Old 05-17-2011, 12:06 PM   #19
NZ-FE Vios
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re
Oh man, super jealous of the diesel. When the gasser dies, I'd like to swap in the comparable 2.4diesel (ala topgear). 404 km is getting up there. Unfortunately the truck had an owner within the family and he didn't appreciate it quite as much as I do. I'm sure it would have lasted longer if properly maintained. It's sure up to spec now
NZ-FE Vios is offline   Reply With Quote
Old 05-17-2011, 12:11 PM   #20
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
Originally Posted by brbo View Post
Are you suggesting there is an issue with Yaris timing chain tensioners ?? ,
I am not suggesting that at all. Quite the opposite.
DMZ is offline   Reply With Quote
Old 05-17-2011, 03:03 PM   #21
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Looks like the OP has left the forum and hasnt returned to update us on his cars condition.Did we waste our time responding?Did the Op get any help out of our responses? Was the timing chain defective? should i worry about the Timing chain in my car?
Thanks Rampage maybe next time you join a forum you may want to read up on Forum etiquette before leaving us all hanging..
Old 05-17-2011, 03:19 PM   #22
DMZ
DMZ's Avatar
No No, I was referencing DMZ post - not really sure if it was in reference to the issue at hand and how it would apply to the original issue....as he quoted my message....
220mile - sweet you've gotta love that 22R engine, I have a few buddies that pound on them with 36" tires,, I personally do it with my 3B diesel...404km and counting...
My post was an attempt to clarify the fact that timing chains do not stretch. The gears wear and that what results in slack.
It is the same with motorcycle chains. There is a common myth that they stretch with age. If you measure one new and after 50K miles, the length is the same. The sprockets get worn and oval out, hence the need to adjust or tighten it periodically.
Sorry about the confusion. I am inclined to believe that a maintained Yaris should be able to go 400k without having a timing chain issue.
Old 05-18-2011, 12:06 AM   #23
brbo
Drives: 2010 Yaris
Really,, ok maybe stretch is perhaps too lay - the pins and bushes elongate causing poor mesh with the sprocket - resulting in premature wearing of the sprocket teeth,, culprit chain.... overheat it by lack of lubrication or poor lubrication pins wear chain gets longer...
Don't have acceptable tolerance specs handy,,,
brbo is offline   Reply With Quote
Old 05-18-2011, 01:22 AM   #24
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
they might not stretch like belts, but i bet if you don't change the oil enough and ignore other maintenance items you could get them to weaken and stretch some.
Colin Chapman disciple
Old 05-22-2012, 08:16 PM   #25
sargo
Drives: yaris
Yaris Timing Chain
I too have had a problem with my 59 plate Yaris which the dealer states will cost £800 to fix.
The only indication of the fault is the orange waring lamp on the dashboard.
There is no noise or any form of problem with the car apart from the warning lamp.
I spoke to the dealer who said they would not be willing to partisipate with the cost of the repair.
My car has only done 31.00 miles and I feel that Toyota should be willing to investigate the fault further,as the timing chain should last almost the same lifetime as the car.
Has anyone heard of this problem happening to anyone else, and if so how did it work out for them.
sargo is offline   Reply With Quote
Old 05-22-2012, 10:30 PM   #26
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
^WTF^
OTA'sTOY is offline   Reply With Quote
Old 05-22-2012, 11:39 PM   #27
Chuck G
Drives: 2010 Yaris Sedan
I think when I pull my water pump off, I'll go ahead &
change my timing chain.
Thanks for the heads up!!
Old 09-02-2012, 01:30 AM   #28
Yaris9999
Drives: yaris 08
Another chain story
My '08 Yaris has 45,000 miles and has NO SYMPTOMS. The dealer says I need a new chain. I have an extended warranty which he says DOES NOT APPLY??
What gives?
Yaris9999 is offline   Reply With Quote
Old 09-02-2012, 02:40 AM   #29
Chuck G
What gives?
Really??!!
Old 09-02-2012, 03:16 AM   #30
nookandcrannycar
Originally Posted by OTA'sTOY View Post
^WTF^
This ^^^^^ 59 plate Yaris?
Old 09-05-2012, 01:30 PM   #31
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
License plates!!
Absolutely Red 12 is offline   Reply With Quote
Old 09-06-2012, 07:12 AM   #32
nookandcrannycar
Originally Posted by Absolutely Red 12 View Post
License plates!!
Why 59 plate? What does the 59 represent? Why would the term be used along with the model name to describe the car? I haven't spent enough time in Scotland to know what this means, and I'm just curious.
Old 09-06-2012, 08:00 AM   #33
You don't watch enough Top Gear. In Great Britain you can tell when a car was made by the registration plate. In his case a 59 plate designates a Sept 2009 to Feb 2010 date.
I would definitely want to see more data as to why the shop believes that a car that new needs the timing chain replaced.
Old 09-06-2012, 08:24 AM   #34
nookandcrannycar
Thanks. I love that show, but you're right, I don't watch it enough. I've driven around England, Wales, Scotland, and Northern Ireland....and once took a regularly scheduled bus from Dover to London. I've seen lots of plates, but I did not know the plate revealed when the car was made. Great thing about each new day, you can always learn something new if you ask questions!
Old 09-06-2012, 07:09 PM   #35
MadMax
MadMax's Avatar
Wow, it's been a while since I was in the UK but I still think in terms of the old system which used letters to distinguish when the car was made...
Now I see that since 2001 it's been numbers...
More info here:
Vehicle registration plates of the United Kingdom
Cheers! M2
Old 09-09-2012, 09:14 AM   #36
DARKSCOPE001
Drives: 2011 Yaris sedan
what a crock. those chains should be good for at least 100k (old school thinking) as far as i know that chain is "lifetime" and in my oppinion. its part of the powerplant. so it should be covered under your power train waranty. if the dealer wants to fight you on it contact toyota direct. write a bad review. make as much noise as possible. hech picket outfront of there store. do every legal thing you can untill they make it right or just ignore them. 4 years, thats so bullcrap. unless your sitster drives like 50k a year or more there is no possible way. someone has a boat payment due.
Good luck
Sean Scott
DARKSCOPE001 is offline   Reply With Quote
timing chain
australian vs american models: timing chain hoobyjuice DIY / Maintenance / Service 3 06-16-2009 10:25 AM
wtf?! timing chain cover split?! jeff69dini DIY / Maintenance / Service 9 08-01-2007 01:11 PM
