Old 01-21-2013, 11:29 PM   #523
yaris2010RS
yaris2010RS's Avatar
IMO put her back together and see if shes magically back to life
Old 01-22-2013, 12:15 PM   #524
Focus_Sh1ft
Focus_Sh1ft's Avatar
At this point, that's basically where I'm at. I'm convinced magic is the only thing that will solve this problem lol...
Hopefully something turns up with the head. On the flip side, at least I'll have completely ruled out any type of mechanical failure.
Old 01-22-2013, 12:36 PM   #525
^ It's a small club of people who have been able to look at their piston tops.
Old 01-22-2013, 01:14 PM   #526
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Ain't that the truth!
Old 01-22-2013, 01:33 PM   #527
yaris2010RS
http://www.yarisworld.com/forums/showthread.php?t=43412
We will see.....
Old 01-25-2013, 11:25 PM   #528
Focus_Sh1ft
Got the head back today, no warpage.
Also, big thanks to Adrian (fnkngrv) for sending me an extra timing chain cover.
Should have everything back together early next week...
Old 01-25-2013, 11:29 PM   #529
fnkngrv
fnkngrv's Avatar
No problem man. You have been a great resource for information as I was doing my turbo install and tweaks along the way. Your knowledge helped me immensely along with Carlos, Garm, Scott, and Brian.
Old 01-28-2013, 08:42 PM   #530
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I should get on here more, I miss a lot and I think I could have helped a while ago. I haven't read everything but kinda glanced at you issue. A stock 1nzfe will blow a rod and crack ringlands way before blowing a head gasket, as result of detonation.
As for your misfire isues, make sure you have plugs gapped to probably .030 in. If you have done that already..... your FIC is faulty or you are in need of a resistor on the crank signal wire on the FIC harness. This was a common issue with running the FIC on a Scion tC a couple years back. Even AEM's own p&p harness needed a resistor wired in, until they got enough phone calls about it.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 01-28-2013, 09:43 PM   #531
Focus_Sh1ft
^ I wish you did chime in sooner, because it took me tearing into the engine to realize the head gasket wasn't the issue lol.
Made some progress today. However, it all came to a grinding halt when I stripped one of the head bolts...
I got it pretty tight before it happened, the others are only about 1/4 turn tighter and are the correct torque. I'm severely worried that will be enough to cause compression loss though...
Once I get the timing chain back on (and timing aligned), could I possibly run the starter and do a normal compression test? Really don't want to put everything back together just to find it was [even more of] a waste of time.
Old 01-29-2013, 03:39 PM   #532
Focus_Sh1ft
Did a faux leak down test of sorts. Put 140 psi of compressed air in each cylinder at TDC, valves closed. I don't have the gauges to measure percentage, but all four lost air at a nearly consistent rate, so we're still good to go
Old 01-31-2013, 07:39 PM   #533
Focus_Sh1ft
Engine is back together and is running the exact same.
So, it's back to the drawing board... At least I didn't make things worse lol.
Old 01-31-2013, 08:59 PM   #534
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
That blows, I think all of us that have fucked around with cars long enough know your pain. I know I been their
pimp my yaris is offline   Reply With Quote
Old 01-31-2013, 09:13 PM   #535
Did you ever get a chance to have someone connect up a techstream?
Old 01-31-2013, 09:25 PM   #536
fnkngrv
fnkngrv's Avatar
wonder wtf if the issue at this point
Old 02-01-2013, 11:36 PM   #537
Focus_Sh1ft
Yes, at the dealership. All we got were P0300-0303 and P0172 (none of which were showing up on my code readers...). Everything else appeared to be working okay with the ECM.
Things are definitely beyond desperate at this point. Let's just say I never thought I'd bring any car I ever owned to a dealership.
I've come up with a few other things to check, but at this point it's just taking shots in the dark...
Old 02-01-2013, 11:39 PM   #538
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Did you pull the pistons out and check for broken rings or ring lands. Could be causing blow by at the much higher pressure of expanding brining fuel than just a compression test.
Old 02-01-2013, 11:51 PM   #539
Focus_Sh1ft
I didn't... But on all four cylinders? I'll listen to any possibility at this point though. Is there any way to test for that without physical inspection?
Old 02-01-2013, 11:52 PM   #540
Bluevitz-rs
Idk
FS: Autometer Cobalt 6170 Boost Gauge Nexus1155 Items for Sale by private party 2 02-02-2011 04:08 PM
Multiple cylinder misfire under boost LtNoogie Forced Induction Forum 13 11-02-2009 04:44 AM
Fill up with Super before starting your boost project LtNoogie Forced Induction Forum 5 12-01-2008 06:41 PM
Supercharger Selection and Limiting Boost Nexus1155 Forced Induction Forum 1 12-01-2008 03:51 PM
WTB: Boost Gauges Teruyume Items for Sale by private party 4 11-12-2006 02:42 PM
