View Poll Results: Which Rear Swaybar Woould You Buy?
Ultra Racing 19mm 2 6.25%
Ultra Racing 23MM 20 62.50%
Whiteline 10 31.25%
Voters: 32. You may not vote on this poll
Old 05-23-2012, 04:15 PM   #1
racerb
Which Rear Swaybar Would You Choose?
Just to see what the interest level is for options on rear swaybar. Choices being Ultra Racing 19mm, Ultra Racing 23mm, or the newer Whiteline unit.
Let's find out what you guys really want for your Yaris!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 05-23-2012, 06:47 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I chose the TRD sway bar because you can't see it...
It has a couple of extra bends which make it tuck neatly up into the fold of the crossmember so that nothing is hanging down below the chassis. I live in an area where having more ground clearance is good.
Old 05-23-2012, 11:23 PM   #3
g.q.vios
jqueza@microimage
g.q.vios's Avatar
Drives: 2010 vios
whiteline its ajustable........
g.q.vios is offline   Reply With Quote
Old 05-24-2012, 12:00 AM   #4
Calogero
Calogero's Avatar
Drives: Toyota Yaris
I have the TRD and it's good for street and first add on.
And you can Feel a difference.
But I would go with 23 mm now for street
And adjustable for more serious intentions.
Lead, Follow or get out of way.
Thomas Paine
Stage One Yaris
TRDsway bar, TRD springs & shocks, TRD
Quick shifter kit, TRD CAI, TRD oil & coolant cap
Microimage light crank pulley, Agency Power steel braided brake lines.
Calogero is offline   Reply With Quote
Old 05-24-2012, 12:25 AM   #5
Klink10
Klink10's Avatar
I have the TRD as the rest were not out at the time. It works for me so really no need to change.
Old 05-24-2012, 07:41 AM   #6
racerb
While I did not include the TRD bar, that is another option and with the current price Sparks Toyota TRD Parts has it listed for, it's pretty damn reasonable!
http://www.trdsparks.com/displaypart...&parts_id=1374
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 05-24-2012, 07:47 AM   #7
spocksleftball
spocksleftball's Avatar
Drives: 2011 yaris
I chose trd....not a vote option
spocksleftball is offline   Reply With Quote
Old 05-24-2012, 08:01 AM   #8
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I'm pretty sure TRD isn't on the list because the intent of this thread is to show Garm that there is still significant interest in the 23mm UR bar. There was talk of discontinuing the 23mm UR in favor of the adjustable 22mm Whiteline bar.
Old 05-24-2012, 09:05 AM   #9
racerb
Thank you, finally a voice of reason, that is exactly the purpose of this thread!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 05-24-2012, 09:36 AM   #10
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I got the 23mm ur
-Derrick-
Old 05-24-2012, 12:42 PM   #11
tooter
play every day
tooter's Avatar
racerb
Should have said that from the get go...
Old 05-24-2012, 12:49 PM   #12
racerb
Well us East Coast people think differently, usually don't have to make thing painfully clear to others!! LOL........
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 05-24-2012, 01:16 PM   #13
spocksleftball
Drives: 2011 yaris
I wanted the 23mm. Told the four bushing whitehouse was better, I chose to go trd. So...voice of reason having to spell it out for us stupid people, translate trd as a vote with my feet fo the lack of 23mm availability. Doi!
Old 05-24-2012, 01:36 PM   #14
What I did was ask if there was interest in the 23mm UR sway bar at the $200 price point. Because that's what it will be if we re-order it. (maybe a little less) --- racerb, pretty sure, said he'd be ok with that pricing level. I have an order pending, but let's see what you guys say in here. (I'll cross post this in your poll thread as well)
If you really want a UR 23mm sway bar right now, they are available on eBay.
The reason I'm pushing Whiteline is because they are motivated to work with us, offer great pricing, and there is ZERO downside to their product -- it's simply better!
Thanks everyone!
Old 05-24-2012, 02:36 PM   #15
richard_rsp
richard_rsp's Avatar
Drives: 2012 Yaris L 3Dr
Ok, good to know.
Just curious: what do you mean by better? Do you mean less body roll (as in more effective)? or Better quality (have you had issues with the UR)? or do you just mean better customer service?
The reason I ask is this: I had a Mazda2 with RacingBeat rear swaybar; it was not exactly the same setup, but was similar in that it had the "U" brackets that mounted over the beam. While it was VERY effective at keeping the car flat in autocross, I found it to be overkill for daily driving: I constantly had a wheel in the air when turning into driveways, and had to retighten the U-bolts several times to keep it tight against the beam.
Now it appears that the Whiteline does allow for some twist in the beam, which could help to eliminate the "doglegging" problem, however, I am still concerned about having to continually tighten the U-bolts. Also, have you had any issues with squeaking bushings? Eventually, my urethane bushings began squeaking and required removal/relubricating.
While this all may seem like minor maintenance (and it is), and I may seem lazy, its just that I see no need in buying a product that requires this type of maintenance if it is overkill for daily driving / occasional autocross when other options are "install and forget it".
Your input is greatly appreciated!
richard_rsp is offline   Reply With Quote
Old 05-24-2012, 04:38 PM   #16
Great questions.
When I mean "zero downside", I am including most of your concerns. No reports of noise, doglegging, or properly installed bolts/nuts coming loose from the several sway bars I've sold so far. I can only answer to this point in time, as I don't have a long history with Whiteline. Yet!
I'm going to switch on my own car and give some feedback from the track. I could make some predictions, but I think it's best not to do that.
Customer Service: Huge point, glad you brought it up. Problem or flaw with UR bar: it's 100% on me, I can't send it back to Malaysia or get a replacement, etc. I have to be real and start including that in my pricing.
Whiteline is here and 100% responsive to us. I can get parts, replacements, etc. and the shipping cost from the Malaysia to the USA doesn't have to be passed on to you guys.
Old 05-24-2012, 06:06 PM   #17
richard_rsp
Ok, thank you for your input, Garm.
I did not realize that UR is out of Malaysia.... thats a big minus in my book, and I can understand your concerns about service.
So that basically leaves two options: Whiteline or TRD.... Looks like I need to do some reading on owners opinions.
Old 05-24-2012, 06:33 PM   #18
racerb
Great questions.
Does this mean they carry a warranty? I have never been able to find a performance/racing part the carried a true warranty at least as far as re-place goes. The fine print usually indicates for off-road use only and no warranty if used for racing purposes. Can you let us know what is covered and what limitations are specified.
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 05:48 PM
Removing Rear Seat bronsin DIY / Maintenance / Service 4 04-11-2011 03:34 PM
