Old 12-17-2012, 03:54 PM   #469
Focus_Sh1ft
Focus_Sh1ft's Avatar
Got the new ECM today and it did absolutely NOTHING. I have the same problem... I even opened it up to see if it failed in the same way thinking maybe a short in the harness. It was fine.
I'm losing my mind over this... The only things left to check are the integration relay and fuel pressure.
Anyone else have any other ideas? Once I rule those two out, I really don't know what else to do...
Old 12-17-2012, 06:22 PM   #470
Are you running a F/IC, or just the ECM by itself?
Old 12-17-2012, 07:42 PM   #471
Focus_Sh1ft
I've tried both. I can't find anything wrong physically in the FIC harness either. Maybe I should do continuity checks on the connector side?
Old 12-17-2012, 09:20 PM   #472
yaris2010RS
yaris2010RS's Avatar
^thats very very odd.....
Just a shot in the dark here, try to run on stock injectors and ECM (no FIC). just to rule out injectors and FIC.
Im sorry to say it sounds alot like the issues i was having. check what your blow by pressues are like at the breather tube.
Also im not sure how plausible this is but could you be having an issue with your stock O2 sensor? if not the sensor possibly the wiring touched the exhaust and melted. Possibly try to unplug the O2 to see how the car reacts.
Old 12-17-2012, 10:38 PM   #473
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Now that I think about it, I forgot the Yarisworld uses an AFR sensor not an o2 sensor up front. So it might really depend on that sensor to make quick adjustments. If the sensor is indeed out of calibration or reading slow it could be causing the lean rich condition.
Old 12-17-2012, 11:07 PM   #474
Focus_Sh1ft
Thanks for your thoughts guys.
I do agree it's very possible my afr sensor is bad, but like I've said it's completely irrelevant because open loop is running like garbage. However, I've decided to just get a new one tomorrow and go back to closed loop to continue troubleshooting. I need to eliminate whatever variables I can.
I'm hoping maybe with a new afr sensor and closed loop I'll be able to get the car running good enough to complete a few drive cycles. At this point it looks like I really need code(s) to point me in the right direction.
I run stock injectors at all times, and they check out because all four plugs are getting fouled. Also, I don't have a boomslang, so the best I can do is use the bypass plug and take the FIC out of the equation (which I've been doing).
I'll check the breather tube. There hasn't been any smoking out of it though.
Ironic aside: I just made my last payment on the car a week ago. Funny or depressing, you decide.
Old 12-17-2012, 11:44 PM   #475
Focus_Sh1ft
Here's a summary of what's been done thus far.
x Air induction system --- triple checked
x Injector blockage/leakage --- ALL plugs fouled
x Coils --- throws immediate codes; none thrown
x Plugs --- used three different sets of plugs with varying gaps
x Throttle plate sticking
x MAF meter --- replaced
x ECT sensor --- readings fine
x Gas leakage from exhaust system
x Rear O2 --- pulled; no difference
x PCV hose connections --- no vacuum leaks
x PCV valve
x ECM --- replaced
x Stuck valve --- compression: 195, 195, 205, 205
x FIC --- bypassed or not, runs the same
x Bad gas --- added fuel stabilizer
x A/F sensor (sensor 1) --- replaced
x Integration relay
x Fuel pressure
Old 12-17-2012, 11:56 PM   #476
Bluevitz-rs
Do you know for 100% that the ECU isn't still looking at the AFR sensor when in both open or closed loop. Because simply disconnecting it will just cause the sensor input to put into default values.
Old 12-18-2012, 12:05 AM   #477
Focus_Sh1ft
I can't say for certain, but I've always been under the impression that with the AFR sensor pulled and unplugged, fueling is done using predetermined values based on other sensor data (MAF, ECT, IAT, crank/cam signal, etc.). Scangauge, for whatever reason, doesn't allow you to view A LOT of the OBDII protocol including oxygen sensor information.
Old 12-18-2012, 09:46 AM   #478
yaris2010RS
just pull the plug on your 1st O2, im not 100% it doesnt use that reading even in open loop. i would ensure its not reading it.
what does this mean? are you rulling out injector issues based on the plugs not being fouled? from what your describing, it sounds like it could be an injector sticking issue.
Old 12-18-2012, 01:12 PM   #479
Focus_Sh1ft
No, all four plugs are getting fouled. Even though the afrs are running from super rich to super lean, they're generally on the rich side (especially in open loop). There's no way all four injectors are suddenly sticking. I'd also expect to see a slightly higher compression in one cylinder from carbon buildup.
Also, to be clear, when I run open loop my afr sensor is NOT plugged into the harness and NOT downstream. Therefore no values are being read.
Even though the ecm is ruled out, I still can't get over the nagging feeling that this is somehow electrical (I checked all fuses BTW)...
Old 12-18-2012, 05:45 PM   #480
Focus_Sh1ft
Didn't realize front O2 sensors are $160... For a part I don't even need. Ugh -.-
Old 12-18-2012, 05:49 PM   #481
You can get the generic Denso 2349052 for under $100.
Old 12-18-2012, 06:51 PM   #482
Or one off my shelf.
Old 12-18-2012, 09:02 PM   #483
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
oh now Garm says he has one. :P
Old 12-18-2012, 10:39 PM   #484
Focus_Sh1ft
Bleh, I was using a different denso part number and was only turning up $130 at best. Oh well.
So yeah, no big difference with it in. Car spends a bit more time around stoich but continues to trend toward the lean side. Also, integration relay and PCV valve are fine.
I'm gonna have my mechanic smoke test the intake tomorrow and see if he has any other ideas. I did a typical boost leak test and the intake did hold some pressure, but all symptoms still point to a vacuum leak. Definitely need some peace of mind on this. It's a lot more plausible than something going wrong with a completely stock, completely untouched fuel regulator.
If not, I'm going to drive it enough to complete some drive cycles. I see no other options.
Old 12-18-2012, 11:53 PM   #485
yaris2010RS
$130 is alot for a sensor i have a spare one kicking around in my garage LOL, Should have asked man....
Im sorry to try to stick on one thing, but it sounds ALOT like what my car was doing when the ECM was gone......
Have you done a compression test? good place to loose vac is in the cylinders is a leak test on the intake passed. if this was a vac leak on the hose or cracked intake mani i believe you would get a very unpridctible idle (up and down or really high) with the car running spreay some brake cleaner or WD40 or something flamable and controlable to see if your RPMS go up when you spray suspected spots.
Another shot in the dark (im good at these but that doesnt make them useful) have you checked the condition of your turbo? possibly if its in dire need of a rebuild it could be holding up enough back pressure to screw with things. check from intake and exhaust side. also while your at it check the rest of your exhaust system or some sort of blockage (if you have a cat, check it!)
These are all the things i checked on my car. they went the cause but i had convinced myself they could be
Old 12-19-2012, 05:58 PM   #486
Focus_Sh1ft
Spent the last few hours combing over the car with my mechanic... and nothing.
-Fuel pressure was fine
-Smoke test turned up nothing
-All sensors are within range via OBDII
We were finally able to get a P0171 code thrown, but that's it. The trims were everywhere - off gas they were trimming fuel like crazy, while on gas it was adding way too much fuel. In other words, they've never seen anything like this before.
So at this point, the only thing that can't be ruled out 100% is the ECM. However, the replacement ECM didn't do anything. The one and only remaining cause is a problem with the harness. Here's what I'm thinking
-Sweet talk someone at Toyota into doing some monitoring with the techstream tool. If the ECM is compromised or a short/open in the harness, it should show up.
-If not, attempt to continuity check EVERY SINGLE WIRE on the ECM (dear lord). I don't even know if the information for this is actually readily available.
-If not, attempt to source a replacement harness
Otherwise... We're talking complete engine replacement. I knew the day would come, but I thought it would be because I BLEW the engine, not some electrical BS.
FS: Autometer Cobalt 6170 Boost Gauge Nexus1155 Items for Sale by private party 2 02-02-2011 04:08 PM
Multiple cylinder misfire under boost LtNoogie Forced Induction Forum 13 11-02-2009 04:44 AM
Fill up with Super before starting your boost project LtNoogie Forced Induction Forum 5 12-01-2008 06:41 PM
Supercharger Selection and Limiting Boost Nexus1155 Forced Induction Forum 1 12-01-2008 03:51 PM
WTB: Boost Gauges Teruyume Items for Sale by private party 4 11-12-2006 02:42 PM
