Old 12-19-2012, 05:18 PM   #1
TOLMACH
Drives: soarer
Gauges installation
Trying to plan my blitz project
What adaptors do I need for oil pressure and water gauges, pls?
Oil pressure: 3/4 - 16?
http://www.amazon.com/gp/product/B00...A3Q5L29ROA0I31
Water temperatrue 28 mm? (1 and 1/8 inch)
also there is a bunch of o2 sensor adptors (no-weld type) .. not sure what size is our midpipe (As far as I understand sensor should be installed somewhere between the header and firts cat)
Thanks
Old 12-19-2012, 05:43 PM   #2
TOLMACH
Drives: soarer
Kinda think oil filter thread is m16 because of the below:
http://www.autopartswarehouse.com/sh...ota/yaris.html
Old 12-19-2012, 05:52 PM   #3
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
did you get the blitz kit for the xB or did you get the one for the yaris?
just curious.
Old 12-19-2012, 06:59 PM   #4
TOLMACH
Drives: soarer
Yaris
Old 12-31-2012, 12:50 AM   #5
TOLMACH
Drives: soarer
^ Update..
(I know .. Do not tell me ))))))))
I appeared to have done everything I could not to purchase the right kit.. Really 200% due dill done )) As a final measure I checked pretty much every part from the BlitsUSA SC installation manual against the pic I received from the vendor. It took me three weeks (found pics of Xb/Echo and Yaris TBs on ebay) to realize the Blitz on-line Yaris manual is in fact showing the xb engine.
Luckily changes that are needed are limited to TB spacer/adaptor, TB suport/hanger, and new belt - all those issued were covered in great detail on YW.
The deal I got on mine is kind OK. Not ok was shipping cost to canada and custom duties which means that in case I decide to sell it i am most likely 300 bucks down.
On the bright side, the condition of the kit is better than expected- had concerns about the pulley/bearings of the Sc itself - both look/rotate/engage (if both the pulley and the clutch plate are rotated together) super smoothly (btw, SC "Intenstines" look kinda scary))))). Condition of the tensioning pully is between very good and excellent - there is hardly noticable play between the bearing and pulley body itself (smth like 0.2 mm) but the bearing itself looks totally good. The only missing part so far is the 16 mm collar for the tensioning pulley - there is lots of stuff in my nearby H.Depot that I can replace it with. I suspect I might miss some of the bolts / spacers / will buy a metric kit prior to install plus will check everything against the manual.
Plans re TB adaptor: if I can not find a machine shop which would be able to fabricatew one for me, will buy smth undrilled like this and try to adjust it (couple days with a good file can do miracles - I am amazing at repeatedly doing stupid labor intensive tasks thanks to my Car-audio hobby). http://www.jegs.com/i/Edelbrock/350/38123/10002/-1
(I also found a good drawing of our TB made by CrankyOldMan (Thank you C.O.M.!!) http://photo.qip.ru/users/tolmach/96608749/129780369/)
CAI - will either adjust/ cut my TRD CIA or (most likely) buy a cheap straight aftermarket tube with MAF holder.
Old 12-31-2012, 12:57 AM   #6
TOLMACH
Drives: soarer
Some pics
Old 12-31-2012, 10:11 PM   #7
Tima122
Drives: bB NCP 31 2005 y
Happy New Year!
In any case, set the meter EGT and A / F
Tima122 is offline   Reply With Quote
Old 12-31-2012, 10:16 PM   #8
Tima122
I have installed an ECU
File Type: jpg gns_spl-img600x450-13260743143vmorj35004.jpg (34.5 KB, 81 views)
Old 12-31-2012, 10:35 PM   #9
TOLMACH
Drives: soarer
Спасибо, Тима (Я кстати сам с Дальнего Востока )))
С наступающим! (У вас уже наступившим)
Old 01-01-2013, 12:21 PM   #10
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
http://shop.microimageonline.com/Oil...OS-osa-001.htm
To your first post and I understand you prob already bought these already. but in case you havent
http://shop.microimageonline.com/Wat...temp-adap1.htm
-Derrick-
Old 01-01-2013, 03:17 PM   #11
TOLMACH
Drives: soarer
^ Appreciate, thank you!
DIY: 2006-2011 Yaris OEM Cruise Control Complete Installation CTScott DIY / Maintenance / Service 172 10-27-2025 03:04 PM
Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder bieniman DIY / Maintenance / Service 4 05-20-2009 12:40 AM
Mechanical vs Electric Gauges? PETERPOOP Forced Induction Forum 13 04-06-2009 02:25 AM
WTB: Boost Gauges Teruyume Items for Sale by private party 4 11-12-2006 03:42 PM
