Old 07-17-2012, 01:31 AM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
squeaking noise after starting car
when i start my car in the morning, it squeaks from the front for like 4-5 seconds, then it goes away. I have done some research on this forum, it seems to be the belt, but what is the belt actually called?
i have never heard this noise before, until recently for the past week. My car is at 121,000km (75180 miles), had the alernator changed at dealership 2 years ago.
any idea?
Old 07-17-2012, 01:38 AM   #2
Lux
Lux's Avatar
Drives: NCP91
It is the accessory belt. Americans call it the serpentine belt. The noise is a symptom of the belt losing friction from drying up and cracking or simply losing tension from age. Have a technician replace the belt. He should be able to do it in less than 0.5 hours labour if he is competent. From experience, I'd recommend using a genuine Toyota belt for your car.
Lux is offline   Reply With Quote
Old 07-17-2012, 01:41 AM   #3
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Originally Posted by Lux View Post
It is the accessory belt. Americans call it the serpentine belt. The noise is a symptom of the belt losing friction drying up and cracking or simply losing tension from age. Have a technician replace the belt. He should be able to do it in less than 0.5 hours labour if he is competent.
Everything he said was spot on, but I would suggest swapping it out yourself. Should only take you 10 minutes time and it's pretty easy to do.
Better to buy the belt for $10 and do it yourself, versus having a mechanic charge you upwards of $100 to do it for you.
Old 07-17-2012, 03:10 AM   #4
caineroad
caineroad's Avatar
Thanks! Will buy the belt tomorrow and do a little DIY.
Old 07-17-2012, 05:44 PM   #5
RedRide
RedRide's Avatar
Yes, it is the belt.
One word of caution..... since the Yaris does not have an automatic belt tensioner, be careful you do not over tighten the belt which could make the accessoriries bearings fail.
Old 07-17-2012, 06:17 PM   #6
caineroad
caineroad's Avatar
I will mark on the bolt.
It is $35 here to buy a belt, what the hell!
Old 07-17-2012, 09:36 PM   #7
RedRide
RedRide's Avatar
That wiil not work as the new belt will not be exactly the same size as the old one.
Old 07-17-2012, 10:15 PM   #8
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
He's 100% correct! I learned that the hard way when I installed my lightweight pulley a few weeks ago. It's helpful to have the bracket marked as a guide... but base it on belt tension, not the mark you put on the bracket.
Here's a video I looked at when I was "teaching myself" how to do it. Some good information...
Eric the Car Guy: Replacing a Serpentine Belt
rubber rubbing noise from front right of car Golddeenoh DIY / Maintenance / Service 5 06-07-2012 07:14 PM
What Car Mechanics Don't Want You to Know!! daddz07 DIY / Maintenance / Service 16 04-17-2011 11:10 PM
Strange noise coming from left door of car daibatzu General Yaris / Vitz Discussion 3 11-19-2010 10:58 AM
Noise when first starting car and turning steering wheel kaileeg DIY / Maintenance / Service 0 11-15-2010 05:51 PM
Custom Lftback - Photo-Scavenger Hunt custom Lftback Photo-Video-Media Gallery 2 03-02-2009 12:12 AM
