Old 01-10-2013, 12:52 PM   #19
^ yes, it is homemade.
Old 01-10-2013, 12:54 PM   #20
Oh.
Old 01-10-2013, 01:40 PM   #21
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by discomark10 View Post
I fabricated it myself as they cost the equivalent of around $250 here...
I'm going to have to either fix or remake it, if resetting the ECU reset fails.
It only cost about $15 to make out of stainless, so a bit cheaper!
Old 01-10-2013, 02:04 PM   #22
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Hey disco, can you post a pic of your intake? Maybe if we can see it, we can help you figure out how to make it work. I admire that you're adventurous enough to try to make one up. I just measured the outside diameter of the two intakes I have:
Weapon R 57mm
Simota 59.5mm
Both work fine, and the difference might be the wall thickness of the tubing. I'll need to disassemble them to get the more accurate inside measurements. How your MAF sensor is positioned relative to the center of the tubing is important. Maybe spacing it up or down will help. I'm taking the intakes apart today to get a better fit on the throttle body so I'll take some measurments and let you know.
Greg
Old 01-10-2013, 02:22 PM   #23
The ID of my PRM Jetstream intake is 2.25".
Old 01-10-2013, 04:22 PM   #24
discomark10
Drives: 02 Yaris 1.5 T-sport
Greg
I wont be able to get a pic until Sunday or Tuesday now as im back on shift :(
But it looks allmost identical to this http://www.ebay.com/itm/400295390141...=38634&vxp=mtr
(yay for google!)
Greg
As for positioning, I'm pretty sure it was well centred, if I remake one ill make sure its positioned as good as I can.
Weapon R 57mm
Simota 59.5mm
Awesome thanks, is it the same size tubing for the bit you measured all the way along the length?
discomark10 is offline   Reply With Quote
Old 01-10-2013, 04:27 PM   #25
Yes.
Old 01-10-2013, 05:42 PM   #26
discomark10
I think this should do the job.. http://pages.ebay.com/link/?nav=item...d=280776018618
WTB Forced Induction kit JohninVT Willing to Buy by private party 5 11-12-2012 04:24 PM
how to fit induction kit to my p1 daveyboigt Performance Modifications 0 10-21-2012 06:06 PM
Induction air filter on yaris diesel - good or bad?!?! Ziishan DIY / Maintenance / Service 3 10-20-2012 09:43 AM
VIS jdm rs body kit Dperry Cosmetic Modifications (Exterior/Interior) 2 05-07-2012 12:00 AM
Greddy xB kit vs Greddy Fit kit ellenbetty Forced Induction Forum 52 09-29-2009 09:42 PM
