Old 08-22-2012, 12:16 PM   #37
ehh.. its only been a couple weeks since his last post. Probably either blew his engine and embarassed to talk about it or just simply got busy with something else and doesn't wanna waste time with us =(
patience
or he has a life outside of internet forums...
Old 08-22-2012, 12:17 PM   #38
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Psh,
Old 08-26-2012, 09:35 PM   #39
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
too bad you can't take full advantage of the compression with bigger cams
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 09-16-2012, 07:13 PM   #40
taman86
Drives: scion xa
So any update to this? Still running? Dyno? Also I was wondering what engine managment you are using to run these. Stock, piggyback, or standalone? Where did you souce these from, new or another engine.
taman86 is offline   Reply With Quote
Old 09-16-2012, 09:53 PM   #41
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
we are all still waiting for some kinda update on this one..
-Derrick-
Old 09-18-2012, 03:36 PM   #42
taman86
Drives: scion xa
does anyone have this guys number and give him a call. I WANT UPDATES!!!
Old 09-20-2012, 06:35 AM   #43
moh
moh's Avatar
Drives: Yaris Sedan
+1
|Blitz S/C|aFe Intake|NST SSK|NST Busing kit|Ralco Short Shifter|Dastek Unichip type Q|Dastek Throttle Control|1ZZ Injectors|1ZZ TB|Custom Header|Custom Exhaust|Head Porting|Momo Drifting Steering wheel|Momo shiftknob|Denso Irridium Sparks|Buddy Club P1 Racing Wheels|195/50/R15|Tanabe NF Coilover|Goodrich SS brake lines|Ultra Racing Front Strutbar|NRG Grounding kit|Custom Grill|Custom Eyelid|Rear Sway bar|
moh is offline   Reply With Quote
Old 09-30-2012, 12:54 AM   #44
Autocross72
Drives: 2009 3rd Polar white
I'm guessing he blew up the engine. That is way too much compression to be running on pump gas and cast pistons. To run as much compression as he had you would need forged pistons and run race gas. Mother wise you would not be able to control detonation. Of course, he could prove me wrong by posting an up date, but physics predicts that he won't be doing that.
Autocross72 is offline   Reply With Quote
Old 11-02-2012, 12:50 PM   #45
jetblast
Drives: Gen 1 XB
Don't forget the toothpick con rods.
jetblast is offline   Reply With Quote
Old 11-05-2012, 11:47 PM   #46
Viperoni
Drives: 2005 Toyota Echo
You sure that the motor would gain that much power from a 1.5 point compression ratio bump that the cast pistons and stock rods would crack and pop?
Worst case you need 94 octane.
2006 Saturn Ion Redline
Old 11-06-2012, 05:40 AM   #47
ilikerice
ilikerice's Avatar
@Viperoni
I dont think its the "power" that he is referring to that will blow up the motor, but the compression itself and not using correct precautions. We will never know because OP hasnt updated
-Derrick-
Old 04-06-2013, 10:06 AM   #48
fast2882
Drives: Toyota Yaris 2012
Hello there, any update ? dyno result maybe?
fast2882 is offline   Reply With Quote
Old 04-06-2013, 11:26 AM   #49
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
what would go first the cylinder walls or the connecting rods?
Old 04-06-2013, 02:01 PM   #50
fast2882
maybe piston hit the valve
Old 04-06-2013, 11:10 PM   #51
Golddeenoh
Golddeenoh's Avatar
i was referring to should it function what would stress out first. valve clearance would be the first issue maybe a shim gasket to gain clearance and lower compression ratio while also adding block guards might work great.
Old 04-07-2013, 11:53 AM   #52
fast2882
too bad the project isn't work, i still really curious about the result if someone can swap this piston and have about 12:1 compression ratio in 1nz-fe engine. toyota 1NR-fe engine series have 11.5:1 compression ratio, so i think actually it is possible to have 12:1 too.
Old 04-07-2013, 12:27 PM   #53
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I think 12:1 is possible and even 12.5:1 with premium gas. the prius pistons are 13:1 so it is pushing it.
MicroImage has higher compression pistons for sale but i don't know of anyone that has done it. his 9:1 pistons are very popular in the boosted community.
Old 04-07-2013, 01:36 PM   #54
jetblast
Drives: Gen 1 XB
With that we'd be hangin' out in the FRS compression ratio arena.
Why strive for a JDM BB, when you can promote the Scion badge?
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 03:58 PM
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 09:38 PM
Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> jay cobbs General Yaris / Vitz Discussion 8 06-07-2012 02:44 PM
SEDAN LOVE CHILD OF CAMRY& PRIUS jay cobbs Fuel Economy Forum 0 05-23-2012 01:42 PM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 11:30 AM
