Old 02-19-2012, 09:52 PM   #253
Originally Posted by 09sedan View Post
great news, i just checked and i have all 3 wires, and my dash cluster has the set and CC indicators.
do i have to use the switches you mentioned, or can i use a plain SPST Normally open pushbutton that i can buy from my local electronics store?
Any normally open switches are fine.
Old 02-20-2012, 10:17 PM   #254
09sedan
Drives: 2009 yaris sedan
people are telling me if i dont use the expensive "aftermarket cruise control kit" which is like 3-500$ with installation that the CC might not disengage or the insurance company wont cover if something happens cuz its a DIY modification , are there any risks involved in using this mod? also i got a single 620ohm 1% 1/2Watt resistor, (im using 2 switch method) is that enough?
09sedan is offline   Reply With Quote
Old 02-20-2012, 10:22 PM   #255
Cruise control is a function of the ECM. You are just enabling that existing functionality by adding the switches and resistors as an input the ECM. The only way it can "not disengage" is if the ECM fails.
The aftermarket Rostra kit was actually recalled, because it has an issue where RF noise can make it misbehave, so I'd stick with enabling the OEM functionality.
Old 02-20-2012, 10:39 PM   #256
09sedan
ok, thanks for the advice, all i have to do now is find out where to mount these buttons , ive decided to just use utility knife to strip away the insulation on the 2 d3 wires and solder them in, i want the best connection possible so soldering is the way to go. i will post up my results once i have finished this project, thanks for the help ctscott!
Old 02-23-2012, 09:05 PM   #257
09sedan
just finished the wiring OMG IT WORKS !!! GREAT SUCCESS!! THANK YOU CTSCOTT!! you just saved me almost 500$ !!! if you ever come to toronto, let me know i owe u a few beers
Old 09-07-2012, 07:57 PM   #258
bronsin
bronsin's Avatar
Ive had my Yaris World cc for maybe two years now. I drove a friends car with stalk cc and HATED it. My four button cc is SO much easier to use!
Question: one button is on/off, another button is set/decel, and button is resume/accel.
What is the fourth button?
Old 09-07-2012, 08:50 PM   #259
Cancel.
Old 09-07-2012, 08:53 PM   #260
Originally Posted by chanka View Post
Hi Scott,
If I don't have cruise control in Yaris 2008 EECU ( In NZ ) can I change US market ECU and will it start as normal ? Then can I do my DIY CC ?
Cheers.
Possibly, if you have the 1NZ-FE engine. I believe that your cars follow the JDM Vitz wiring. I have not done a pin for pin comparison of the US versus JDM ECMs to see if any pins need to be moved around.
Old 09-08-2012, 07:20 AM   #261
Thanks Scott, If its hard I'll go for this option.
http://www.ebay.com/itm/WEAPON-R-I-T...=mtr#vi-ilComp
Thanks again.
Chanka
You do realize that that device is not cruise control, but rather a device that makes the throttle seem more responsive?
Old 09-10-2012, 07:29 AM   #262
azeeroth
Drives: '09 Yaris
I have the 2009 automatic with OEM cruise control and the stalk annoys me and frustrates my wife even more. We loved the OEM flick stalk on the old Camry!
Could I tap into the wiring and add this even though I have the OEM stalk? Essentially I'd have two sets of cruise control controls... control controls lols I can't see why I can't do it this way, but I don't want to poke it and end up with no cruise control.
I'd like to add a set of buttons or a joystick somewhere, but leave the OEM stalk in place so when it comes time to sell the car on I can take the secondary buttons out so as to not confuse anyone.
azeeroth is offline   Reply With Quote
Old 09-10-2012, 08:01 AM   #263
Can you post a picture of your OEM stalk? I am wondering if your Australian CC is different (and perhaps actually an aftermarket system).
If it is actually the OEM type used on the US Yaris, then you can indeed add the extra set of controls by tapping the two wires.
Old 09-11-2012, 07:11 AM   #264
azeeroth
Drives: '09 Yaris
I've had the steering wheel cover off to do the headlight relay mod, and from memory there's just one thick black cable going to this stalk. Presumably that goes back to the same wires you've described though.
Oh yes, this was done by the Toyota dealer before we got the car, so it's as factory as they do it here. I remember asking about the Camry style flick switch and they said something about not being able to do that as factory and they'd have to "put the cruise control in afterwards" so it could be an aftermarket one that Toyota uses.
Old 09-11-2012, 07:40 AM   #265
OK - That is definitely an aftermarket system, so there is a module somewhere under the dash or under the hood that controls it.
Old 09-28-2012, 06:36 PM   #266
voranik
Drives: 2011 Yaris 4D Sedan
Does this work on a 2011 Yaris ?
Hello,
I just bought a 2011 Yaris, and was wondering if this mod is easily possible on that model as well, i.e., is the wiring present from the ECM to under the steering wheel ?
Thanks!
voranik is offline   Reply With Quote
Old 09-28-2012, 09:30 PM   #267
Originally Posted by voranik View Post
Hello,
Thanks!
It is for sure for 2011 liftbacks, but Sedans are not as cut and dry. At least up to 2009, if the Sedan did not have the power package, then the wiring was installed from the ECM to a junction connector under the top of the dash, but not from there to the steering column.
The easiest thing to do is to pop the steering column cover and check for the blue and brown wires on connector D3.
Old 01-01-2013, 03:33 PM   #268
mf4361
Drives: Yaris Sedan
sorry for reviving this thread. I was trying to do this on my Canada 07' Sedan. (I believe this is possible for Canada Yaris right?) But I hit problem when getting the wire from engine bay to interior using the rubber plug next to the ECM.
According to the posted manual, the plug is installed from the engine bay side and one can easily remove it. But on mine, the grommet plug seemed to be installed from the inside so I can't get it out from engine bay. And from the inside, the rubber plug is behind the carpet so I can't reach it either.
Can anyone show me where the grommet plug is from the inside? or is there any other place to get the wire in somewhere else? I'm a noob in car mods and in fact this is the first time I do things like this with a car. Please help! Thanks!
mf4361 is offline   Reply With Quote
Old 01-01-2013, 06:11 PM   #269
My full DIY for the OEM cruise stalk (link below) shows where the grommet comes through inside. To get to it you will either have to pull down the carpet a bit, or cut a little slit in it.
http://www.yarisworld.com/forums/showthread.php?t=33750
Old 06-13-2014, 12:19 PM   #270
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
doing this tomorrow! THANKS SCOTT YOU THE MAN!!!!
trunkout is offline   Reply With Quote
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
