Old 01-28-2013, 10:05 PM   #361
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Originally Posted by Yoda View Post
Been gone for a minute but the project is back on. Had to use my fiances to help my family out and such. Engine is undergoing rebuild right now. Trying to decide if i should get it sleeved or not. I wont be pushing more than 300whp and I remember Blown Xa doing a few runs on that power level no problem. Also going to need a new manifold cause the ones I have don't suit the larger turbo well (no room).
50,000 miles so far on factory sleeves, no excessive blow-by indicating cylinder distortion. Haven't done a leakdown test in a while, but the last one was good.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 02-13-2013, 11:07 PM   #362
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Do you think I need to get my IC piping welded? I could save about $500 just by cut and clamp. What worries my is the 20psi I will running. Open to suggestions
Old 02-13-2013, 11:33 PM   #363
Focus_Sh1ft
Focus_Sh1ft's Avatar
Are you worried about blowing couplers off? My tC pushes 22 psi with silicone couplers and t-bolt clamps with no issues. I did have problems with a vacuum plug being blown off... That was fun.
Definitely opt for t-bolt over worm gear at that point.
Old 02-13-2013, 11:59 PM   #364
24 psi here, no issues with silicone couplings or fittings. A lot of clamps would make me nervous though.
Old 02-14-2013, 08:59 AM   #365
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
20 psi and my couplers are holding. Are U running a FIC or a standalone? My FIC is maxed out at 20. 15psi atmosphere plus 20psi boost runs to the top of the FIC map at 35.
pimp my yaris is offline   Reply With Quote
Old 02-14-2013, 10:47 AM   #366
Yoda
Yoda's Avatar
Running the fic still but if I am able to save a few here and there I will be upgrading to standalone. Garm did you have to modify anything to get your turbo to fit back there? Think I still have your manifold in my garage.
Old 02-14-2013, 01:23 PM   #367
^ I remember having to clock it, and I insulated the firewall, but otherwise it fits okay.
Remember, we now offer plug 'n play AEM EMS + Boomslang harness. Best of all worlds, and certainly the way I would have done it.
Old 02-14-2013, 06:24 PM   #368
Yoda
Yoda's Avatar
Ok cool I may take you up on that offer. My FIC is wired in gonna be a pain to remove .
Old 02-14-2013, 10:55 PM   #369
Focus_Sh1ft
^ Just throw the bypass plug in and be done with it.
Old 02-15-2013, 02:59 PM   #370
pimp my yaris
C'est la vie
What's the price on that Aem Ems boomslang combo Garm? We need a YW discount.
Old 02-15-2013, 04:45 PM   #371
Yeah but then he's stuck with the FIC sitting there. Gotta be some resale value there!
Old 02-18-2013, 06:45 PM   #372
Focus_Sh1ft
True. I wonder if AEM sells just the universal harness (and if so, for a reasonable price).
The thought of having to remove that harness after it's installed is worth no worldly sum of money to me for the effort involved, lol.
Old 02-18-2013, 07:23 PM   #373
Yoda
Yoda's Avatar
LOL i know right
Old 02-20-2013, 02:02 PM   #374
Yoda
Yoda's Avatar
Question did anyone need to change to tolerances when installing the pistons? I think it says 35 thousandths but not sure if it should be more for my boost level
Old 02-20-2013, 02:09 PM   #375
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Piston to wall clearance?
Old 02-20-2013, 08:02 PM   #376
Yoda
Yoda's Avatar
Yea that.
Old 02-20-2013, 08:04 PM   #377
Bluevitz-rs
It's different if you're using forged or cast pistons. Each has a different expansion rate so you'll have to do a bit more research to get it correct.
Old 02-24-2013, 10:05 PM   #378
pimp my yaris
C'est la vie
I went with the standard piston size. I beleve it was 75mm. I did not have a proper cyl. Bore guage. I have a little to much clearance. Noisy piston slap when the motor is cold. It gets a lot more quite when the motor is warm. It sounds like a old VW diesel. I have beaten the shit out of it with no problems yet. No oil burning at all. Its just sounds shitty when cold. Both Garm and blown xa said they have some piston slap noise. I beleve you can have some tighter tolerance on forged pistons as opposed to cast because they dont expand as much. This would explain my noise. I dont know what sizes you can by for custom cp pistons. I know 75 and 75.5 mm are available. Best to measure with a bore guage. And remember pistons are not perfectly round.
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 11:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 12:59 PM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 01:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-27-2007 12:18 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 09:45 PM
