Old 06-30-2012, 09:59 PM   #523
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
i think pimp had cut his off so he could upgrade his injectors easier.
http://www.yarisworld.com/forums/sho...&postcount=406
Old 07-05-2012, 05:48 PM   #524
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
Garm
The black thing comin out of the regulator is for te gauge ?
What is the regulator brand ?
Interior:ALL red, black roof
Old 07-05-2012, 06:30 PM   #525
The two inlet ports are tapped with a 9/16-18 thread. The fuel pressure gauge port is tapped with a 1/8-27 NPT.
The outlet port is located at the bottom of the fuel pressure regulator. It has a 9/16”-18 thread.
Connect the vacuum hose to the top of the fuel pressure regulator. (Hose size is a 3/16” or 5mm)
I use the AEM regulator, in stock (black).
Here is AEM's page and PDF for it:
http://www.aemelectronics.com/univer...-regulator-338
http://www.aemelectronics.com/Images...s%2025-302.pdf
Old 07-05-2012, 06:56 PM   #526
packetrace
packetrace's Avatar
Definetely going to pick up one...VERY SOON....at the same time fuel rail....and 2 gauge :)
Old 07-05-2012, 07:19 PM   #527
packetrace
packetrace's Avatar
Where is the outlet of the rail going ? and where is the little black thing that comes out of the regulator going ?
Old 07-05-2012, 07:28 PM   #528
Jeff@MicroImage
"Know it all"
Jeff@MicroImage's Avatar
Drives: Lancia Delta Integrale
Fuel is being returned to the tank using the original fuel feed line (reverse direction). It's recommended to run the fuel return line when turbo, not needed on a N/A car an you can simply plug the unused end of the fuel rail.
Black hose is going to manifold vacuum/boost, FPR is rising rate based on boost, the more boost it sees the higher fuel pressure gets.
www.microimageonline.com
Jeff@MicroImage is offline   Reply With Quote
Old 07-05-2012, 07:34 PM   #529
The bottom of the regulator is the return line/outlet, the left is the feed from the rail, and to the right is the gauge.
Old 07-05-2012, 10:40 PM   #530
packetrace
packetrace's Avatar
not quite sure tu understand...
I understand the boost inlet...
The left side of the rail(passenger side) goes to the stock feed line as I will turbo...
The right side of the rail go to the regulator obviously...
Where is the FEED...I dont understand how the fuel can come from the fuel tank if we use the feed line as return line now...
Old 07-06-2012, 06:46 AM   #531
packetrace
packetrace's Avatar
I got it I think!!
Fuel rail is feeded from the left(passenger), then it passes trought the fuel rail....then in the regulator...and THEN it goes to the stock feed line which is now return (bottom of the reulator)...
Gauge on the right side of the regulator
Black hose iandor vaccum boost
Now....to mke the completely new feed line....i make hose from the fuel rail and the fuel pump ?
Old 07-06-2012, 11:54 AM   #532
Yes -- A new fuel line from the pump to the rail if you include the direction of flow, but yeah. My last post in here on this -- we totally jacked the thread. SORRY PIMP
Old 07-08-2012, 03:55 PM   #533
packetrace
packetrace's Avatar
Just read the wholleee thread!!! lollll
will get my engine next week cant wait to start it :D love YW and MI :D
Old 07-20-2012, 07:44 PM   #534
hey what happened to pimp??
Old 07-20-2012, 08:22 PM   #535
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
he has been pretty busy with work and stuff lately.
Old 07-21-2012, 10:47 AM   #536
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Im here. I have almost all the fittings, filter, pump and lines I need. I need just a couple more fittings. Just piecing it all together before tear down. I dont want my car down any longer then necessary.
pimp my yaris is offline   Reply With Quote
Old 08-04-2012, 08:04 AM   #537
packetrace
packetrace's Avatar
Any update :D
Old 08-04-2012, 09:15 PM   #538
pimp my yaris
C'est la vie
Did some test fitting today. I will need to cut off part of the head casting to clear the -6 fitting. Also the resistor bolted to the head on the left side of the stock fuel rail needs to be moved for clearance.
Old 08-04-2012, 09:18 PM   #539
pimp my yaris
C'est la vie
On all previous posts I was able to upload pics from my Iphone without resizing them. That is no longer possible. What a pain in the ass. Photobuckt.com moves beyond slow.
Old 08-04-2012, 11:48 PM   #540
packetrace
packetrace's Avatar
did you used stock spacer ? what injectors you have ?
looks great man!
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 03:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 03:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 02:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 03:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 03:10 PM
