#19 | |
play every day
#20 |
0-60 in slow
The only thing I've noticed that really kills fuel economy in these cars is driving to fast ie faster than 75 mph. I've done a few sub 26 mpg tanks but it's always been from driving 90+ mph for long stretches of driving. Being the car has 30k miles on it I doubt anything mechanical or electrical is wrong with the car a bad filter can reduce mileage but you would need a crazy blockage in flow for it to be bad. I'm willing to bet its due to driving style ie flooring it driving through traffic or crusing at 85 mpg on the freeway or having to drive through the mountains things like that.
#21 |
You are way off the mark xnamerxx
plus there aren't any mountains where the OP lives. Hell, there are hardly any hills.
#22 | |
![]() ![]() ![]() Drives: 2008 5 Door Liftback Auto Join Date: Oct 2011
But generally it's a good point.
1999 Honda Prelude Base 5 speed (summer driver) 2008 5 Door Liftback Auto |
#23 |
The second I hit the AC button, I'm losing 10mpg. I can see this on my SGII.
#24 | |
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
I know this may be boring .... but there are websites like www.Fuelly.com which will make this much easier for you. You only have to enter your KM and LITRES .. and it will calculate your mileage for you. It will allow you to use L/100 Km or Imperial MPG or US MPG whatever your preference is. Have fun. |
#25 |
^ it's not hard without fuelly.com...just a quick calculation before I pull away from the station which I do every time. And I do operate in L/100 km, I only convert to US mpg when I post here so it's easy for the majority of folks on this site.
10L/100km is exactly what I got last time and about 8 before that. Imperial MPG is basically an irrelevant unit...
#26 |
^ is that by calculation after a fill up?
#27 |
that's ok, I just wanted to make sure it's not based on obd data.
I dunno, 45mpg=5.22 L/100 km with 2 adults in a car and ac. I dunno...I never got more than 34 mpg from this car even when I was doing highway commute. Nowdays, with all city my average realistic mileage is around 28 mpg summer and winter. There's a window of couple of months late spring/early summer when it's not to hot and humid and then I might get 31. All maintenance is very up to date. On the other hand my mom's Mazda 5's last tank was 18 mpg. She is also all city, very similar driving patterns, but no occupants and a heavier foot than me. In colder and less humid summer weather she gets about 21.
#28 | |
#29 | |
#30 |
Weather cooled down, ac is now used significantly less. 27 mpg this time. Better, but still not great. I used to get about that mileage during last winter and same driving patterns.
#31 |
Are you using cheap gas, and is it possible that the gas station you're filling up in is still, some how, using winter blend gas (worse gas mileage with winter blend, even worse if using cheap gas).
#32 |
^ highly unlikely. I use Petro Canada which is one of the major brands around here.
I am not even sure you can get 'cheap gas' around here, it's all major brands everywhere.
#33 |
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
Maybe try switching to Shell if there's one close by for a couple of tanks, see if that helps..I haven't really heard many good things about Petro, other than Petro Points. lol.
Also, you said tires are inflated properly...try taking them up to around 40 if you feel comfortable. I've been running between 40-44 on all 4 tires with good results. |
#34 |
Not really sure then. Check your wheel alignment and increase your tire psi. I'm constantly running at 49-51 COLD psi without a problem (sidewall tire psi rating is for cold psi, I believe).
#35 |
alignment is in green..the rear right toe is real close to the limit (still green though)...Don't like over-inflating, the ride is too harsh as is.
#36 |
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
maybe your driving in 3rd gear
| Save thousands and BIG MPG almost PRIUS | jay cobbs | New YARIS Purchase Forum | 6 | 08-28-2012 09:38 PM |
| Why sub-compacts and compacts get almost the same MPG | Kal-El | Off-topic / Other Cars / Everything else Discussions | 0 | 08-11-2011 12:51 AM |
| 3000 mi Summer Trip Log...MPG included! | slothman86 | Fuel Economy Forum | 14 | 07-20-2010 01:15 PM |
| Better MPG in the City vs. Hwy | Loren | Fuel Economy Forum | 21 | 01-29-2010 12:49 PM |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 07:31 PM |
