Old 12-09-2012, 01:21 PM   #451
yaris2010RS
yaris2010RS's Avatar
CTScott i wished toyota let me keep the old ECM as i would have loved to donate it to you
Old 12-09-2012, 02:47 PM   #452
Originally Posted by Focus_Sh1ft View Post
Great news! Threw the ECM back in the car and we still have the same problems! (I must live a pretty depressing life if I consider that 'good news' )
CTScott - is there ever a time you don't pull through? lol
Are the markings significant to you? I ask for two reasons. One: could I possibly pick up an equivalent diode at a local electronics store? Two: I noticed yaris2010RS has what looks like 'T3 91'. Wondering if there's any substantial differences. For reference, my ECM is for a 2008 automatic (part# 89661-52G50).
If all else fails, I'll gladly take you up on your generous offer. Thanks again!
The 81/91 are likely date codes and the T3 is the identifier.
It appears to be a BAV19W - BAV21W:
http://www.diodes.com/datasheets/ds12024.pdf
Old 12-09-2012, 03:10 PM   #453
Focus_Sh1ft
Focus_Sh1ft's Avatar
Unfortunately, since these look to be used largely for commercial use, obtaining one (or even a few) looks pretty impractical.
I was trying to match some typical diodes found at a place like radioshack against the electrical characteristics in that link, but no luck.
Getting the piece from you looks like the best way to proceed. I'll send you my info shortly.
Also: Is anyone as baffled as myself as to how this happened? Technically I've been running the ECM in "limp mode," so maybe that circuit was spending too much time outside it's expected operational range or something? Weird.
Old 12-09-2012, 07:20 PM   #454
yaris2010RS
my bet is water.......
Ill check tomorrow at a local electronics surplus store. Radioshack wont have anything like this, you need to go to a real electronics store....
Old 12-09-2012, 10:39 PM   #455
Pulled, packed, and ready to head to the post office in the morning:
Old 12-09-2012, 11:35 PM   #456
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Pick your poison
Old 12-10-2012, 12:47 PM   #457
Focus_Sh1ft
Attachment 49257
Excellent.
So I discovered something interesting while digging around. Apparently, the 2008 model year switched ECM models only two months into production. Common sense says Toyota must have found something pretty bad to merit changing the ECM during the production run, rather than waiting for the following year.
Old 12-10-2012, 03:02 PM   #458
Excellent.
Which part number ECM do you have? Looking at the EPC, for AT equipped Yaris only there was a change in 11/2007, with the build having started in 8/2007.
Old 12-10-2012, 05:25 PM   #459
Focus_Sh1ft
^ That's exactly what I'm talking about. I have 89661-52G50 and they started using 89661-52G51 in 11/07. Haven't been able to find anyone else with ECM failures though, but then again that is a fairly small window.
Old 12-10-2012, 05:32 PM   #460
Crashy and Crashy 2 both have the 89661-52G50. The outer aluminum of Crashy's ECM is super oxidized. I really should open it to see if any of the salt has made its way inside yet. There wasn't a TSB on the change, so the 89661-52G51 isn't considered a necessary replacement, so they probably did some minor tweaking to the AT control, since the MT didn't get revved.
Old 12-12-2012, 12:43 PM   #461
Focus_Sh1ft
Leave it to USPS to take what should have been 1 day shipping and turn it into what is going to be at least 3 days now. Ugh.
Old 12-12-2012, 01:06 PM   #462
Tracking shows that it was delivered today.
Old 12-12-2012, 01:12 PM   #463
Focus_Sh1ft
Oh boy.
Old 12-13-2012, 01:42 PM   #464
Focus_Sh1ft
Welp, this board is dead. Diode made no difference (yes I observed polarity).
Let's talk about replacement ECMs. My number one concern is if I'm going to need reprogramming or not. From what I understand, since I don't have an immobilizer I shouldn't need it. I'll have a VIN mismatch obviously but I'm pretty over that.
Also probably going to grab a part# 89661-52G51 since they're more available.
Old 12-13-2012, 01:45 PM   #465
Bluevitz-rs
Well that's sucks! I gues you just need a non Imobilizer ECU as a replacement then.
Old 12-14-2012, 10:40 AM   #466
yaris2010RS
from what i have gathered from a mechanic (chrysler but same thing), you will be able to switch it out without issue. if you have keyless entry (lock and/or unlock on your key fob) you may need to reprogram this feature. he said it depends on the specific car. (Im sure CTScott would be able to answer that)
As per the chip key thing, has anyone confirmed that a new ECM would need this programmed in? from what my dash cam caught of My ECM replacement they did not program any keys (nor did they ask/ensure i had all my keys with me). They may have transferred the data off my old one onto my new one but i am not sure
Old 12-14-2012, 11:48 AM   #467
With a non transponder key one the only thing that ideally needs to be programmed is the VIN. This can be done via techstream. If you don't have it done, if your state does an inspection or emissions check, where they plug into the OBD connector, the VIN will read incorrectly.
If you don't want to deal with the dealer for the VIN reprogram, ship me the ECM and I'll program it for you.
Old 12-14-2012, 12:07 PM   #468
Will you smog and pass my car next March?
FS: Autometer Cobalt 6170 Boost Gauge Nexus1155 Items for Sale by private party 2 02-02-2011 04:08 PM
Multiple cylinder misfire under boost LtNoogie Forced Induction Forum 13 11-02-2009 04:44 AM
Fill up with Super before starting your boost project LtNoogie Forced Induction Forum 5 12-01-2008 06:41 PM
Supercharger Selection and Limiting Boost Nexus1155 Forced Induction Forum 1 12-01-2008 03:51 PM
WTB: Boost Gauges Teruyume Items for Sale by private party 4 11-12-2006 02:42 PM
