Old 09-04-2012, 04:10 PM   #91
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
If I understand intake properly, you'd want more heat soak. Intake air temps you want to be lower, exhaust should be warmer. Heating the intake temps will rob some of the power (hence why cold-air intakes provide more power over short-ram and OEM)
Anyone feel free to correct me if I'm wrong.
:EDIT:
Completely misread, and didn't notice the "gasket" portion of what was said. Thought you meant the ENTIRE manifold...
I'll go back to my corner now
Old 09-04-2012, 04:13 PM   #92
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by baseballfan416 View Post
I wonder if changing the intake manifold gasket to a non-metal material would help? More metal (compared to the plastic manifold) could translate to some heat soak?
I do believe that it would...
I did the dyno runs without it and the manifold was blazing hot. That big one inch thick slab of aluminium "heatsink" laying across the intake ports transfers engine heat like crazy. I'm going to get longer bolts to put the insulating gasket on.
Old 09-04-2012, 05:42 PM   #93
^ The manifold will get pretty hot from regular driving, especially stop and go, or "around town". Once you are moving pretty well, the longer runners will help protect against too much heat transfer.
The insulator/spacer might help a little. I'm not sure we'll be able to test one on the dyno though.
Old 09-04-2012, 06:44 PM   #94
justjesus
justjesus's Avatar
Drives: 2008 Liftback
DAMN. is it Thursday yet?
Get 'er done, Garm!
Old 09-05-2012, 11:47 PM   #95
Viperoni
Drives: 2005 Toyota Echo
I could see a switch keeping the rad fan on all the time helping out a bit too, but yes, you want the intake air temps cold.
2006 Saturn Ion Redline
Old 09-06-2012, 02:08 AM   #96
10 Francis
Drives: 2010 Yaris S HB
Wouldn't blowing hot air from the radiator be detrimental? Or are you (Viperoni) assuming that the radiator will be cooler than the manifold?
At any rate, some sort of wrapping or heat shielding would definitely seem to be in order as well as a phenolic spacer. Heat soak and weight are the two main reasons most OEM intake manifolds are made of a plastic material now (miles per gallon and tailpipe emissions).
10 Francis is offline   Reply With Quote
Old 09-06-2012, 03:48 AM   #97
baseballfan416
Drives: 2017 L 3-door
I'm only speaking from experience with honda's. Granted... a bone stock k20a2 (rsx-s) makes roughly 160whp, so in effect, it may be a magnified effect.
http://hondata.com/heatshieldgasket.html
The problem I see is that these metal manifolds increase heat soak (regardless of the mechanism by which it occurs)...
http://shop.microimageonline.com/The...GE-tig-1nz.htm
Wouldn't a product like the above potentially mitigate that heat soak? I almost wonder if tooter's manifold project could have realized better gains via the use of something like this.
baseballfan416 is offline   Reply With Quote
Old 09-06-2012, 11:07 AM   #98
today's the day!
Old 09-06-2012, 11:44 AM   #99
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Yes! Any Expectations?
Old 09-06-2012, 12:40 PM   #100
^ None. Just curious, like everyone else.
Old 09-06-2012, 01:20 PM   #101
suckerface
#1 Lemming
suckerface's Avatar
The anticipation is KILLING me! Hurry up and be done!
Old 09-06-2012, 01:22 PM   #102
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
waiting for printout lol
Old 09-06-2012, 08:19 PM   #103
Jeff@MicroImage
"Know it all"
Jeff@MicroImage's Avatar
Drives: Lancia Delta Integrale
Great results! Very pleased :) Garm should be chiming in shortly...
www.microimageonline.com
Jeff@MicroImage is offline   Reply With Quote
Old 09-06-2012, 08:20 PM   #104
SUCCESS. Didn't make much top end, but a nice midrange bump, right where you want it. Specs and dyno charts to be posted later. Couple of small improvements to be made in production.
I'm happy.
Old 09-06-2012, 09:23 PM   #105
Yoda
Yoda's Avatar
Nice!
Old 09-06-2012, 09:53 PM   #106
Viperoni
PICS AND VIDS!
and boobs.
Old 09-06-2012, 10:34 PM   #107
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
Awesome!!! I look forward to seeing the results and buying one!!
4/20 NEVER FORGET is offline   Reply With Quote
Old 09-06-2012, 11:02 PM   #108
bzinn 1
bzinn 1's Avatar
nice to see somebody finally bringing out an intake manifold...I cant stand the plastic one...will be saving up for this mod for certain...
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 02:06 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 07:52 AM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 12:58 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 09:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-14-2008 12:26 AM
