![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
Is there anyway to fix this?
![]() Drives: 2007 toyota yaris sports Join Date: Oct 2010
sand it down and paint over it. same thing happen to my old car.
you could repaint it or just replace the whole thing.
right below the section in question, there s a small plastic insert that is covering the nut which holds it to the stud. just remove the plastic insert and take the nut off. the wiper comes right off. the wiper is ribbed (there is a propper word for it but it eludes me) so that it will turn with the movement of it. I actually used the dirt on my windshield for alignment when I removed mine. I had to remove my cowl for spring removal. good luck regardless of what you decide to do. |
I was lucky enough to obtain a new set of pristine arms at a wrecking yard a few years back. I use my old corroded ones in the winter, and switch to the second good set in the summer.
![]() ![]() Drives: NCP91 Join Date: Jul 2012
splined, there we go. was a bit brain dead earlier today. it happens.
やりすぎだ~
^brain was thinking "condoms".
How did that happen?
![]() Personally I dont worry about things like that unless I have nothing better to do someday.
WTF are you talking about!? I have never seen spline corrosion on any wiper arm that exhibits this common problem of paint blistering on this part of the arm.
2ZR swap. DO IT! Ask how!
Based on the location of the blistering, it's not from the spline. The spline is under the cap, all the way on the right of the arm. This looks like a flaw in the finish around the pivot pin, possibly caused by mechanical damage (ice scraper, "snapping" them down too hard, rock chip, etc.) I'd say just get a new/salvaged one.
| Hey everyone...Did anyone get a FIX for the Oversteer Problem at fwy Speeds under war | jay cobbs | General Yaris / Vitz Discussion | 0 | 06-13-2012 11:10 AM |
| DIY- rattle from lower windshield fix. | PetersRedYaris | DIY / Maintenance / Service | 3 | 08-21-2011 01:29 AM |
| LED Indicator Fast Flash Plug and Play FIX | 1NZYaris1 | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 04-18-2011 04:47 AM |
| Uh oh: How Much To Fix This? | bronsin | General Yaris / Vitz Discussion | 11 | 12-05-2009 08:25 PM |
| firts mecanic fix! | the_boss | Off-topic / Other Cars / Everything else Discussions | 1 | 08-21-2009 04:56 AM |
