Old 03-20-2007, 09:00 PM   #19
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Originally Posted by Moose View Post
Although I'm all about the aftermarket short-shifter, I'm not too enthuised about the whole stainless-steel-bushings-thing. I would much rather see a nice urethane set from Energy Suspension. I can imagine, since the steel bushings have NO play, that there could be negative side effects from using them. You should have a little play in the shifter- the rubber bushings, besides just insulating noise and vibration, keep you, the idiot human, from bending your shift forks and linkages when your shift angle is just a little off.
Just a thought.
I agree. I really doubt they would actually make them out of steel though.
Old 03-20-2007, 11:06 PM   #20
Just a thought.
I'm not so sure it's a big concern with this car, if you look at the way the shifter system is assembled, the only connection between the shifter and the gearbox itself are two rods that go only backward and forward, there should not be any need for any play since there's no way to really mess up your shift.
TWM also has some aluminium replacement bushings.
Old 03-20-2007, 11:44 PM   #21
ChinoCharles
Drives: LB
TWM's bushings are for the cage. They are not for the tranny-side linkage. This is why I am so excited that these may be produced. It is uncharted territory, and that we don't want.
With stainless steel bushings, there is no play, so there are drawbacks. You will feel the road through your shifter. Some will say that for a daily driver it is pointless or annoying, but I personally like as much input from my car as possible. It helps you make decisions. The electronic power steering is already robbing you of that effect to a degree. Control is increased, but as Moose mentioned it comes at the price of risking long-term damage. If you're not an experienced stick driver, you may want to wait until you're good and comfortable before moving to steel bushings. If this isn't your first date with a clutch, however, you'll probably enjoy the sensation of actually feeling yourself sinking into gear.
Old 03-21-2007, 01:14 AM   #22
aaaah i see, my bad there
most interesting, then....
Old 04-10-2007, 11:13 AM   #23
ChinoCharles
Drives: LB
OK. This is it folks. Cat is out of the bag... I hope I don't get yelled at for posting this, but it can now be found through the main web site, so I don't think I am sworn to secrecy anymore.
http://www.nonstoptuning.com/ProductsDrivetrain.htm
'Nuff said. NST FTW!!!
Old 04-10-2007, 11:17 AM   #24
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
The Million Dollar Question is still on the Table...
WILL IT WORK WITH TWM's KIT?
Nutzoids is offline   Reply With Quote
Old 04-10-2007, 11:19 AM   #25
ChinoCharles
Drives: LB
IT WILL! Your throws would be so short its insane!
The Two Million Dollar Question then...
When is it "too short?"
Old 04-10-2007, 11:23 AM   #26
Nutzoids
Nutzoids's Avatar
When your girlfriend says...
"It's OK dear... I was sleepy anyway!"
Old 04-10-2007, 11:24 AM   #27
ChinoCharles
Drives: LB
Oh jeez...
Old 04-10-2007, 11:26 AM   #28
Black Yaris
der Zeck
Black Yaris's Avatar
what about the "TRD style" short throw, with our modified shifters? how short do you think those will be?
Old 04-10-2007, 11:28 AM   #29
ChinoCharles
Drives: LB
I have a modified shifter and I'll likely be testing this new short shifter (which is tranny side) so I will let you guys know just how short it is.
Old 04-10-2007, 11:32 AM   #30
my only concern, after installing the TWM one, is that if it is combined with the TRD/CC shifter, it's going to be much too hard to push the lever into gear, there's already a lot of resistance.
But, wait and see
Old 04-10-2007, 10:14 PM   #31
acrbill
Drives: Polar White Hatch
Are you saying that the NST short shifter is on the tranny side?
Back in my Neon days we used to have a mod where we moved the pivot point on the gear selector arm in about an inch. That eventually evolved into someone making a new arm. I did that mod along with a true short shifter and holy crap where the shifts short. I think it was 2.5" total forward back motion.
I will however say this. I had urethane bushings on the shift cables and they made shifting quickly difficult. I ended up putting the stock bushings back on the shifter side and leaving the aftermarkets on the tranny side and that helped a ton.
A short shifter is a mod you can enjoy dozens of times a day.
http://home.comcast.net/~job0b/ywsig.gif
ChinoCharles Intake supporter.
acrbill is offline   Reply With Quote
Old 04-11-2007, 01:54 AM   #32
ChinoCharles
Drives: LB
It is tranny side. I think if bushings were made they'd be stainless steel.
Old 04-11-2007, 02:28 PM   #33
YarisGuy
Drives: 2006 Yaris
If not more
YarisGuy is offline   Reply With Quote
Old 04-13-2007, 12:49 AM   #34
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
ey charles, any update on the shifter combo? thanx man!
barebonedvitz is offline   Reply With Quote
Old 04-15-2007, 11:13 AM   #35
graywolf_14
Drives: um not a yaris but hopefully
ok as in tranny side u mean it is just bushings on the tranny? Ok and when u get the trd shifter and is installed is there something to tell people it is trd? Does it come with a shiftknob or sticker or something?
graywolf_14 is offline   Reply With Quote
Old 04-15-2007, 11:22 AM   #36
I think a sticker's included with the TRD one...
Chino, will you want any CCRD stickers?
twm short shifter installed! dngz Performance Modifications 115 08-02-2007 01:11 PM
TWM Short Shifter Boxing Week Blowout! TWM Performance Sponsors Classifieds Area 2 01-08-2007 04:01 PM
November: Big Yaris Short Shifter Sale! TWM Performance Sponsors Classifieds Area 14 12-12-2006 10:50 AM
TWM Yaris Short Shifter Sale! TWM Performance Sponsors Classifieds Area 9 08-28-2006 03:37 PM
Custom short shifter ChinoCharles Performance Modifications 13 08-20-2006 03:52 PM
