Old 07-25-2012, 11:09 AM   #1
bigdoglover
Drives: 2007 red lb
power door lock problem
hi guys, my 07 hb power door locks just started giving me problems. i can lock the doors but it will not unlock them. its not hard to reach over and unlock the passenger side door but the hatch is a pain to always have to use the key to unlock. is this difficult to fix? is this going to cost me a lot of money if i bring it in to a shop? thanks guys
bigdoglover is offline   Reply With Quote
Old 07-25-2012, 11:20 AM   #2
Do you hear sound from any of the locks when you press the unlock switch?
Old 07-25-2012, 02:53 PM   #3
bigdoglover
Drives: 2007 red lb
no
Old 07-25-2012, 03:50 PM   #4
OK. In that case, I would think that either the "unlock detection switch" is stuck on one of the three lock assemblies or that the main body ECU has a bad driver for the unlock mode.
You can test the first by unplugging each of the lock connectors to see if the problem goes away when one is unplugged. If the problem doesn't go away with one of the three, then the next step would be to check the output from the body ECU to verify that it is not driving in the unlock direction. If that is the case, then the entire unit would have to be replaced.
Old 07-26-2012, 07:33 AM   #5
bigdoglover
Drives: 2007 red lb
thanks
Old 07-28-2012, 12:22 PM   #6
bigdoglover
Drives: 2007 red lb
update,got into the car and remembered the power door lock between the front seats so i tried it, they worked. so i thought this is great now i can open it and not bother trying to fix the darn thing. gets better, i then tried the power lock on the door panel and it now works too! don't know if it was just stuck or what but my problem is solved. thanks for the help anyway
Old 07-28-2012, 01:08 PM   #7
Excellent! The center switch was probably just stuck, locking out the unlock.
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
aftermarket power lock problem mauiyaris In Car Entertainment + Electronics (audio / video / alarm) 17 08-24-2010 02:40 PM
Power Lock button?? cyberfrogg DIY / Maintenance / Service 25 03-26-2009 10:16 PM
Power Enterprise Super Charger Kit Round 2 $3100 Power Enterprise Evan Forced Induction Forum 312 03-26-2009 06:48 PM
