Old 11-14-2012, 10:51 AM   #1
bronsin
bronsin's Avatar
Water pump recall
Hey whats this stuff about Toyota recalling cars for water pumps.
Is it also us?
Old 11-14-2012, 10:56 AM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
So far all of the news isn't listing much for which models, but it is very possible that ours may be included since they are talking about over 2 million vehicles. I have been kicking around upgrading the water pump anyway, but still if this is the case I am not going to be really bent out of shape since my reliability has been tested pretty well with most parts holding up very well.
Old 11-14-2012, 11:16 AM   #3
kou
Drives: 08 lb
For the cost of $30 and an hour of my time I would rather replace it myself. Anyway they don't completely fail they just weep a little at high rpms mine lasted 80k before I decided to change it and my overflow tank still had a 1/4'' left in it.
Old 11-14-2012, 11:42 AM   #4
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
They are recalling the Prius', so I am thinking the Yaris' that share the same 1.5L engine as the Prius are probably on the list.
2007 LB W/Cold Wx Package
DMZ is offline   Reply With Quote
Old 11-14-2012, 11:44 AM   #5
bronsin
bronsin's Avatar
Another question:
My wp WAS REPLACED BY tOYOTA UNDER WARRANTY.
sHOULD THEY LOOK AT IT?
Old 11-14-2012, 11:46 AM   #6
bronsin
bronsin's Avatar
Yeah mine leaked just a little.
Now that its MY dime I might just let it leak if it happens again..
Yes? No?
Old 11-14-2012, 11:50 AM   #7
NEexpat
Drives: 2009, auto, 4dr LB
Here is a link to one of the reports,
HERE
Mentions the Prius and the Corolla but does not rule out any others. I'll wait and see if I get notified.
NEexpat is offline   Reply With Quote
Old 11-14-2012, 11:52 AM   #8
DMZ
DMZ's Avatar
Here is some more info. It appears that they are going to replace the electric water pump on the hybrid systems:
http://detroit.cbslocal.com/2012/11/...-pump-defects/
Old 11-14-2012, 12:16 PM   #9
kou
Drives: 08 lb
Yes? No?
You can let it leak as much as you want just keep an eye on the coolant bottle. I installed an aftermarket Nissin waterpump the are are good quality japanese parts maker.
Old 11-14-2012, 01:04 PM   #10
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
ELECTRIC water pumps..
Not Yaris
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 11-14-2012, 02:00 PM   #11
2011 and greater Corolla, Prius and Wish.
OEM vs Aftermarket Water Pump? antone DIY / Maintenance / Service 0 10-23-2012 01:25 PM
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 09:04 PM
Water Pump gave up on me finally Vioz DIY / Maintenance / Service 4 07-31-2011 07:08 PM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 10:14 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 10:26 AM
