Old 03-04-2013, 05:06 PM   #1
mankypurple
Drives: 08 yaris
cruising w/o cruise control issue
My 08 yaris, automatic is having an issue. Every now and then it starts driving by itself. The cool light will come on and it will accelerate without my foot on the pedal. If I pop it in neutral it starts rev hunting bad. Or it idles really low and vibrates the car. I was thinking the pedal position sensor or throttle sensor might be to blame, but than again ive always owned manual minI coopers. This is my wifes car. I'm a little lost with its workings. Please help. Any advice is greatly appreciated.
mankypurple is offline   Reply With Quote
Old 03-04-2013, 05:25 PM   #2
If the cool light comes on with the car warmed up, then the coolant temp sensor may be bad. The engine will idle at a higher RPM when the engine is cold (or the ECM thinks it is cold). If the cold light did not come on, then I would suspect the throttle position sensor.
Old 03-04-2013, 05:28 PM   #3
mankypurple
Drives: 08 yaris
When its actually cold it doesn't rev hunt or accelerate while in drive. I just noticed it was on everytime it acts up.
Old 03-04-2013, 07:46 PM   #4
Kar98
Drives: 2011 Scion tC
Now there's something you absolutely need to have a qualified Toyota dealership looked at. Do. It. Now.
Old 03-04-2013, 07:47 PM   #5
That is part of what makes me think the sensor is bad. The engine isn't cold, but the system is acting like it is, so it ends up fighting against itself to run rich for the cold, but at the same time it isn't running like it is cold, so it fights back to stoich. Do you per chance have an OBDII device that you can use to monitor what the ECM thinks the coolant temp really is?
Old 03-05-2013, 11:23 AM   #6
mankypurple
Drives: 08 yaris
At the moment, I do not. The check engine light is on. I'll get that scanned at autozone today if I can. See if that gives any clue.
Old 03-05-2013, 11:26 AM   #7
That would definitely help to narrow it down to either the coolant temp sensor or the throttle position sensor.
As mentioned above, if it really feels like it is running away, you should not risk it and should probably get it to Toyota ASAP.
Old 04-18-2013, 11:55 AM   #8
mankypurple
Drives: 08 yaris
well, turns out the cel was for the coolant temp sensor. I bought one. but im having trouble locating where it goes!
Old 04-18-2013, 02:46 PM   #9
Take a look a few posts down in this thread for a picture of the location of it:
www.yarisworld.com/forums/showthread.php?t=37691
Old 04-29-2013, 06:57 PM   #10
mankypurple
Drives: 08 yaris
Alrighty. Found and replaced!!! But, it didn't fix my revving problem. :-( so I'm back to being lost
Old 04-29-2013, 07:00 PM   #11
Has the check engine light come back on since you replaced the coolant temp sensor?
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
Rostra 250-1731 cruise control kit for Yaris PeetYaris In Car Entertainment + Electronics (audio / video / alarm) 5 06-26-2011 07:48 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
