Old 08-05-2012, 12:07 PM   #541
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
what is the model of your fuel regulator ? did it came with fittings male-male or you had to buy some ?
Interior:ALL red, black roof
Old 08-05-2012, 04:33 PM   #542
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
AEM Part Number 25-302BK they do not come with fittings. im sure Garm will have them in stock.
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 08-05-2012, 06:25 PM   #543
^ Thanks, we do, and the gauges too.
Old 08-05-2012, 08:18 PM   #544
packetrace
packetrace's Avatar
Good i will call uou or jeff next week!:)
Do you have them in red the regulator ?
Old 08-05-2012, 08:47 PM   #545
I'll check, I know I have black for sure.
Old 08-06-2012, 09:00 AM   #546
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
I am using a Aeromotive regulator and it did not come with any fittings. The stock rail spacers look like they will work good. I am using Scion TC/Camry injectors from a 2AZ-FE engine. For now. Will upgrade to some 550cc denso injectors later.
pimp my yaris is offline   Reply With Quote
Old 08-06-2012, 11:04 PM   #547
pimp my yaris
C'est la vie
More progress.
Old 08-06-2012, 11:18 PM   #548
packetrace
packetrace's Avatar
Cooll man thanks for pictures! Inlike the way you place the regulator! Might copy it :$
Post pics if where you run the hose to the tank :)
Old 08-08-2012, 12:27 AM   #549
pimp my yaris
C'est la vie
daily updates
Old 08-08-2012, 01:52 AM   #550
way to go!
Old 08-08-2012, 02:12 AM   #551
scioncrew
scioncrew's Avatar
Drives: SCION tC
what dose it look like when you compress it all the way down. make sure it dosent kink.
Old 08-08-2012, 09:05 PM   #552
packetrace
packetrace's Avatar
post pics of when its compressed :)
where did you ran the 6an new feed line.. ? where can i reach the pump assembly ? under passenger seat ?
Old 08-08-2012, 11:59 PM   #553
pimp my yaris
C'est la vie
The pump is under the rear seat under a silver piece of sheet metal. I did shorten the line to the pump a little. That pic was not the final assembly. The line will run under the car and tied to the factory line that I am going to use as the return. I will post some more pics tomorrow if it doesn't rain.
Old 08-09-2012, 01:34 PM   #554
packetrace
packetrace's Avatar
Good thanks!!!:-)
Fun to follow thread like this :-) will make thing easier when i will install mine /)
Old 08-09-2012, 10:14 PM   #555
packetrace
packetrace's Avatar
wow man....i rmeoved the rear seats(and did not pu them back :D) its BIG this fuel pump assembly!!! i tought I would have some thing that fits in my hand...ITS BIGGG!! ahah...just wanted to share..
Old 08-09-2012, 10:27 PM   #556
^ dunno what you mean. The pump is very small
Old 08-10-2012, 05:44 AM   #557
packetrace
packetrace's Avatar
I meant..nott the pump itself...the cylinder in which it stands...its pretty compare to what i had expected lol
Old 08-13-2012, 12:19 AM   #558
pimp my yaris
C'est la vie
The fuel system is done and WOW what a difference. I now know the stock regulator was seriously choking off fuel and could not flow enough to handle a turbo yaris above 5 psi. The only reason it was working was because of the larger injectors and the fact that I was increasing the duty cycle to max them out. I went from plus 80% fuel at the high rpm end of my map to -12% at the same spot on my map with the new fuel system. My new regulator adds 1 psi of fuel pressure for every 1 psi of boost. This does most of the tuning for you. You absolutly still need a piggy back though. I took more pics of the system and some pics when I was doing some "HOT LAPS" and tuning.
Also as far as parts used: fuel rail, scion TC injectors, Aeromotive fuel pressure regulator, 1/8 npt fuelpressure guage on regulator, 1 -6an bulk head fitting with nut, 6 straight -6 hose end fittings, one 90 degree -6an hose fitting, 1 -8an straight cut to -6an hose fitting with o-ring, one -8an straight cut to -6an with a 90 deg. bend and o-ring, 25ft of -6an black braided fuel line. I bought the line and almost all the fittings from e-bay and the last fitting from summit racing. That one was hard to find.
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 03:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 03:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 02:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 03:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 03:10 PM
