Old 08-30-2012, 07:17 AM   #1
mamun22s
Drives: Toyota Vitz
Power window
In my Clavia VITZ 2000 Driving sit power window wont work. I open the door switch board and wash the carbon then wash the rail. After reinstall once it work but after it goes dead. At night i see the auto writing upon on the window switch is blinking. I want to debug the problem my self. First of all is there any fuse or any controller to chk secondly the switch, third one the motor?
Any one can help how do I done all those things to repair my power window.
mamun22s is offline   Reply With Quote
Old 08-30-2012, 08:35 AM   #2
The blinking light on the switch says that it is getting power, so it's not a blown fuse. Inside of the master switch for the power windows there is quite a bit of circuitry, including a microcontroller. The easiest fix would be to replace the power widow master switch, but if you can't find one the next option would be to attempt to repair the existing one. The likely bad parts within it are either the switches themselves or some of the electrolytic capacitors, which tend to dry out over time.
power window
DIY: Colibri Power Window Install Taiyaki DIY / Maintenance / Service 15 04-28-2016 10:03 PM
Power window failure YarTrek DIY / Maintenance / Service 13 11-25-2013 01:38 AM
Power Window Switches Stoln Australia 5 11-07-2008 10:02 AM
POWER WINDOW POWER SOURCE IN DOOR PANEL? mrrock DIY / Maintenance / Service 5 03-21-2007 07:27 PM
