Old 03-13-2013, 04:14 PM   #55
jcboy
Drives: Sedan 07
You get less gas mileage because the supercharger is always going ( well not always, as the blitz does have a clutch) and a small turbo tuned right can do the same thing a supercharger can but get better gas mileage and more power. It would just cost more. And be more of a hassle.
But Philippines? isn't that the land of dirt cheap labor costs?
Well, commodities and services cost a lot there in the US, but you earn big money too. Here commodities and services are dirt-cheap compared to there, but people earn a looot lower than people there. Although the cost-of-living-to-salary ratio is lower compared to what you have, unfortunately it is still not considered affordable since as non-necessities such as car tuning (as compared to house repair) are charged incredibly high.
FYI, A decent paint "washover" can go as low as $500 including labor and paint and all. a $600 paint job is already superb, an $800 paint job is carshow quality already, probably with pocket change.
Old 03-20-2013, 10:15 PM   #56
That wiring is all correct for the Yaris. How did you make your connections (tap splices, solder, etc.)?
Old 03-21-2013, 06:19 AM   #57
Originally Posted by TOLMACH View Post
Update: Just disconnected a bunch of wires and reconnected the same way again: IT WORKS.. dunno what happened
JEEEEE... THE CAR FEELS TWO TIMES FASTER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
CAN NOT BELIEVE HOW GOOD THIS THING IS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
That's great that it is now working. I would recommend either soldering the connections or using some form of crimped connectors. Twist and tape is not a good way to go under the hood.
Old 05-07-2013, 06:56 PM   #58
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
CT, do you by chance have any pictures of your soldering process? I'm not 100% sure how to strip the insulation on the OEM harness w/out cutting any of the wires. Small torch?
I soldered the lights on my trailer last weekend and it was a pretty big pain trying to hold both wires steady enough to get the solder to set. In addition, I ended up cutting the wire that was being spliced in to so that I could get the heat shrink over just those two wires. There were a few stray strands that got nicked by the wire stripper, but I'm not as concerned with trailer lights as I am with the ignition wiring.
Old 05-07-2013, 07:13 PM   #59
I didn't take pictures of that process, but I typically do inline soldering by either of two methods:
Stripping the wire:
1. Strip and smush - Take the wire to connect to, cut through the jacket with a wire stripper (one that has separate holes for each wire size, to prevent cutting the strands). Once you are through the jacket, push the stripper along the wire towards the longer side of the wire (i.e. away from the nearest connector). You can typically get 1/2" to 1" of access to the bare wire by doing this.
2. Carve the insulation - Using a hobby knife (or the stripper above and hobby knife), ring the insulate at two points about 1/2" apart, and then slit between the two rings to remove the section of insulation.
Soldering:
Wrap your wire to attach around the exposed wire, heat the two wires with a soldering iron, and wick the solder into both. Then, a wrap of electrical tape or a shrinkable tape seals the deal.
Old 05-08-2013, 08:02 AM   #60
CrankyOldMan
^Now that you mention it, I think I have one of those around here...
Old 05-09-2013, 08:18 PM   #61
^ I think this thing can also help prevent (to some extent) the heat from going towards the ECU and potentially damaging smth.. My soldering skills are kinda mediocre - overheating the wires is a real possibility ((
You won't really have enough room to use a tool like that, but there are no real worries about overheating the wire. You will be splicing into the wire a few inches from the ECM connector and can even do so with it unplugged...
Old 08-24-2025, 03:30 AM   #62
tmizell
Drives: 2009 Yaris 5 door hatchback
@TOLMACH Thanks for sharing that diagram. Saved the day!
Was shipped a used Blitz with the NCP91 kit, but has the xB Fuel Controller. Couldn't find the proper wiring diagram, until I found your old post.
tmizell is offline   Reply With Quote
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Blitz SuperCharger Install PETERPOOP Forced Induction Forum 127 09-23-2010 01:25 AM
Blitz Supercharger and AEM Water Methanol Kit Morgan Items for Sale by private party 18 01-25-2010 10:54 PM
an other blitz install thanks to Garm s3r3nity Forced Induction Forum 18 05-13-2009 09:35 AM
