#19 | |
I thought I was going to need one for Crashy2, but ended up just needing to replace the melted airbag connectors, so this was saved in my eBay watch list: http://www.ebay.com/itm/2006-2007-20...cbfedc&vxp=mtr
#20 |
![]() ![]() Drives: 07SedanS06Taco Join Date: Oct 2008
Everything has been fine with the airbag light in the cluster since I replaced the clock
spring back in May 2012. I now have a flickering passenger airbag light on the dash. I will see if there are any codes but I'm assuming since its flickering it might be a loose connection or something in that direction. Any other troubleshooting suggestions? |
#21 | |
#22 |
I will try the connectors and reply with the results.
Should I have the ignition on when I disconnect and reconnect the connector? |
#23 | |
Do it with the ignition off.
| Airbag light won't turn off | dubgil | DIY / Maintenance / Service | 128 | 08-03-2016 02:12 PM |
| Passenger Airbag Question | RedStickHam | DIY / Maintenance / Service | 13 | 06-23-2013 05:39 PM |
| Replace airbag in my 2007 Yaris | uglyducklin | DIY / Maintenance / Service | 2 | 01-12-2011 03:53 PM |
| passenger airbag light problem (NOT stuck on) | ersheff | General Yaris / Vitz Discussion | 3 | 10-12-2010 09:20 AM |
| WTB: Driver Airbag, Airbag Control Module, Upper Tie Bar | opdmize | Willing to Buy by private party | 1 | 03-19-2010 02:01 AM |
