Old 02-24-2013, 10:07 PM   #1
2005rs
Drives: 2005 Echo Rs
really small turbo
I had a $40 ct12 turbo fall into my lap the other day. I know it's too small for best performance on a 1nzfe, but would it work for improving torque at mid-range?
I'm thinking around 5psi boost, and if boost fell off towards redline, that wouldn't be a bad thing in my mind.
Besides the logistics of making the thing fit, is there a downside to using this turbo?
2005rs is offline   Reply With Quote
Old 02-25-2013, 04:35 AM   #2
thefalls
Drives: Axio GT
There are a few types of ct12 turbo. One comes from the supra and other one from the toyota hiace diesel, i think.
Now on a 1.3l [4efte] with the ct12 i used to get full boost at 2,500/800 rpms or so. On a 1.5l it will be way lower,but not very recommended in a 1nzfe. It will improve torque but the expense of fitting it outweigh the benefits,in my opinion.
The ct12 from the supra is slightly bigger than the one from the Hiace but i still think its better to go for a td04 [small one] and it will give better top end.
thefalls is offline   Reply With Quote
Old 02-25-2013, 10:58 AM   #3
2005rs
Yes, when I did some initial research, I thought the tercel was a 1.5l engine. I bought the turbo knowing full well that it may not be suitable, but that I could likely get my money back.
Full boost at 2500 or less would be awesome. Less than full boost above 5000 would be fine by me. If it becomes an air restriction, obviously that would be a fail.
Anyway, nothing is happening until the temps are above freezing.
I appreciate hearing from someone who has experience with this turbo.
I think this one is off a supra, but I'll have to google some images to see. The previous owner found it on the back seat of a used car he bought. I have no other history on it. There is a tiny amount of side play in it and seems to be in otherwise good shape.
Old 02-26-2013, 04:26 AM   #4
thefalls
Drives: Axio GT
Post a pic,then i may be able to help you more.
Old 02-26-2013, 04:28 PM   #5
2005rs
https://docs.google.com/file/d/0B21J...VuMEhjbzQ/edit
https://docs.google.com/file/d/0B21J...VyMmFUa1U/edit
Seeing if this works. 2 pictures of the ct12
Old 02-26-2013, 08:29 PM   #6
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Originally Posted by 2005rs View Post
nope. says you have to request access.
Colin Chapman disciple
Old 02-27-2013, 05:45 PM   #7
maxthehax
maxthehax's Avatar
Drives: Echo HB Turbo 6Speed
I had an experience with a very small turbo -- Garrett GT1548
http://turbobygarrett.com/turbobygarrett/turbocharger
So I though I could share :P
Before I start explaining the whole situation/setup I will give you my main idea about a ''too small'' turbo; ''NEVER AGAIN''
1. When a turbo is too small, it is not working in is efficient area... I burnt 2 GT1548 because it was too small, overtime it put too much stress on the CHRA, with both brand new turbo the wheel fins scrapped the housing!
2. Low rpm power was a great gain over stock, lets say amazing :P But high end was a real bull****, N/A 1nzfe was faster at high rpm or high speed 100km/h+ :/
3.If you still choose to go small, get at least 3inch exhaust system from turbo to the back. My setup used a 2¼inch full turbo back straight pipe. Smaller turbo = huge exhaust, because smaller turbo creates a lot of backpressure!
I am now running a Garrett GT2252 turbo, this is the smallest turbo I would use with a stock 1nzfe engine & the CHRA is journal bearing so cheaper than ballbearing. I also got an extra Garrett GT2554R ballbearing which is the best turbo for a 1nzfe up to 200whp.
The GT2252 turbo is alright with my 2¼ exhaust, much less backpressure than the GT1548. Still 3'' would be the best.
I put the link for garrett website so you can compare my GT1548/GT2252 to yours!
maxthehax is offline   Reply With Quote
Old 02-28-2013, 07:29 PM   #8
2005rs
http://db.tt/fsdTVowF
http://db.tt/eLT5NYtP
Just a couple of links to show what I have but from what maxthehax's experience was like, I think I'll put it up on eBay or maybe save it for the lawn tractor.
Old 03-01-2013, 02:51 PM   #9
maxthehax
maxthehax's Avatar
Judging by the picture, the exhaust size of the turbo looks smaller than my
GT15! :O
If so, I would get rid of it right away just like you said.
Good luck, Im sure you will find a better turbo :P
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-10-2012 12:35 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 12:59 PM
another small update on turbo kit. joey1320 Forced Induction Forum 6 08-23-2007 05:51 PM
small update on turbo project... joey1320 Forced Induction Forum 26 08-03-2007 05:29 AM
