Old 05-01-2012, 03:45 PM   #1
CPALK719
CPALK719's Avatar
Drives: 2012 toyota yaris
interior LED lights?
Has anyone change the interior bulbs to LED white bulbs for the map lights and dome lights? if so would you guys has the sizes needed to change these?
2012 yaris L model
2014 wrangler unlimited sport
CPALK719 is offline   Reply With Quote
Old 05-03-2012, 06:35 PM   #2
CPALK719
CPALK719's Avatar
59 views and no info on that as of yet??? HA.........
2012 yaris L model
Old 05-03-2012, 10:10 PM   #3
Revsson
Have you searched the Cosmetic Modifications (Exterior/Interior) section?
http://www.yarisworld.com/forums/forumdisplay.php?f=16
http://www.yarisworld.com/forums/sho...+interior+dome
http://www.yarisworld.com/forums/sea...archid=1367396
Old 05-04-2012, 02:29 PM   #4
CPALK719
CPALK719's Avatar
Originally Posted by Revsson View Post
your first link shows nothing but the cosmetic threads.... nothing pertaining to what i was looking for an answer.
second link somewhat helps, but then again thats for the older gens... i realize they probably might use the same parts for the newer gen as well. but thats why i asked on the 3rd gen forum, so i can see if anybody with a 3rd gen has tried this yet.
and that third thread link you sent showed NOTHING at all.
yes i did search, and found nothing pertaining to any of the threads i put up over the last week and finally now im getting a response .... this forum is going to shit
2012 yaris L model
Old 05-04-2012, 06:18 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
you seem to think you are in the late 90's modding civics.
You aren't. There are not thousands of people that have already done every mod you could even think of. Odds are you are the first to even think of doing this. I'd be shocked if they changed any of the lights in the 2012, so everything about the older models will work.
Colin Chapman disciple
Old 05-05-2012, 02:01 AM   #6
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I'd like to help you but have only had mine for about 2 weeks so everything is still unfamiliar. I think there are only just a few people with 2012's here. It'll probably take a year or so until there are more.
Old 05-05-2012, 10:34 AM   #7
CPALK719
CPALK719's Avatar
lmao i was under the impression the way a few on here tend to act , is that we have Yaris "gurus" on here. i figured someone should have done it by now
Originally Posted by TOLMACH View Post
I used this stuff for a dome light. In terms of internsity it is comparable to the OEM bulb but the color is @crazy white@.. I did it merely for looks.. you can buy similar items with more LEDs or use two if you want (one panel was enough for me). Price is an outrageous 1.99 including shipment )) Comes with wiring adaptors and @mounting hardware@ (3m double sided tape).
http://www.ebay.com/itm/390402270580...84.m1439.l2649
I decided to stick with OEM bulbs for map lights as they seem nice and comfortable.. LEDs are @too sharp@ when used while driving (to my taste)
Also used these for parking lights
http://www.ebay.com/itm/260981511370...84.m1439.l2649
and brake lights
http://www.ebay.com/itm/130619220449...84.m1439.l2649
Mine is 09 Hb.. yours should be comparable
appreciate the links and info man, i'll check it out !
yeap, i know
2012 yaris L model
Old 07-03-2012, 09:43 PM   #8
robkay
Drives: Hatch
and brake lights
Your post is helpful. I'm shopping for a dome bulb now and it's helpful to know that you think the 12 element bulb is about the same as the OEM.
Now, I just tried the one you spec for your parking lights as map lights and I don't care for them in that application. They are definitely not as bright as the OEM bulbs, but I'm thinking it's because only 1 of the SMD's is outward firing. The other 4 point to the sides. Now, I'm sure some of that light gets reflected out, but maybe not enough for map lights. Between that and the very cool white color range it is not pleasant to try to read with them. I'm willing to try to compromise on the color if I can just get one that is bright enough to light text well. I want LED's for map lights because I worry that one of us will leave one on and an LED will consume a lot less juice than an incandescent. (I think....) I have ordered this one to try: http://www.ebay.com/itm/W5W-Pair-Fro...item3cc85e23c9 I'll let you know how it works out.
[Update] OK, I definitely find the above front firing bulb to be better for map lights than the (5)-SMD 360 degree type I tried the first time. I tried them side-by-side and the 1.5W one is definitely brighter--not like night and day, but definitely noticeable. I'm going to have to get used to the cooler color, though. I see now that they have warm white options, but they seem to be more expensive for some reason.
I have since learned a little more about LED bulb options and understand now that the 360 deg type was the wrong choice for map lights. But, since I was brand new at looking for LED's I didn't even know there were front firing options. Chalking it up to experience.
robkay is offline   Reply With Quote
Old 07-05-2012, 12:56 AM   #9
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
changed my interiors today, 192 bulbs. i accidentally got blue, but it looks good so i left it. retail for the pair is 30, i paid 20 :)
reverse lights are 194 & brake lights are 7443
Old 11-23-2012, 03:19 PM   #10
J.A.R.V.I.S.
war machine
Drives: 2012 yaris LE
yeap, i know
Dude do your own research. If you can't find the size on the internet then go take the bulb out and look for the number printed on it. Go on Ebay type in the number. There should be a list of bulbs and LEDs that come up for that size.
J.A.R.V.I.S. is offline   Reply With Quote
Old 11-23-2012, 04:32 PM   #11
tooter
play every day
tooter's Avatar
Just a heads up... you answered someone who posted almost a half a year ago.
Old 12-01-2012, 07:33 PM   #12
yaristuner2012
Drives: 2012 Toyota Yaris Hatchback LE
Dome light
i believe i used 5050 T10 bulbs for my dome light, but i will update it when i take the lights out
Reverse: 194
back turning signal: 7443
front turning signal: 7440
hope this helps
yaristuner2012 is offline   Reply With Quote
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 05:13 PM
How to turn on the running lights and fog lights @ same timewhile/headlights off ...? Moratiya DIY / Maintenance / Service 8 12-11-2010 06:40 PM
Taillights, signal lights, parking lights stop working jamal1984 DIY / Maintenance / Service 2 10-13-2010 10:17 AM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 07:54 AM
