Old 07-24-2012, 04:40 AM   #1
birdman
Drives: '08 Blazing Blue Yaris LB
Power window noise
My '08 Yaris LB passenger side power window recently started to make a sort of buzzing friction noise when it goes up. The window still operates well but I am concerned about the noise. I lubricated the tracks but it didn't help. Does anyone know what's the cause and fix for this? Thanks :o)
birdman is offline   Reply With Quote
Old 07-24-2012, 09:18 AM   #2
Sounds like something with the motor or the lifting assembly. I would pull the door panel to get a better look/hear.
Old 07-24-2012, 03:20 PM   #3
birdman
Will do. :o)
Old 07-24-2012, 11:45 PM   #4
birdman
I removed the door panel to have a look and sure enough the noise was coming from the power window motor. I sprayed some lithium grease on the gear and greased the metal track below. None of this helped much though.
How much longer would you guess it will be before the motor is likely to die? When it does need replacement it looks like a bear of a job to get the old motor out and a new one in. Has anyone replaced a window motor?
Old 07-25-2012, 12:58 AM   #5
It may run forever making noise or it may die in a day. The motor will be a bit of a hassle to replace.
Old 07-25-2012, 02:11 PM   #6
birdman
Thank you. :o)
Old 08-26-2012, 02:01 PM   #7
DaryleTilroe
Drives: 2008 Yaris Sedan
Came here to look for this symptom. My '08 Yaris Sedan has started doing *EXACTLY* the same thing on *EXACTLY* the same window. Are they on some sort of failure timer!? Of course it's a year off warranty.
I wondered if it's actually something in gearing or spacing (ie loose and rubbing) unique to the RHS Front door topology but you say you took the panel off already and it's coming from the motor module.
I don't know how cheap this is parts wise but usually it's not too bad of a DIY job. I did it three times on my old Lumina Van (1 driver, 2 passenger; it was a '95 that is just going out to pasture now).
Sounds like wait till it dies kind for thing but if it becomes an epidemic we might get lucky with a TSB. Did you look already?
FYI Mine was a 12/07 build date and if I decode the VIN correctly it was plant "1" in Japan.
DaryleTilroe is offline   Reply With Quote
Old 08-26-2012, 02:28 PM   #8
There is not a TSB on this. It is not a very common issue and probably has much to do with the frequency that the power windows are opened and closed.
Old 08-27-2012, 12:38 AM   #9
DaryleTilroe
Hmm. Pretty strange since the driver's side gets rolled down a lot more and, as you can see from my profile location in Edmonton, we don't roll down windows at all almost half the year. Also, from prior power window experience, 4 years is really a poor lifetime; I'd expect twice that.
Old 08-27-2012, 09:36 PM   #10
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
If this helps at all.. My front passenger window motor has made a "struggling to roll up type of noise" id say for about the past 3 years.. It doesnt roll up or down any slower or faster than the driver side.. It just makes the noise.. So like CTscott said, it could die tomorrow or never..
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 09-01-2012, 01:11 PM   #11
auxmike
auxmike's Avatar
I think its from lack of use mostly. Mine is louder too. I only roll it down about an inch when I leave it in the parking lot at work otherwise it gets barely any use. I think the drivers side is more smooth because of daily use....
Yaris Power window switch fires auxmike General Yaris / Vitz Discussion 7 06-21-2012 03:41 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 10:34 PM
Installation of original power windows and locks in Yaris lantis DIY / Maintenance / Service 4 02-25-2012 02:38 PM
Rear Window Defogger YarisOwnersDad New YARIS Purchase Forum 37 12-10-2010 12:31 AM
