Old 02-23-2007, 01:48 PM   #19
ChinoCharles
Drives: LB
OEM Toyota Pulley - 50.00 oz
ZPI pulley - 14.4 oz
NST pulley - 12.5 oz
The DIY has been edited to include this information. Thanks for your PATIENCE.
Old 02-23-2007, 03:34 PM   #20
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
'bout damn time.
Old 02-23-2007, 03:37 PM   #21
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
75% reduction
Old 02-27-2007, 10:29 PM   #22
"G"
Drives: 2007 Yaris Hatch
quick question that "shitty" stock pulley has a rubber material towards the inside right ?
"G" is offline   Reply With Quote
Old 02-28-2007, 11:47 AM   #23
jmew0ng
Drives: Scion FRS
i smell harmonic balance thread whatever coming around .___.
jmew0ng is offline   Reply With Quote
Old 02-28-2007, 02:49 PM   #24
forpinks
forpinks's Avatar
Drives: 03 Toyota Corolla S modded,
can it improve fuel economy?
THE YARIS: TINY BUT PRICEY!
BUT YOU JUST GOTTA LOVE IT....
forpinks is offline   Reply With Quote
Old 02-28-2007, 07:06 PM   #25
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
Any weight removed from the vehicle improves MPG. Simple fact.
jdubau55 is offline   Reply With Quote
Old 03-01-2007, 01:20 AM   #26
spkrman
Drives: 1
maybe I cant get 40mpg because I'm a l@rd @$$
Old 03-01-2007, 07:26 PM   #27
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Though I do agree with you that less weight is better for MPG, when were talking rotating mass, this is not true.
A crude explanation: as you start to decrease rotating mass by lightening things like the pulleys and the flywheel, MPG may suffer. The engine revs faster and once spun up it takes more gas to keep things going. Lower mass will take less time to dissapate the energy put into it. Toyota knows this and has designed certain portions of the drivetrain to take advantage of rotating mass for optimal mpg. The pullys are one of these portions. Gains or losses in mpg will be most noticeable on the highway. Around-town should remain the same or maybe get better. Maybe. The main reason for a possible decrease on the highway is that the RPM at which the engine wants to 'cruise' will likely be eliminated. This is due to a less efficient energy storage system. Anyway, wtf do I know. With only the pulley changed out and the flywheel the same, there likely wont be much change.
Galavoxx is offline   Reply With Quote
Old 03-01-2007, 07:30 PM   #28
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Hey Chino... how is the idle? Notice any difference or have to make any adjustments?
Old 03-01-2007, 10:11 PM   #29
That's true, at a constant rotational speed, a heavier weight acts as a "buffer" that keeps the rotation steady (think of a spinning top). So, less input is required from the motor to keep the rotation, and gas can be saved. But compared to the frictional forces from air drag, and the fact that the flywheel weighs a lot more than a single small pulley, I don't think it will make such a huge difference.
BUT! In order to get the rotation up to speed, there is more inertia to be overcome (think of how much effort you spend spinning a small, light top vs spinning a larger heavy one), which is where more fuel is required. So, in this kind of stop-and-go traffic situation, less rotational mass can have a good effect on performance and mileage.
Of course, the disadvantage of removing rotational mass in a 4-cylinder daily driver is the idle quality. The engine needs the heavy weight of the flywheel to keep it going during the 3 non-power strokes. So, when you reduce this mass, the engine will slow down between rotations, and at a lower engine speed (idling), this can make things very rough, even stall the engine.
But, as I mentioned before, 80% (if not more) of the rotational mass in our engine/transmission would be from the flywheel, so a ligher crank pulley should not be such a big difference that it can cause problems.
At least that's what my physics education tells me, I can't wait to see the effects for myself
Old 03-01-2007, 10:18 PM   #30
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I think you explained it better. but I tried...
Old 03-01-2007, 11:00 PM   #31
A for effort
ah this "education" had to come in useful sometime.. I used to love physics, best in my class... but that was many many moons ago
Old 03-01-2007, 11:56 PM   #32
ChinoCharles
Drives: LB
I definitely didn't have to make any adjustments. Within 5 minutes of the install I was back on the road again. No issues.
Old 03-02-2007, 12:06 AM   #33
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Good to know. Now where's my damn pully!!!
Old 03-02-2007, 12:14 AM   #34
ChinoCharles
Drives: LB
I just got word pulleys should ship out mid next week. Let the crying begin!
Old 03-28-2007, 04:10 PM   #35
Astroman
Modded Moderator
Astroman's Avatar
I have mine installed. Love it! Thank you Chino Charles!
Old 03-28-2007, 09:41 PM   #36
ChinoCharles
Drives: LB
Astroman, can you feel the difference in rev speed? Engine idle? What is your take on it?
