![]() ![]() ![]() Drives: 08Yaris2D, 88LandCruiser. Join Date: Jan 2013
Great Oil for cheap!
Hi all, I'm new to Yaris, but a 30 year plus Toyota owner.
I'm sure this is nothing new, but I found some great oil for $5.4 per Qt. Mobil1 extended service @ Walmart for $27. per 5 qt jug. Regular auto parts stores are selling this stuff for $9.99 per qt. http://www.mobiloil.com/USA-English/...nce_5W-30.aspx |
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jan 2013
QSUD for $.97 after rebate is a better deal
Mr. 155 and climbing
3k/3 month interval:
Conventional Oil 10w-30 (40qts needed for 25k miles) @ $3.00/qt * 40 = $120.00 8 Standard Filters @ 6.00/filter * 8 = 48.00 Total: $168.00 AMSOIL 25k/1 year interval: AMSOIL 10w-30 (5 qts needed for 25k miles) @ 7.35/qt * 5 = $47.75 1 EaO Filter @ 18.30 Total: $55.05 Savings: $112.95 annually Even if you only drive 12k miles per year you are saving just in oil/filter costs not to mention the following benefits: - Easier cold-temp starting - Improved fuel economy over time - Cleaner running engine - Cooler running temps - Should experience more power/throttle response - Less engine wear - Longer intervals between changes which means less inconvenience of the car being at the shop
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
Shell synthethic for $3.33 a quart ( before tax ) . Will be posting an used oil analysis of SHELL synthetic 5w-20 from the '08 sedan within a few weeks .
#5 | |
Still most likely good oil.
+1 for Amsoil. I've been using them for at least 4 years (annual changes only, drive 12k-15k miles a year). Best stuff! I did a compression test last year around this time, and had around 78k miles on my car. Got 204 psi (give or take 2 psi) for each cylinder.
| Natural Gas Transportation - Why Not? | Kal-El | Off-topic / Other Cars / Everything else Discussions | 1 | 03-20-2011 01:12 PM |
| DIY Oil Pressure Gauge Install | LtNoogie | DIY / Maintenance / Service | 13 | 11-20-2009 04:13 PM |
| Gear oil change choices (Canadians) | Jem_hadar | DIY / Maintenance / Service | 17 | 08-29-2009 11:51 AM |
| Question About Engine Oil | Kaotic Lazagna | Off-topic / Other Cars / Everything else Discussions | 21 | 08-29-2009 03:08 AM |
| embarrassingly bad mileage... REALLY | XYaris | Fuel Economy Forum | 83 | 05-05-2009 04:47 PM |
