#343 |
![]() ![]() ![]() Drives: 2007 Yaris Hatch Join Date: Feb 2007
You need fluidfilm.
#344 | |
D.
. CLA 250, 4MATIC |
#345 |
![]() Drives: 2007 Yaris Join Date: Jun 2012
I am having this same issue- ABS and Parking Brake Lights both on- it comes and goes.
My question is: Do the fault codes get stored after the ABS and PBL go out? Can you only get the fault codes when the lights are on? |
#346 |
Drives: 2008 Yaris Join Date: Jul 2012
ABS and brake lights are on
It's disturbing to read all of the comments from owners of the Yaris regarding the ABS sensor issue. I have a 2008 Yaris and started having this problem in the spring. The service shop said that this is a common problem but there is no recall. The cost for repair is in the $700 range.
I called Toyota Canada and all they could say was that it's "unfortunate". They also gave me the impression that there was not a systemic problem. I would say that this website indicates otherwise. I'm posting this issue here to let others know that the problem still exists and Toyota is ignoring it. This is obviously a design/manufacturer problem and the consumer should not have to pay for this costly repair. Keep speaking out against the issue and make sure that Toyota hears about it! |
#347 |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Just an FYI if you have this problem and try and sell your car, it will NOT pass a safety (in Ontario).
I am selling it to my brother and the garage said because the (!) was on as well as the (ABS) it would not pass (which I think is complete BS, but any way) - the mech even admitted there was nothing wrong with the car just because the actual light was on it would not pass. This is completely unacceptable. |
#348 |
![]() Drives: 2006 hatch Join Date: Nov 2011
Thanks for the info everyone. I read most of the thread. My wife's Yaris had this happen once while under warranty, took them 2 tries to fix it. It came back in the spring when we were taking the snows off. The back left was rusted and really stuck, we had to beat it off with a hammer. After that, the ABS and (!) lights were on. I used an OBD reader and said it was the rear left speed sensor, something that we were afraid of since the first time, we were warned that it was something that seemed to be happening frequently. I reset the code but obviously it came right back.
I was going to just buy a new sensor until I read the thread. Thanks to you guys, I didn't do that, and from the pictures, I realized I didn't even need to take the wheel off. I got under it and pulled the connection, and I could see a bit of blue corrosion on the wire. I couldn't see inside the port on the sensor. I cleaned it up a bit and blasted it with contact cleaner, and it cleared after driving it a hundred yards or so. I'll get some dielectric grease and put it on both sides to protect it. |
#349 |
#yyc
Drives: BSP '07 RS 5dr LB Join Date: Aug 2011
Put the Yaris into winter mode today, and greased up the connectors using this stuff:
![]() Before shot: ![]() Thankfully no corrosion (yet). |
#350 |
Drives: Vitz 2007 Join Date: Dec 2010
Hi, I have a 2007 2nd Generation hatchback Vitz from Japan. The abs light is on and i have read that it might be a problem with the sensors. Where are the sensors please, front or back wheels?
Thanks a lot. |
#351 |
#yyc
Rear hubs
#352 |
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
I am having the ABS and Emerg Brake light problem. My car has about 170,000 km on it .. and does have ECP extended warranty (the previous owner paid a couple of thousand dollars for this warranty coverage) for another 9 months. Does anyone know if this problem would be fixed under warranty ?
Of course .. the problem has gone away. The lights have gone off .... and speaking to the previous owner it is not uncommon for this problem to appear when the roads are messy, and for the problem to go away for months at a time. *edit* I spoke to the dealer and they didn't want me to bring my car in .. as the lights have turned off and when they hook the computer up to it, nothing will be shown. So .. they said they won't know if it is the right or left side that is causing the problem. Well .. I don't know but for me checking both sides for corrosion would be a good game plan. But I am not them .. and well I cannot tell them what to do. Last edited by edmscan; 01-21-2013 at 04:00 PM. Reason: Updated |
#353 |
![]() Drives: 2008 yaris Join Date: Feb 2011
When I opened mine you could easily see corrosion and I am sure they could also. Luckily the trick of cleaning with circuit cleaner and then packing it with dioelectric grease worked perfect, and now I have traded that car back to Toyota and bought a Corrola.
#354 |
It seems that my car cannot make up its mind what it wants to do. Some days .. the ABS/Emerg light is on and other days it doesn't show its face. I will just ignore it I guess .. and see how that works out.
#355 |
It'll just get worse and worse. The fix is so easy, why ignore it?
#356 |
I am not a car guy. I know how to check my oil .. and that's about it. So .. fixing it will be something that I may get the dealer to do. But the dang lights won't stay on, so the dealer won't touch it.
#357 |
from the sounds of it your sensor is at the point where there is some corrosion but the pins are still intact and no serious damage has been done. it may get to the point where the only thing possible to do is to replace which is much more $$$
#358 |
![]() ![]() Drives: 2007 Yaris Sedan Join Date: Oct 2008
^^^ I agree with this.
edmscan, you really should take a look at it while you still have time to protect the connection before it's completely corroded apart. All you have to do is clean the salt spray and sand off the connector, and then seal it back up with dielectric grease. It takes no more than 10 minutes and will save you all kinds of headaches. The dealer will charge you for an hour's labour, so that'll be $90-110 for a very simple task. Take a look at this pic for what the sensor looks like: http://www.yarisworld.com/forums/sho...&postcount=232 |
#359 |
thought they didnt use salt out there?
#360 |
![]() Drives: Orange Yaris Hatchback Join Date: Feb 2012
The ABS and brake light appeared today not impressed. I retrieved the code and it was 33 for right rear sensor. Pulled the rear wheels off to get better access. Took a while to get the electrical connector off the back of the sensor. I ended up using a medium cotter key split in half. I put it in the lower part of the connector and turned while pulling on the connector towards the center of the car. Blew my mind when I got it off this plug has no rubber seal of weather proofing at all WTF... I dried them both out with a hair dryer and filled them with vasoline. Drove it down the street and BOOM!! it's fixed. When it's not -14 out I will rig up some boots to cover the connectors. They should at lease supply us with some rubber boots that can be slipped over these connectors to prevent the moisture.
