Old 02-24-2013, 10:53 PM   #379
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Pistons should be perfectly round. A worn cylinder bore might not be though.
Old 02-24-2013, 11:58 PM   #380
I think we have 76mm also.
Old 02-25-2013, 02:02 PM   #381
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
I have the 75.5 mm one. Might be getting a custom manifold made for the turbo. Cant fit it in there with the waste gate I was looking the the PT tuning one but not sure if it would fit back there.
Old 02-25-2013, 02:13 PM   #382
Why doesn't it fit? I have the same manifold I sell and mine fits back there.
Old 02-25-2013, 03:41 PM   #383
Yoda
Yoda's Avatar
I have a internal wastage .
Old 02-26-2013, 01:00 PM   #384
Yoda
Yoda's Avatar
So my choices are as follows:
Order new external mani from MI and find an external WG
Have a manifold custom made
Sell everything and just get a new car lol.
This unforseen expenditure will delay me a bit longer.
Old 02-26-2013, 01:43 PM   #385
They buy the one without a wastegate flange. It's offered both ways on our site.
Old 02-26-2013, 03:04 PM   #386
Yoda
Yoda's Avatar
Sorry if I was not clear. The internal wastegate is what is preventing it from fitting. It hits the firewall.
Old 03-26-2013, 08:30 AM   #387
Yoda
Yoda's Avatar
Last few parts I was waiting on have come in. New manifold and wastegate. Just one more thing to get... AEM EMS with pnp harness. I cant wait
Old 06-22-2013, 02:12 PM   #388
Yoda
Yoda's Avatar
Small update
Finally got all of the parts needed. Engine done and going in.
About 2 more weeks of work.
Old 07-04-2013, 12:39 PM   #389
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
looks awesome.
-Derrick-
Old 07-30-2013, 07:22 PM   #390
Yoda
Yoda's Avatar
Exclamation
Went to the shop just to see how they were doing. Its pretty much all done but one problem is getting the TPS issue with the Haltech Sprint sorted out. The issues is that the Haltech is not reading the throttle position accurately. If he puts 50% throttle it reads between 70-100%. Tried a couple different settings but nothing seemed to fix it. Now were trying to figure out if it is tapped in the right location. I think its in C20-115 right now. Are there any other possible pin locations or settings I may have missed?
Anyway here are a few pics
Old 07-30-2013, 08:24 PM   #391
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
what does it read a t closed throttle? sounds like it is off keyed but further testing would be needed to determine for sure.
Old 07-30-2013, 08:35 PM   #392
Yoda
Yoda's Avatar
Cant member what it was. I know the blitz guys use A21-55 for an input not sure it would work for me but I will try anything at this point. If I get this solved then by Friday i will pick her up.
Old 08-01-2013, 01:33 PM   #393
Yoda
Yoda's Avatar
Anyone have any ideas? Seems like the FI section went belly up.
Old 08-01-2013, 02:48 PM   #394
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Is this possibly a drive by wire issue? Are you still using the stock ECM for DBW?
Old 08-01-2013, 03:33 PM   #395
Yoda
Yoda's Avatar
Still using the stock ECU for DBW.
Old 08-01-2013, 05:38 PM   #396
fnkngrv
fnkngrv's Avatar
Have you reached out to Carlos to ask him yet?
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 11:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 12:59 PM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 01:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-27-2007 12:18 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 09:45 PM
