#523 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
post pics of when its compressed :)
where did you ran the 6an new feed line.. ? where can i reach the pump assembly ? under passenger seat ?
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#524 |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
The pump is under the rear seat under a silver piece of sheet metal. I did shorten the line to the pump a little. That pic was not the final assembly. The line will run under the car and tied to the factory line that I am going to use as the return. I will post some more pics tomorrow if it doesn't rain.
#525 |
Good thanks!!!:-)
Fun to follow thread like this :-) will make thing easier when i will install mine /)
#526 |
wow man....i rmeoved the rear seats(and did not pu them back :D) its BIG this fuel pump assembly!!! i tought I would have some thing that fits in my hand...ITS BIGGG!! ahah...just wanted to share..
#527 |
^ dunno what you mean. The pump is very small
#528 |
I meant..nott the pump itself...the cylinder in which it stands...its pretty compare to what i had expected lol
#529 |
C'est la vie
The fuel system is done and WOW what a difference. I now know the stock regulator was seriously choking off fuel and could not flow enough to handle a turbo yaris above 5 psi. The only reason it was working was because of the larger injectors and the fact that I was increasing the duty cycle to max them out. I went from plus 80% fuel at the high rpm end of my map to -12% at the same spot on my map with the new fuel system. My new regulator adds 1 psi of fuel pressure for every 1 psi of boost. This does most of the tuning for you. You absolutly still need a piggy back though. I took more pics of the system and some pics when I was doing some "HOT LAPS"
and tuning.Also as far as parts used: fuel rail, scion TC injectors, Aeromotive fuel pressure regulator, 1/8 npt fuelpressure guage on regulator, 1 -6an bulk head fitting with nut, 6 straight -6 hose end fittings, one 90 degree -6an hose fitting, 1 -8an straight cut to -6an hose fitting with o-ring, one -8an straight cut to -6an with a 90 deg. bend and o-ring, 25ft of -6an black braided fuel line. I bought the line and almost all the fittings from e-bay and the last fitting from summit racing. That one was hard to find. Last edited by pimp my yaris; 08-12-2012 at 11:31 PM. |
#530 |
C'est la vie
O, I forgot. The regulator and the fuel filter on the bottom of a car I got from a friend. Still need to pay him.
#531 |
wow nice!!! thank you for picture!!
so you feed from passenger side...and returns on the driver side to the stock hard line ? what kind of inline filtrer did you used ?
#532 |
C'est la vie
The feed and return are zip tied together. Yes I am using the stock hard line for the return. It feeds on the driver side of the fuel rail.
I am attaching a manual boost controller and I am going to turn it up to 15psi and retune. |
#533 |
Excellent!
#534 |
Did you get a new turbo?
#535 | |
Mr. 155 and climbing
You meant 51psi right?
#536 | |
you lost me here? i hope you dont mean you going to us the boost controler to bring you fuel pressure up to 15psi because thats not going to work..
05 Scion tC allmotor 350+ hp 9.34@144mph 05 Scion tC sfwd 880hp 9.96@147mph 05 Scion xB 280hp 12.97@104mph 07 Toyota Yaris 357hp 12.80@107mph |
#537 |
I think he means boost, not fuel pressure.
#538 |
I hope so :)
#539 |
pretty sure that is the case and I am curious what he is setting his FP at.
#540 |
C'est la vie
Fuel pressure is set at 45psi at idle.
And yes I am increasing turbo boost because that is the whole point of getting enough fuel to support it. I was beyond maxing the stock in tank fuel pressure regulator at 12psi I am running into a new problem in trying to get to 15psi. It looks like my current .48AR turbine turbo will not flow enough air to maintain 15psi. I am getting to 16psi now, but as rpm,s go up boost is falling off. Time for a new turbo and a new manafold. This is what Im liking http://www.ptuning.com/html/Item-Des...9&ModelDesc=xB Plus a tial external wastegate and a .64AR hot side turbo with a new custom 3 inch exhaust. |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 01:24 AM |
| ZPI soon to release their turbo kit | turboyaris | Forced Induction Forum | 10 | 04-26-2007 02:52 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 02:10 PM |
