#37 |
True.. I wear glasses daily so for those who have perfect vision tend to not where any protection what so ever. I used a face shield because one got me right in my nostril.. very awkward feeling, alot of sneezing involved.
#38 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
I have 20/17 vision, I will always put on safety glasses, and if dealing with fluids or batteries, goggles.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#39 |
Safety is cool.
#40 |
nice. I love my CRXs. They are like my children (according to my landlady!)
I'll be checking this one from time to time! Dude, you need to move to California. We can go racing in STF, and you can get another CRX, and we can go to the CRX meets out here! (oh, and you can rebuild my engine! haha) |
#41 |
U pay for shipping and cost of parts. I will rebuild you a 'd' or 'b' series motor no charge in labor. I have been really busy with this wedding. Another reason why this is taking a while. Also he is ordering all his from majestic.com some online honda dealer in new jersey. Half the price than my local dealer.
#42 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
Majestic does have good prices.
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
#43 |
My buddy Jason has one really clean CRX, and he tends to get his OEM goodies from Majestic as well.
Thanks Rice ! !! ! That's a heck of a deal :) I'll let you know when I'm ready for a rebuild (car stll running fine) |
#44 |
I had already used plati-guaged the bearing to check.. Forgot to grab the camera.
Used assembly lube putting the bearings back in and the crank and main caps are on.. Rotates smooth. Also checked crank end play. All within spec. last pic, got the oil pump, water pump, tensioner and oil pickup on. They guy only order 1 set of piston rings.. lol.. so gotta wait for the rest to come in before I can do Rods. At another road block til that happens. These bearins are done by color codes, gotta match the number on the block with the numbers on the caps to get the correct bearing. easy once you understand what your doing.
#45 |
update:
5 valves got here. 3 were on back order.. still waiting on piston rings though.. ugh..
#46 |
you need to do a video on how to do the bearings using the color codes!
that always throws me off ! ! |
#47 |
I can do that. I think. If not a video at least bunch of pictures. Lol
#48 |
slideshow then :D
#49 |
LOL at slideshow.
Actually, that would be good too ! ! |
#50 |
![]() ![]() ![]() Drives: 2012 Yaris SE Join Date: Nov 2011
I've had 3 CRX Si, two 1987 and 1988.
They will never make a car like that ever again. Really special! |
#51 |
You said it NJ.. Parts will be arriving tomorrow. Will be doing alot of work on it this weekend. Hopefully will be finished being assembled. Then will have to plan a weekend for him to bring the car back to finish putting it in.
#52 |
![]() ![]() ![]() Drives: '10 Yaris LB Polar White Join Date: Oct 2010
First time seeing this thread, I'm always amazed of having the ability,skill and patience for motor rebuilds.
#53 |
Ok, I did most of this last weekend. I haven't had a chance til now to post these up. Been really busy lately and rarely on the computer. Here is the latest.
THere is a big gap from when I put the head on to putting together the timing belt and stuff. I got carried away and so into the build I forgot to grab the camera to take a picture before the cover went on. Last picture is as it stands now. Gonna do valve adjustment tomorrow and hopefully finish it and have it ready to be dropped in the car.
#54 |
Ok, someone was asking how to figure out bearings using the coded numbers and colors.
Ill just do the rod bearings for now. Time is limited for me so this is going to be kinda quick. Sorry, I don't have time to put a slideshow up or video. Pic 1 and 2: each rod has a number that is cut in half on the side of the rod bearing. by matching up the number you will get a 1-4. In my case I had 2-2-2-3. Pic 3: on the crank there are letters stamped on the crank once by each in front of each rod journal. as U can see on the picture with the bearings and notebook, I had B-C-B-A. Pic 5: using the chart here, basically you match up the number with the letter to get a color. So with my first rod bearing (2), I will go over 2 columns and then go down that column til I get to Row (B) and Yellow will be my color for which bearing I will need. Pic 4: as you can see each bearing has a color on the side of it for easy verification. Same thing as the crank, except the Letters for the crank are on the block where the rear main seal goes as shown in pic 6. the numbers are on the crank and you can use the diagram in pic 5 to show you which numbers go for which journal. Hope this helps a bit for the D16A6 builders
| rebuild | yaris9876 | Performance Modifications | 6 | 12-21-2011 03:43 PM |
| The ugly ugly UGLY rim project thread. ('86 CRX wheels) | 33OH | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 01-07-2011 02:35 PM |
| crx sir jdm front bumper, cf hood, headlights | ilikerice | Items for Sale by private party | 0 | 12-27-2010 09:19 PM |
| Engine Rebuild | rkvin21 | Forced Induction Forum | 0 | 02-25-2010 01:19 AM |
| Rebuild some threads? | Reddog99 | Suggestions - Feedback - Questions | 2 | 10-22-2008 10:20 AM |
