Old 04-27-2012, 09:49 PM   #37
auxmike
auxmike's Avatar
Isn't this Canada only? My hatch. Vin doesn't even have a letter B in it!
Old 04-28-2012, 04:24 AM   #38
enviri
enviri's Avatar
Drives: 2010 Yaris
I had this done last year. I had that knocking sensation for a few weeks and they swapped bolts no problem. It happens.
Old 04-28-2012, 09:32 PM   #39
Firefly
Drives: 2010 yaris 3dr red AT
im from the chicago land area and we get lots of salt
i bought a small tub of axle grease and greased all of the hardware and lines /fittings /threads/cotter pins and ABS sensors with a small brush
i also bought a 1 gallon chemical sprayer and a gallon of crisco veg shortening heated it up in some boiling watter and sprayed every inch of the underside of the car and the bottom foot of the doors (except the hatch) il use babby oil or wd40 on that
im also going to respray/grease the car this fall but with non hyd vegie oil like i did my 02 saturn
i love seeing all the rusted out early to mid 2000 fullsize trucks (i guesse thay catch my eye first in northern MI)and knowing that an 8$ sprayer and a gallon of vegy oil every fall mabey a can of red spray grease would have saved the wheel arches and rocker panels from rusting
Firefly is offline   Reply With Quote
Old 05-03-2012, 04:02 PM   #40
djb
Drives: 2006 hatch
So it's safe to take these bolts out (one at a time) and eyeball the shafts? I don't think you can tell much just from looking at the heads.
At 125000km, my wife's 07 is long out of warranty.
djb is offline   Reply With Quote
Old 05-03-2012, 07:12 PM   #41
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
I didn't even take the bolts out. I just checked the bottom and the heads seem OK.
I am WAY out of warranty too (pushing 250,000km).
devinlamothe is offline   Reply With Quote
Old 07-23-2012, 03:02 PM   #42
sex
sex's Avatar
Drives: 09 5DR
55k miles on my hatch. Replaced both sides. Rusty on the drivers-side. Pics attached of driver-side old vs new, and passenger-side old vs new.
sex is offline   Reply With Quote
Old 07-23-2012, 04:24 PM   #43
I keep meaning to replace mine on all three of my Yaris, but keep forgetting to order them when I order other parts.
Old 07-23-2012, 11:01 PM   #44
auxmike
auxmike's Avatar
Anyone have the part numbers? What's the torque spec on them?
Old 07-23-2012, 11:37 PM   #45
90119-14126 (They are about $4 each)
Torque is: 118 ft lbs.
Old 07-23-2012, 11:43 PM   #46
auxmike
auxmike's Avatar
Great! And 4 are required?
Old 07-24-2012, 01:08 AM   #47
sex
sex's Avatar
Drives: 09 5DR
Two. I spray-painted the underside of the head and washer in hopes that'll slow down the rust. My guess is the bushing traps water between the crossmember and washer causing the bolt to rust through. I changed mine without lifting the car. Very easy to do
Old 07-24-2012, 12:24 PM   #48
Hershey
Ramps ?
Old 07-24-2012, 12:55 PM   #49
Billiam
Drives: '10 White Yaris 4D LB
I pulled mine out about a year ago and they looked fine. I coated them in high temp bearing grease and reinstalled them. I figure that couldn't hurt. Next time I do an oil change I might take another look at 'em to see how they've done bathed in grease.
If you want to enjoy your car, stay off of the internet.
Old 07-24-2012, 01:29 PM   #50
otterhere
Drives: 2008 Yaris 3-door Meteorite
Gee, I'd been wondering whether or not to replace my 2008 Yaris hatch, VIN JTDJT923, etc.; this must be a sign...................... I don't see how to get a FREE carfax report on my vehicle; they want $39 for one? I'll just check my car's paperwork to see if it's ok.
otterhere is offline   Reply With Quote
Old 07-24-2012, 02:09 PM   #51
sex
sex's Avatar
Drives: 09 5DR
No ramps for me, car is stock height. auxmike has some pretty good pics at the beginning of this thread showing the bolts
Old 07-24-2012, 03:42 PM   #52
Hershey
How'd you fit and work under it w/o ramps ? You be an X-man ? Slim Jim man .
Old 07-24-2012, 05:21 PM   #53
otterhere
Ya'll are a bunch o'mechanics on here! I'm just a girl; someone tell me if my VIN is safe.
Old 07-24-2012, 07:01 PM   #54
You need to list two more digits.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
