Old 09-29-2012, 08:19 PM   #1
Applejam
Drives: 2007 Yaris
AC doesn't work on startup until I change circulation
This just started today on my '07 hatchback, but I was able to reliably reproduce it.
When the car starts the AC fan doesn't kick in. If I change the speed, even to 0 and then another speed, it doesn't do anything. If I change how the air flows (either from outside air coming in to recirculation, or vice versa), it kicks in and seems to work fine. I can even change it back to the original setting without trouble.
I'm having difficulties finding a similar problem through Google, partly because I'm not really sure how to succinctly search for it. Anyone encounter something like this? And if it's not an easy fix, how much would it set me back? Is it even worth fixing?
Applejam is offline   Reply With Quote
Old 09-29-2012, 10:28 PM   #2
Since the fresh air / recirculate knob is purely mechanical and is not tied at all to the blower, I would start with popping off the AC control panel and checking for the blower speed connector not being fully seated (pull of the vertical black pieces with your fingers and then pull the AC panel straight back).
Tags
a/c, circulation, knob, recirculation
Planning first oil change @ 500 or 1000mi schleppy DIY / Maintenance / Service 39 07-09-2010 07:28 AM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 03:20 PM
LED Change for the AT Shifter for a Liftback? omendt Cosmetic Modifications (Exterior/Interior) 3 06-24-2009 11:53 PM
Oil change time... yay! YarisFan007 DIY / Maintenance / Service 10 09-19-2007 06:40 AM
My Work, Your Work - Stories and Fun SmallCarGuy Off-topic / Other Cars / Everything else Discussions 0 09-02-2007 08:43 PM
