Old 02-27-2013, 12:52 AM   #1
yariseggvvti
Drives: Yaris Hatchieback
Vehicle Flick
While I was driving, the vehicle flick. The light goes off and come back right away. After it flick and I keep driving nothing happen again. This happened the past two day when I drive with the lights on.
Check battery is 12.85 voltage. When the vehicle is running is read 13.85 voltage.
Current mileage 74k and replace OEM alternator 4k ago.
Any idea???? Please help!
yariseggvvti is offline   Reply With Quote
Old 02-27-2013, 06:34 AM   #2
Check the large connectors that plug into the battery terminals. In the past a couple of people have had issue with those connector pins being severely oxidized, causing similar behavior.
Old 02-28-2013, 03:02 AM   #3
yariseggvvti
I will check them out this weekend. Thanks CTScott!
Dose the ground kit defect anything in the vehicle? I got a ground kit running in the vehicle. I notice the battery is needs to start the vehicle. Once the vehicle start is running by the alternator not the battery any more. Is that true ?
Old 02-28-2013, 06:08 AM   #4
The ground kit should not effect anything. With modern vehicles the battery acts as filter for the alternator output, so the battery has a purpose even once the vehicle has started.
Old 03-02-2013, 03:16 PM   #5
yariseggvvti
CTScott, I had check everything and I dont see any wrong wit it. All ground cable is connect and tight. Could it be the ignition problem or air, fuel. Vehicle basic running on those three things. Either one failure can be the problem. ThX!
Old 03-02-2013, 03:33 PM   #6
When you say it "flicks" do just the lights flicker, or does the engine stop running briefly?
Old 03-03-2013, 02:57 AM   #7
yariseggvvti
It just complete lost everything for a sec and come back up. The first time happened to when I come to the stop light. The vehicle lost all the power and come back up in just sec. I can feel the steering wheel very hard to turn. The second time I was driving on the freeway. Suddenly the light was out and came back up.
Old 03-03-2013, 07:29 AM   #8
If everything is cutting out, then I would not suspect ignition, fuel, etc., as the lights would still stay on if the engine itself cut out for a second. I would try wiggling connectors with it running, like the ignition switch connector, to see if you have a loose terminal.
Old 03-03-2013, 11:57 AM   #9
hw6515
Drives: 08 Yaris AT, 350Z GT MT
At 75k miles I would replace the battery (if you have not done so already).
As Scott said, carefully inspect the battery connectors, remove them both, (Ground first) and clean or replace them if need it.
Clean the battery side as well. If the alternator was replaced, check the connections as well.
Give Scott more info, if anyone can help you here, he is probably the ONE :)
hw6515 is offline   Reply With Quote
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
2012 Ford Focus ELECTRIC Kal-El Off-topic / Other Cars / Everything else Discussions 11 02-11-2011 11:34 AM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
problem car conurebuddy General Yaris / Vitz Discussion 23 04-11-2009 12:37 AM
