Old 11-19-2012, 11:07 AM   #37
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
cool
Old 11-19-2012, 04:38 PM   #38
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Just picked this up from the shop
I need to do some finish work on it but overall everything came out better than I hoped.
Old 11-19-2012, 06:22 PM   #39
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Looks really neatol!
Will you put the runners inside the flange holes?
Old 11-19-2012, 06:32 PM   #40
xnamerxx
0-60 in slow
xnamerxx's Avatar
sorta I'm either going to flare the tube or cut and wedge the pipe in the flange. I matched the flange port diameter to that of the gasket so I don't induce any extra sharp edges that will mess up the initial shockwave from the exhaust.
I'm going to speak with the welder and see if I can get this started tonight.
Old 11-19-2012, 07:24 PM   #41
tooter
play every day
tooter's Avatar
I had a similar issue building the manifold, and had little "shelves" machined into edges of the ports to hold the runners in alignment while they were being welded up. It worked great because the weld filled in the shelf and covered it up smoothly...
...leaving the inside relatively clean.
Old 11-19-2012, 09:11 PM   #42
xnamerxx
0-60 in slow
xnamerxx's Avatar
All cleaned up and ready to be welded on :)
Old 11-21-2012, 12:05 AM   #43
xnamerxx
0-60 in slow
xnamerxx's Avatar
Well its time for me to post a real update
I now understand why Richard Holdener went with a 4-1 design its so much easier to package and get the correct length out of. I'm about 1/3 to about a 1/2 of the way finished with the primaries. Thank god the welder who is helping me out had experience building motorcycle race exhausts because I made some bone headed mistakes. All in all my primaries are longer than the stock primaries and my secondaries will be cake on top of that. So to keep you guys tided over here is a picture of the first tube being tacked in place.
Old 11-21-2012, 01:01 AM   #44
tooter
play every day
tooter's Avatar
It's so exciting to see your project begin to take shape.
It's like creating a work of functional art!
What are you using to cut the tubing so cleanly?
Old 11-21-2012, 01:25 AM   #45
xnamerxx
0-60 in slow
xnamerxx's Avatar
I'm a bit fortunate to have access to shop equipment but I've been cutting everything with a band saw, grinder, or belt sander.
So in order to get the clean cuts after I make the initial cut I deburr the edge of the tube both inside and out and it makes that nice clean lines, makes it way easier to weld as well apparently too. I can't take all the credit though, I'm getting lots of help from the welder on how to properly work with tubing.
I'm amazing on how much work it is to make these pipes, its been quite fun, but quite a bit of work. I wish I took some more pictures after I got the collector on but it was getting late and I needed to home. Hopefully I'll get the other 2 pipes welded up tomorrow and a initial test fit to see if everything's kosher.
Something I thought was a bit funny but my primaries right now on my tri-y header are longer than the primaries on the stock header and I still have about 2 feet of secondaries to add.
Old 11-21-2012, 01:30 AM   #46
Bluevitz-rs
are you going to dyno the results before and after?
Old 11-21-2012, 02:26 AM   #47
tooter
play every day
tooter's Avatar
If yours going to be this long?
(just joking )
Old 11-21-2012, 10:28 AM   #48
xnamerxx
0-60 in slow
xnamerxx's Avatar
I have dyno results from when I was stock, but I'm going to dyno it against a DC header after its been vetted.
LOL its going to be close but thats all I'm going to say
Another taste ;)
Old 11-21-2012, 02:30 PM   #49
tooter
play every day
tooter's Avatar
Is your header going to have an 02 sensor bung? I was thinking of chopping my WR header in half and adding a couple of straight tubes to lengthen it.
Old 11-21-2012, 02:46 PM   #50
MBSPE
Custom Exhaust
MBSPE's Avatar
Drives: Yaris Sedan
nice work
-Greg @ MBS
Custom exhaust fabrication!
www.mandrelbend.com
www.mandrelbendingsolutions.com
MBSPE is offline   Reply With Quote
Old 11-21-2012, 04:04 PM   #51
xnamerxx
0-60 in slow
xnamerxx's Avatar
It will but I'm a ways from being able to weld the bung in place. It might be difficult to extend the primary length for the WR header which is what you would want to do.
Old 11-21-2012, 06:04 PM   #52
tooter
play every day
tooter's Avatar
I only was thinking about lengthening the secondaries as its easier.
The logical place to cut would be at the first welded joint up from the bung where everything is pointing straight at each other.
Old 11-21-2012, 06:09 PM   #53
Jason@SportsCar
Another taste ;)
Good stuff, cant wait to see dyno numbers.
Old 11-21-2012, 06:10 PM   #54
xnamerxx
0-60 in slow
xnamerxx's Avatar
I don't think you'll see any benefits to doing so just because the primaries are far more important than the secondaries for base scavenging.
What I would do is cut the point before the primaries join get a u bend SS in the right diameter cut and bend it so the pipes sit on top of each other like a 4-1 and pull them out about 18-30"s and use the existing merges as a way to terminate the pipes.
OBX Header Galavoxx Performance Modifications 3 04-20-2007 11:36 AM
Megan Header Advice jamal1984 Cosmetic Modifications (Exterior/Interior) 1 02-20-2007 07:22 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 01:57 PM
