeah, nice!
Old 04-17-2012, 01:34 PM   #473
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
that is awesome.
Colin Chapman disciple
Old 04-17-2012, 02:00 PM   #474
Focus_Sh1ft
Focus_Sh1ft's Avatar
So ridiculous... I would have never thought our engines could put down so much power stock.
Old 04-19-2012, 01:20 AM   #475
Schizoprenia
Drives: Toyota Yaris 1.5 M/T '06
OK I finally did some work to eliminate my smoke problem on cold engine starts. The problem has been getting progressivly worse as the weather gets colder. Their has been a lot of talk about where the oil return enters the pan. I dont believe that is the problem. But I admit its a possibility. My oil return was submerged in oil in the lower part of the pan. So this weekend I removed the right side axel and relocated the return to the top of the pan above the oil level. I also switched from a 1/4npt fitting and a 3/8in hose to a more free flowing 3/8npt fitting and a 1/2in hose. The thing is huge. For sure if I continue to have a cold start smoke problem, I know it will not be the return. I have finished the work and just need to fill with fluids tomarrow after my silicone drys on my oil pan. I will also take a pic. tomarrow.
how hard is it to remove the axel?
Schizoprenia is offline   Reply With Quote
Old 04-21-2012, 11:15 PM   #476
pimp my yaris
C'est la vie
Not to hard. You must remove right front wheel. Then remove the bolt on the spindle that clamps the lower ball joint to the spindle. Then you must remove the nut that holds the axel in the center of the front hub. I believe its 30mm and must be a twelve point socket. Then slide the axel out of the front hub and slide the ball joint out of the spindle. Then you can pull the rotor hub and caliper can be pulled out of the way and tied up. Then using a pry bar you can pop the axel out of the transmission. Drain transmission fluid out first or it will be messy. Muake sure if the axel needs to be hammered out of the front hub the threads are not damaged. Air tools and a compressor make this job much easier.
Old 04-21-2012, 11:32 PM   #477
pimp my yaris
C'est la vie
Well a couple of days ago I was driving to the grocery store and when I was leaving my neighborhood I nailed the gas in second gear. The tires broke loose and kept spinning until about 50mph. When I let of the gas and shifted into third gear I heard a loud knocking noise tied with rpm. I pulled over and saw no oil leaking. I drove home with the noise as the damage had already been done. I thought for sure I spun a rod bearing. I drained the oil and saw no metal chips in my oil. So then I did a compression test, 3cyl. at 155 to 160psi and 1cyl. at 95psi. Mystery solved. I slapped a valve at high rpm. Now I have a bent valve.
I am now working on removing my cyl. head. I also bought a used 80k mile motor from a local junk yard for 350$. I am going to put the head on my car, so I can get back on the road for now.
Then I am going to order pistons and rods for the short block soon so I can start on a higher boost motor. Goal 275-300hp
Old 04-21-2012, 11:37 PM   #478
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
for some reason they don't like 25+ psi either.
Old 04-22-2012, 12:47 AM   #479
pimp my yaris
C'est la vie
? Who is making performance valve springs besides Ferrea. 1000$ for valves and spring is a little stiff. And stock seem a little weak for my extended high RPM abuse.
Old 04-22-2012, 12:58 AM   #480
I've been running stock valves for quite a while with pretty tough track days included. We did put stiffer springs on them so I could rev to 7300.
I'll check our sources and see if anyone else is making valves. You want stock or over-size?
Old 04-22-2012, 01:49 AM   #481
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
There's Ferrea valves for sale in the FS section... have a looksee
Old 04-22-2012, 10:33 AM   #482
pimp my yaris
C'est la vie
Im just looking for valve springs. What Brand are U running Garm. And do you sell them?
Old 04-22-2012, 11:44 AM   #483
bluevitz, those oversized valves would be a substantial project on the head, I'm sure you know that; unless someone can do machining and such themselves.
I don't know what springs we have in my car, but Ferrea is making us an upgraded valve spring kit that supposedly would be ready by now. You know how that goes.
I will follow up with them on Monday.
Old 04-22-2012, 10:54 PM   #484
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
From assembling a few different Toyota motors, I can tell you that the Scion tC motor has the same dimension valve springs. So I've thought about just purchasing upgraded springs ( advertised for the tC) and using those.
I guess I have lucked out, using stock head and my limiter is set to 7300rpm. I've even slammed it in the wrong gear a few times and the rpm shot well past what the tach shows (8000 rpm). I'm pretty sure it was about 9000 rpm once when I was at the dragstrip and put it in second instead of 4th. I think the only reason I didnt get valve contact was because maybe the valves cleared the lower compression pistons even with float. I did hear a noise afterwards which scared me for a few minutes, until I figured out that my power steering belt flipped upside down! Lol
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 04-22-2012, 11:07 PM   #485
Viperoni
Drives: 2005 Toyota Echo
You had this happen to you too? When it happened to me, I couldn't believe it.
2006 Saturn Ion Redline
Old 04-23-2012, 12:19 AM   #486
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Yea, I don't even understand the physics behind how that can even occur.
Ptuning.com
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 03:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 03:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 02:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 03:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 03:10 PM
