Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 05-21-2012, 03:57 AM   #91
syntax
syntax's Avatar
hindi na active si armando aka pilyo sa YWME pre' halos lahat ng mga kayaris ay ganito ang setup including mine... kapag may time ka attend ka ng monthly meet natin, every 1st friday un, para makita mo meron din naka CAI sa mga kayaris...
Old 05-21-2012, 04:00 AM   #92
BoyMalambing
BoyMalambing's Avatar
Drives: Toyota Echo 2005
Ano po specs (size) ng Air Filter na to... may brand po ba definite??
This is my 1st first car in Saudi Arabia
BoyMalambing is offline   Reply With Quote
Old 05-21-2012, 04:01 AM   #93
BoyMalambing
@ Syntax, baka pwede mo naman ipakita yung sa iyo. ano size nung air filter, ano kailangan ko bilhin at saan ka bumili ng airfilter mo. TY
Old 05-21-2012, 04:29 AM   #94
syntax
syntax's Avatar
hirap i describe eh, yung specs nakalimutan ko na rin, attend ka na lang ng monthly meet dami makikita
Old 05-21-2012, 04:46 AM   #95
BoyMalambing
Photos will help... medyo malayo lang po kasi kaya di ako makababa....
Old 05-21-2012, 05:28 AM   #96
syntax
syntax's Avatar
cge try ko hanapin ang specs nun, sa pictures pareho lang nung nasa ibang kayaris, mag iiba yung sayo dahil echo yan..
Old 05-21-2012, 09:52 AM   #97
BoyMalambing
Thanks in advance sa specs at sa photo. Yung photo baka pwede yung medyo malapit from engine up to filter kasama yung mga joints, pano kinabit yung MAF sensor at yung isang pipe from Engine na maliit.
Old 05-22-2012, 05:09 AM   #98
BoyMalambing
@ Syntax, nakita ko na yung para sa Toyota Xa 2004 Scion na pwede gamitin sa Echo 2005. Same layout as you said. Papagawa na lang ako sa contractor namin ng Stainless steel pipe. Papagaya ko ito
http://www.trdparts4u.com/scripts/pr...dproduct=-7862
http://www.carid.com/2004-scion-xa-a...ke-360128.html
Old 05-22-2012, 09:26 AM   #99
syntax
syntax's Avatar
ayus yan pre' para sakin wag steel pre' kung pwede ang aluminum mas maganda
Old 05-23-2012, 02:39 AM   #100
BoyMalambing
Ay oo nga pla Aluminum... plan ko sana para mag ok, yung Rubber Tubing na misma nakakabit sa Intake tanggalin ko lang box tapos gamit ng mga clip(yun ba tawag doon)
Old 05-23-2012, 03:41 AM   #101
syntax
syntax's Avatar
yup.. ganun nga pre' basta kung ano ung nakakabit dapat sa OEM na intake meron din sa custom intake na gagawin mo...
Old 05-23-2012, 03:51 AM   #102
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
+100 hehehe, musta tol...
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 05-23-2012, 04:04 AM   #103
syntax
syntax's Avatar
@ duke ok naman pre' dami lang ginagawa dahil lam mo na..hehehehe, kaw pre musta na?
Old 05-23-2012, 04:23 AM   #104
BoyMalambing
Try ko maghanap muna ng Air Filter... saan ba nakakabili nito...
Old 05-23-2012, 04:28 AM   #105
syntax
syntax's Avatar
check mo sa ghurabi area pre' dun sa al aqsa, malapit ito sa alrajhi atm na malapit sa jollibee, sa kabilang side andun ung al aqsa, hanapin mo si roy, alam na nya kapag yarisworld member
Old 05-23-2012, 04:30 AM   #106
duke_afterdeath
ok lang tol kaso nga lang zero balance, hehehe...
d2 sa Riyadh tol madami nyan branded at generic nagkalat, hehehe...
Old 05-23-2012, 04:32 AM   #107
syntax
syntax's Avatar
@ duke buti nga ikaw zero balance.. ako negative pa nga eh wahhhhh...
Old 05-23-2012, 04:41 AM   #108
duke_afterdeath
Any Aftermarket Intakes Yet?!?!?!?! silverRS Performance Modifications 120 12-07-2011 06:44 PM
Weapon-r sheet metal intakes 1/2 off (almost) H3LlIoN Forced Induction Forum 5 11-27-2010 12:21 AM
aFe intakes in stock! cali yaris Micro Image 66 02-11-2010 04:58 PM
air intakes? SLIK4 General Yaris / Vitz Discussion 16 05-21-2007 09:34 PM
