Old 03-16-2010, 09:03 PM   #1
typicaljawaiian808
Drives: '09 Yaris Sedan
Big 3 Upgrade in '09 Sedan! (w/pics)
Just did my Big 3 Upgrade in my Yaris. Here are some pics!
The engine bay is dirty I know, but I have to drive 4 miles round trip on a dirt road everyday to get home
Pioneer
Ascendant Audio
Sundown Audio
DC Power Engineering
Knukoncepts
Fosgate
Stinger
typicaljawaiian808 is offline   Reply With Quote
Old 03-16-2010, 10:31 PM   #2
YAR1S
YAR1S's Avatar
for your audio system? lol Im clueless.
-Jen <3
Old 03-16-2010, 10:39 PM   #3
typicaljawaiian808
Correct! I needed it bad as I plan to run almost 3500 watts of car audio!
Pioneer
Ascendant Audio
Sundown Audio
Knukoncepts
Fosgate
Stinger
Old 03-16-2010, 10:47 PM   #4
Palmer812
Drives: 2010 Meteorite Metallic LB
I did mine last week. I still have my factory stereo now but that will change in a few months. I only plan on 1000 watts or less but I think this is a good idea no matter how small of a system.
Palmer812 is offline   Reply With Quote
Old 03-16-2010, 11:22 PM   #5
typicaljawaiian808
Yes sir! My 300 amp DC Power alternator should be going in within the next 3 weeks!
Pioneer
Ascendant Audio
Sundown Audio
Knukoncepts
Fosgate
Stinger
Old 03-16-2010, 11:25 PM   #6
typicaljawaiian808
@ Palmer812 - check out my build log
http://www.yarisworld.com/forums/showthread.php?t=26458
Pioneer
Ascendant Audio
Sundown Audio
Knukoncepts
Fosgate
Stinger
Old 04-08-2010, 08:54 PM   #7
typicaljawaiian808
Put in a Fosgate fuse Block, and Fosgate Wire all around!!!
Pioneer
Ascendant Audio
Sundown Audio
Knukoncepts
Fosgate
Stinger
Old 04-08-2010, 08:59 PM   #8
YarisSedan
Drives: 08 Yaris Sedan
Looks good i plan to do this soon as well im too lazy though ive had the wires sitting in my closet for months
Old 04-09-2010, 02:49 AM   #9
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I know this may sound like a trollish question...but why in the name of all that is holy do you have the fuse on top of the engine cover? Did you just run out of wire? Stick that on the firewall...
― Thomas Paine
Old 04-09-2010, 03:22 AM   #10
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Maybe he'll redo it after he gets the Monster Alternator
Old 04-09-2010, 03:28 AM   #11
AND189
Drives: 2
thats some chunk cable mate
AND189 is offline   Reply With Quote
Old 04-14-2010, 12:03 AM   #12
typicaljawaiian808
this may sound like a trollish answer...but I kind of like it there.
Pioneer
Ascendant Audio
Sundown Audio
Knukoncepts
Fosgate
Stinger
Old 03-27-2012, 12:38 PM   #13
09sedan
Drives: 2009 yaris sedan
is the big 3 needed for a 300 watt mono amp? (just the one amp)
09sedan is offline   Reply With Quote
Old 03-27-2012, 01:35 PM   #14
_S7V7N_
_S7V7N_'s Avatar
It wouldn't hurt.
Basically if you have an extra 25 bucks go for it. Even then you could probably build your "Big 3" kit cheaper. 4 gauge wire would work or you can prepare for a bigger system and use 0 gauge.
Knu Konceptz KCA 4 gauge is rated @ 100 amps and is 95 cents a foot or check them out on ebay. I'll post where I ordered some wire from later on. And post some connectors.
Old 05-15-2012, 12:50 PM   #15
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
So, if I'm reading correctly, I can actually replace the stock cables, rather than add to them? Say I went with a low gauge (1-2) and took out the stock cables (alt->chassis/battery, battery->chassis, right?) and replaced it, that'd have the same effect, correct? Getting more info from the12volt.com, btw.
Old 05-15-2012, 01:47 PM   #16
_S7V7N_
_S7V7N_'s Avatar
Add don't replace. Your cpu won't like it if you replace
Old 05-15-2012, 03:15 PM   #17
LA Yaris
Yaris323
LA Yaris's Avatar
No if you do that it makes your yaris faster
Old 05-15-2012, 11:59 PM   #18
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
wow do want to be a jerk or just a loser? your post makes you look like both and more.
Colin Chapman disciple
The Big One upgrade fuji DIY / Maintenance / Service 2 02-15-2009 03:37 AM
So how do you like the BIG SMILE on the 07 Sedan???? Ziv General Yaris / Vitz Discussion 3 02-03-2006 12:12 PM
