Old 08-23-2012, 12:19 AM   #19
djksmith
Drives: 2012 Yaris Hatchback
Originally Posted by jpmck03 View Post
Just make sure you have the correct amount of tension on the belt.
If you don't get it right, well you can buy a new belt and then make sure you have the correct amount of tension on the belt!
Well I have a "MI" appointment next week so I know I'm in good hands... Already had one adventure with my Yaris, not looking for #2, LOL
djksmith is offline   Reply With Quote
Old 08-23-2012, 12:22 AM   #20
Although I had a NST crank pulley, the main difference I noted was when shifting, when letting my foot off the gas, the revs would die down a lot quicker, so you had to shift and get back on the gas faster too (and the engine would rev up quicker anyway). So, it allowed faster shifting :)
Old 08-23-2012, 12:38 AM   #21
I have the regular NST lightened crank pulley (not the underdrive one). I've only really notice a difference in free revving (in neutral vs in gear). Aside from that, haven't really noticed anything else. lol
Old 08-23-2012, 02:01 AM   #22
ljming99
Drives: Yaris '06
It will be even more obvious with a lightened flywheel.
I have the NST WP and Alternator pulley, forgotten what brand crank pulley (likely is summit or something) and MI CCI flywheel.
If i Shift UP just abit slower, i would have to blip the throttle slightly.
For DOWN shift, blipping the throttle is almost a must for a rev match.
ljming99 is offline   Reply With Quote
Old 08-23-2012, 10:20 AM   #23
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
well, I pulled the trigger and ordered it. so I guess I'll see for myself when it comes in. I plan on doing a full review.
Captain Slow is offline   Reply With Quote
Old 08-23-2012, 10:59 AM   #24
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
You'll like it :)
goliath1812 is offline   Reply With Quote
Old 08-23-2012, 12:24 PM   #25
Captain Slow
I'm sure I will. everything I've done so far is to make the car a nice fun street ride. I really don't want to go overboard like I've done with previous cars and make them awful on the daily commute.
I think after this all I want is a set of Tanabe NF210s and a header. Oh, and some gripper tires when the stockers have been run bald.
Old 08-23-2012, 12:43 PM   #26
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
i had a belt squeal initially. my new gates belt was $7 and change. took me 10 minutes to change it along with cleaning the other pulleys, noise went away.
you should replace the belt while your there anyways, & clean/degrease the other pulleys while your there
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-23-2012, 01:48 PM   #27
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
It seems like there is quite the trend that folks end up a squealing belt after installing a lightweight pulley from either MI or NST.
Replacing the belt and cleaning up the pulleys while you are swapping out the pulley is great great advice.
Old 08-23-2012, 01:57 PM   #28
Based on my own experience with these pulleys, I believe the issue is the aluminum does not grip the belt as well as the OEM cast pulley does.
On a fresh belt, all is good. Once the belt has broken in and retensioned, all is still good. Then, as the belt ages and starts to glaze, the startup squeal is there to stay, but only on a cold engine/belt. If you're experiencing squeal on a hot engine/belt, then there is most likely tensioning issues.
DIY: MI Lightweight Pulley jpmck03 DIY / Maintenance / Service 36 12-09-2013 06:32 PM
Pulley System Question Vioz Performance Modifications 22 07-08-2010 09:51 PM
Alternator Pulley Question MGargano Performance Modifications 11 04-30-2010 12:50 AM
NST pulley question cookfreeordie Performance Modifications 14 11-14-2008 05:19 PM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 03:51 AM
