Old 06-14-2012, 12:02 PM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Intrest in a sedan center exhaust rear section?
I can produce them if wanted...or just about anything else using my car as a jig. Ive done it before i can again. I an do mild or loud options all in 409ss to match the factory exhaust.
Next week i may swap my stock exhaust back on and whip up a center rear section to see what its going to take.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 06-14-2012, 12:53 PM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
headerback to match up to a dc header?
Old 06-14-2012, 01:25 PM   #3
baseballfan416
Drives: 2017 L 3-door
I'd be more interested in a legitimate header back exhaust option. Seems pointless to have header and axle back when the mid pipe is somewhat restrictive... Kinda wishing I had a hatch merely for that reason.
baseballfan416 is offline   Reply With Quote
Old 06-14-2012, 11:10 PM   #4
malibuguy
Obsessed with 1.5L
Its doable...just a little more complicated to produce. And i would not be able to sell that to california residents b/c emissions
-96 Tercel 4dr
Old 06-14-2012, 11:14 PM   #5
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Come on, malibu...
If California can produce and sell $14,000,000,000 worth of pot every year, you can certainly sell one little exhaust.
Old 06-14-2012, 11:19 PM   #6
malibuguy
Obsessed with 1.5L
We cant even ship our cats there anymore or we face hoooge fines.
Axle-backs are not a problem however ;)
-96 Tercel 4dr
Old 06-14-2012, 11:44 PM   #7
tooter
play every day
tooter's Avatar
Wow... car exhausts are illegal contraband?
Sorry, didn't know it was that bad.
I'll be glad when the government
goes bankrupt like Greece.
Old 06-15-2012, 04:00 PM   #8
ViosFan
How much do you think an axle back would cost? I wouldn't mind it being loud as long as it has a nice low rumble to it.
ViosFan is offline   Reply With Quote
Old 06-15-2012, 05:31 PM   #9
car exhausts are illegal contraband? Sorry, didn't know it was that bad.
I don't think it is. Megan is making a midpipe for us for the liftback, that is 100% legal to sell, and Megan Racing is located in SoCal.
However, it is "for show and offroad use only" and must be clearly marked and marketed as such.
malibuguy, can't you do the same thing?
Old 06-17-2012, 03:47 PM   #10
malibuguy
Obsessed with 1.5L
We just cant. Even summit racing cant sell cats to california.
Pricing i would predict in the 250-350range plus shipping. Ill try to make a loud one this week to test it out
-96 Tercel 4dr
Old 06-24-2012, 12:05 PM   #11
malibuguy
Obsessed with 1.5L
I put the car on the lift the other day to start planning...
There is no easy convienent way to hang the center exhaust without drilling.
However...dual tailpipes (one on each side) is very doable as there is threaded bolt holes in the frame rail on the driver side. I think im going to make duals one day just for the hell of it....
-96 Tercel 4dr
Old 06-24-2012, 12:45 PM   #12
SAV912
Pirate Yaaaaris
SAV912's Avatar
Wouldn't that make it easy enough to route pipes and hang them from the edges but not exit the car on the edges? Can't they be run from the edges to the middle without a hangar in the middle or is that too much pipe to have unsuspended?
Don't know for sure because I have a liftback. Just thinking out loud.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 06-24-2012, 03:04 PM   #13
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
I am interested !
Interior:ALL red, black roof
Old 06-24-2012, 05:03 PM   #14
packetrace
packetrace's Avatar
if you do a cat back...make it so we can bolt the cat to axle section to an other axle-back system :)
Old 06-26-2012, 10:04 PM   #15
malibuguy
Obsessed with 1.5L
The only downsidento doing a cat back like that. Is that i would have to reduce the tubing to a smaller size to make an oem replica connection to allow maximum flexablilty. Really a bunch of work to work backwards.
Ideally an exhaust needs support every 3-5ft of pipe and just about every direction change. Without easy convienent holes to support a center exit pretty much kills my idea of a production run. Im not saying it cant be done. Im just not drilling extra holes in my car.
-96 Tercel 4dr
Old 06-27-2012, 12:52 AM   #16
tooter
play every day
tooter's Avatar
I share your aversion for drilling on a vehicle. It's not worth the loss of strength and the hightened likelyhood of rust. I did have to drill one tiny hole for mine, and made sure it was in a noncritical area.
When I think of a dual conversion for a Yaris, this design seems to make some sense as long as the muffler is small and nothing hot is near the brain.
Old 06-27-2012, 12:58 AM   #17
That made me think of the ECU, which is just a few inches from the exhaust header.
Old 06-27-2012, 01:28 AM   #18
tooter
play every day
tooter's Avatar
Hey, you're right! I didn't even think of that.
I was thinking of that big plastic looking box underneath the rear. Is that also electronic?
Micro Image center exhaust... tooter Performance Modifications 64 10-14-2012 11:07 PM
